Question about Frigidaire 24 in. GLD2350RC Energy Star® Built-in Dishwasher
My Frigidaire FDB935RHS0 top rack is not getting enough water (pressure) to rotate the top rack sprayer. We have looked at all the connections under the machine as well as the tubing, but we have not found any obstructions or problems. The water moves very slowly up the tube to the top of the machine and the water only seems to trickle out of the feed line therefore the sprayer doesn't spin or spray. We have disassembled the bottom sprayer and have found no obstructions there either. Do you have any suggestions of what we can do?
  • 105 Answers
SOURCE: dishes not washing clean
check water level in machine
may be not filling enough and the wash pump is starved from water thus not pushing water to upper arm
drain water from machine dismantle and clean out air tube to pressure switch take off air tube at pressure switch and blow back into sump then pinch air tube with fingers to stop air from flowing back up tube then refit to p/s
run and see if that solves problem
Posted on Feb 24, 2008
SOURCE: Dishes not cleaning particularly on top rack
Thank you, so much, for the update!
Lita
Posted on Jun 18, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Upper rack sprayers not working on LG ldf7811 dish washer
Check the pump out. Even though the Hose is and tubes are clear it does not necessarily mean that the pump is not pumping water to the top sprayer. One way you can do this is take off the upper spray tube and lay it in a glass or bowl and turn on your machine for a minute or so to get the water flowing if it flows then I would take off the spray assembly itself and make sure that there is no blockage on the bearing race
Posted on Apr 08, 2009
  • 423 Answers
SOURCE: Frigidaire Dishwasher - Spray Arm Not Working
When a dishwasher has been checked for obstructions in the sump area and the spray arms can spin easily (by hand) plus the spray arm holes are not blocked, you end up with either a broken impeller or a failing wash pump motor.
If you would like more details of have more questions, please post comment back here, OK?
Good Luck!
Posted on Apr 26, 2009
  • 2501 Answers
SOURCE: lower spray arm siemens aquastop dishwasher doesn't rotate
Sprayers require water to pass through the jets to provide motion to the arms.
Suggestion;
Remove the sprayer from the machine and look for blockages. (Removal should be easy, at it is expected that the user will need to clean the jets occasionally; If you have any problems removing it, consult your manual).
Posted on Dec 14, 2009
Testimonial: "Thanks for a speedy and v helpful reply. Sounded obvious, but I hadn't checked the water inlet(which was calcified)just the jets on the arm itself! "
Dishwasher won,t clean dishes ontop rack
Make sure the top rack is pushed back all the way to connect with upper sprayer arm water port. Also make sure nothing is preventing either sprayer arm from rotating and there is nothing blocking the sprayer arm holes, like seeds or pieces of plastic debris. Also make sure your water heater temp is hot enough.
May 18, 2011 | Electrolux EIDW6305GS Builtin Dishwasher
My dishwasher is leaving a lot of residue on dishes
I had the same problem and fixed it by disassembling the lower spray arm and return filter, and cleaning all the junk out.
Most dishwashers have 'risers' that bring the water up to the top sprayer or arm located under the top rack. If the recirculating pump is plugged even a little there won't be enough volume or pressure to get the water up there.
Test this by putting a dry muffin pan in the top rack, flat, and running the dishwasher for a bit. If there is no water on the top (or the bottom) either the top sprayer or the sprayer arm underneath the top rack is not getting enough volume.
To fix this you need to clean out the screen and filter, where the water returns to be recirculated. If you don't have any confidence to remove the parts and clean it out yourself, get an appliance repair person to do the job.
Aug 26, 2009 | Dishwashers
The dishes on the top are not getting clean what can be the trouble? Tea stains and grit are left in cups and glasses.
I have a GE Profile Dishwasher Model # GSD4940Z00SS. It does not wash very well. Water stays at teh bottom after each wash cycle. We have blow air through tubes and looked for obstruction but can not...
I had a similar problem and fixed it by disassembling the lower spray arm and return filter, and cleaning all the junk out.
Aug 24, 2009 | Dishwashers
DISHES ARE NOT COMING CLEAN BYPASSED THE DOOR LATCH TO WATCH CYCLES,LOOKS LIKE THERE IS NOT ENOUGH WATER PRESSURE TO ACTIVATE THE WATER TOWER AND ROTATING ARM?WATER PUMPS OUT BUT NOT ENOUGH TO MAKE THINGS...
Top water injector not working
Aug 24, 2009 | Frigidaire 24 in. FDB126RB Built-in...
Spray arms do not turn. water to them but not
Aug 23, 2009 | Bosch 24 in. SGS43C12 Classixx...
Our dishwasher is type no:575-0, model:665.17369301.dishes r not getting clean properly.
This may help you.
Aug 22, 2009 | Dishwashers
Not enough water pressure to move upper arms or clean dishes
Recommend you pull the bottom spray arm straight up, then out of the DW.
Remove 9 phillips screws that hold the filter shroud down. Remove the filter and clean/rinse it out.
While the filter it out, grab a flashlight and inspect all over the sump area. Especilly in the area the has the check valve that rotates (Vario motor-driven) to feed the water pressure either to the lower and then the upper arms. Watch out for broken glass! Also, inspect the impeller to see if it is undamaged and spins easily.
Reassemble, then test out.
If problems remain, the the wash pump motor is probably the culprit. Do you get any error messages on the time display?
Good Luck!
Apr 05, 2009 | LG LDF6810ST Stainless Steel Built-in...
Top wash rack doesn't get water
does the unit have a half load selection? if so then it may be stuck in half load due to a faulty solenoid in the base.
Mar 14, 2009 | Dishwashers
Frigidaire 24 in. GLD2350RC Energy Star® Built-in Dishwasher Logo
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
