Question about Philips 32PF7421D 32 in. LCD HDTV
Philips 32ta2800, when first switch on tv ok, after 1 hour it become like negative picture, can't see picture well, could you help me
3 Suggested Answers
yungdub
  • 93 Answers
SOURCE: Philips 32TA2800
The Way Im understanding your problem is,
it seems like you need to hook your rcas directly to the tv and switch the surround to aux or something similar to that.
Posted on Jun 14, 2009
  • 128 Answers
SOURCE: philips 50pf9631d/10 Audio ok but no picture
Bad power supply or backlight inverter.
If the backlight is not turning on, you should be able to see the lcd image by shining a bright flashlight at the screen.
Backlight inverters are loud, so you can hear them operating (high pitched whine) and if the backlight is coming on, you can see white light leaking around the edge of the screen, and even a little inside the cabinet.
Philips are legendary for having power supplies that fail due to bad capacitors, so that could be the culprit as well.
Posted on Oct 22, 2009
Philips tv 32TA2800/79 where to buy signal board 715t2441-2
If you really need to buy a PC board, I would contact Philips to see if they are still made. They should be able to tell you who can supply one if they do.
Jan 16, 2014 | Televison & Video
I have a Phillips FLATTV model ... Problem with the Philips Flat Panel Televisions I have a Phillips FLATTV model 42PFL7662D/ 05 I have no picture, the audio is OK, I have had a hissing noise for about 2...
Try with that...
http://www.filestube.com/3c4e959f7e53ba6703e9,g/PHILIPS-42PFL7932-LC420WU5-V2-CIRC.html
Symptom:
Sound but no picture.
Cure:
Master or Slave inverter is defective.
It can be that the driver IC is defective or MOSF
inverter transformers, or 470uF 35V C
Replace driver IC BD9897FS or MOSFET's.
996500046243 IC BD9897FS
996500046242 Mosfet FDD8447L
996500046241 Zener KDZ100V
Oct 18, 2010 | Philips Televison & Video
Philips 32TA2800
Jun 14, 2009 | Philips 32PF7421D 32 in. LCD HDTV
No Picture
check the blue disc capacitors around horizontal output for a burn mark.
Dec 28, 2007 | Philips 26PW6341 26" TV
Loud pop and picture is no longer available.....
blown resistor (42ohm) replaced this and it imediately blew it clearly shows that there is a short circuit in your tv. if you are a tech person please proceed as follows. 1 isolate power supply from hor.output section. 2 now check power supply section.i.e. switching tran., cap..diode etc. 3 if it becomes ok check power supply output. 4 if output is ok then check hor. output section.i.e. h.out tr.,cap& diode in eht winding. 5 check print near eht. 6 at finally eht. 7 see every thing is normal now. now reconnect power to hor.section. put on tv. good luck.
Sep 24, 2007 | Philips 7P6041W TV
Philips wide screen 32in Digital TV
You probably have a component breaking down on one of the circuit boards. It would have to be checked out to find out which one. Stargazer
Feb 13, 2007 | Philips Magnavox 20MT133S 20" TV
Philips 32PF7421D 32 in. LCD HDTV Logo
220 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
