Question about Whirlpool GBD307PDS Electric Double Oven
Whirlpool Electric Wall Oven RBS275PDQ6
My oven temperature indicator will go backwards in temperature from 350 degrees even when I press the button to make it go up. It will heat fine and my broiler works on 500. It seems that my circuit board may have gone awry. Funny thing is I just self-cleaned the oven on Saturday and baked in it yesterday and won't go above 350 only downward no matter what I do.
Had same problem, had computer checked out by profesisonal. Was ok. But it seems it is the control pad that clean cycle screws up. Try this (thanks to my wife and her experimental prowess). 1. turn oven on to custom broil. 2. push down temp button to 375. 3. press bake button. 4. You should now have up or down temp. We think you have to get past pre heat cycle in order for this to work. But work it does.
Posted on Jan 08, 2011
    Scholar:
  • 150 Answers
Sounds like board to me, it could alsovbe a problem with the interface like a bad key. self clean runs very high temp and the whirlpool and kitchenaid built ins have been bad about self clean cooking the electronics. the board is expensive but easy easy to replace
Posted on May 07, 2008
  • Stuart Moon
    Stuart Moon Nov 05, 2013
    can we buy a new board?
    Dedicated:
    Visited the website for 20 consecutive days.
  • Whirlpool Expert
  • 84 Answers
If the Whirlpool oven bakes great at 350 degrees, then the problem your having is with the membrane circuitry = The touchpad/keypad on your oven is faulty. The button itself is bad.
You can read more about this issue here -- http://blog.fixyourboard.com/2015/08/18/whirlpool-oven-wont-increase-temperature-up-arrow-decreases-temperature-e1-f2-error/
Replacement touchpads are available for your unit through FixYourBoard.com
Whirlpool Models that normally experience this issue below -- GBS277PDB0, GBS277PDB1, GBS277PDQ0, GBS277PDQ1, GBS277PDS1, GBS307PDB0, GBS307PDB1, GBS307PDQ0, GBS307PDQ1, GBS307PDS1, GBS307PDT1, RBS245PDB1, RBS245PDB2, RBS245PDB4, RBS245PDB6, RBS245PDQ1, RBS245PDQ2, RBS245PDQ4, RBS245PDQ6, RBS248PDB4, RBS248PDQ4, RBS275PDB1, RBS275PDB2, RBS275PDB4, RBS275PDB6, RBS275PDQ1, RBS275PDQ2, RBS275PDQ4, RBS275PDQ6, RBS277PDB1, RBS277PDB2, RBS277PDB4, RBS277PDQ1, RBS277PDQ2, RBS277PDQ4, RBS305PDB1, RBS305PDB2, RBS305PDB4, RBS305PDB6, RBS305PDQ1, RBS305PDQ2, RBS305PDQ4, RBS305PDQ6, RBS305PDZ1, RBS305PDZ2, RBS305PDZ4, RBS305PDZ6, RBS307PDB1, RBS307PDB2, RBS307PDB4, RBS307PDQ1, RBS307PDQ2, RBS307PDQ4, RS675PXEB0, RS675PXEB2, RS675PXEQ0, RS675PXEQ2, RS675PXEZ0, RS675PXEZ2, RS675PXGB0, RS675PXGQ0, RS675PXGZ0, RS676PXEQ0, RS676PXEZ0, RS696PXEB0, RS696PXEB2, RS696PXEQ0, RS696PXEQ2, RS696PXGB0, RS696PXGB2, RS696PXGQ0, RS696PXGQ2
Posted on May 05, 2017
Whirlpool Accubake Wall oven pre heat but temp goes 350 and downwards when pressing temp up
I am not sure about this, but sounds like a connector is on backwards or in the wrong place.
Nov 26, 2014 | Whirlpool Ovens
Bosch double electric convection oven: top oven will heat and display code E1 15 once it gets to 350 degrees, will continue to heat with no response to temperature choosen. Set oven to 350 degrees and...
replace the oven temp sensor, it looks like a metal rod sticking out from the inside back wall inside the oven. part here....
http://www.repairclinic.com/PartDetail/Oven-Sensor/650101/1557889
Jan 23, 2018 | Bosch HBL3420UC Electric Single Oven
Can not raise temperature above 350
500 degrees farenheit is 260 degrees celcius (metric)
any chance the display is set for metric ?
Jun 28, 2012 | Whirlpool RBS305PDS Electric Single Oven
Blomberg BEP 906. After power went out a couple
Hello.
When baking or cooking common foods in your oven, it is important that the oven heats to the proper temperature. Otherwise, the food in your oven could become over- or undercooked. The electric ovens are able to be calibrated if only slightly off, however, if the temperature is 25 degrees off or more, you should replace the oven sensor. The oven sensor is the device in the oven the detects the temperature. The control board increases or decreases the oven temperature, depending on the oven sensor reading. Before calling a repair technician, attempt to calibrate your oven or change the oven sensor.
Instruction
1 Turn on the oven and set the temperature to a medium-heat setting, such as 350 degrees.
2 Allow the oven to preheat and then open the door and insert the oven thermometer.
3 Allow the oven thermometer to remain in the oven for a few minutes and the look at the temperature reading, comparing it to the oven temperature setting.
4 Recalibrate the oven if the temperature is only slightly off, or replace the oven sensor if the temperature is greatly off, such as 25 degrees or more.
Calibrating the Oven
1 Turn off the oven to prior to calibrating.
2 Press and hold the "Bake" button until the calibration settings are displayed on the display.
3 Use the arrow buttons or "+" and "-" buttons to adjust the temperature the number of degrees that the oven is out of calibration.
4 Press the "Start" button to save the calibration settings.
Replacing the Oven Sensor
1 Unplug the oven from the wall or cut the power to the oven in your breaker panel.
2 Open the oven door and remove the oven racks.
3 Locate the oven sensor, located at the top-center of the rear oven wall.
4 Remove the mounting screw securing the oven sensor to the wall and then pull the oven sensor away from the wall.
5 Remove the cable connected to the terminal on the rear of the oven sensor and then discard the oven sensor.
6 Connect the cable to the terminal on the new oven sensor and then reposition the oven sensor and secure it using the mounting screw.
7 Replace the oven racks and then restore power to the oven.
Thanks.
Dec 23, 2011 | Ovens
Oven heats to 200 and indicator dings
Try to set it at 500 degrees and see if it goes off at 350. If it does, then it probably needs calibrating. You can calibrate it by taking the knob off and finding a set screw in the stem where the knob sits. If this is not the problem, you may have to replace the thermostat. By the way, check to see if your temperature probe is not touching the wall of the oven. It will give it a false reading. Let me know if any of these things work and we will go from there.
Jan 29, 2009 | Whirlpool RBS245PDS Electric Single Oven
Oven temperature only gets to within 20-25 degrees of temp. set
next to last page in your manual
Adjusting Oven Temperature
Oven temperature has been factory calibrated and tested. If
oven consistently over or under cooks food, adjust thermostat.
Oven temperature can be increased or decreased 35°F. To
avoid over adjusting oven, move temperature 5°F each time.
1. Push BAKE pad.
2. Press + pad until an oven temperature greater than 500°F
shows in display.
3. Immediately push and hold, approximately 5 seconds,
BAKE button until “00” appears.
4. Press + or - arrow pad to adjust oven temperature.
• To increase oven temperature (for a hotter oven), Press
pad until a positive number appears in display.
• To decrease oven temperature (for a cooler oven),
Press pad until a negative number appears in display.
5. Press OVEN CANCEL pad to save adjustment.
• Setting is saved if power fails or is disconnected.
heres a link to the entire manual if needed
http://shop.amana.com/assets/pdfs/literature/32103601.PDF
Nov 27, 2008 | Amana AOCS3040SS Electric Single Oven
Oven model RBS245pd86
after cleaning the oven the bake temp would not go any higher than 350. when you press the temp button to go lower or higher it only go down. could you tell me what is wrong or what to do.
Jul 27, 2008 | Whirlpool RBS245PDS Electric Single Oven
T3 electric wall oven - Temperature set buttons
I had the same problem. The entire control panel had to be replaced. That included the display, keypad and all the hardware behind it.. it's one integrated unit. Luckily I had the extended warranty, otherwise it would have cost close to $400.
Jan 20, 2008 | Maytag 30 in. Electric Single Wall Oven...
Whirlpool GBD307PDS Electric Double Oven Logo
846 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
