Question about Mk Diamond MK - 170 Wet Cutting Tile Saw
I have a mk 101 and when you turn it on it runs for about 25 seconds then the breaker trips
  • 128 Answers
Sounds like brushes in motor when gets to hot it shuts off have motor rebuilt
Posted on Aug 29, 2010
Tip
Fuse blown or breaker tripped
Due to short circuit or burnt wiring in air conditioning. It may happens due to high voltage or undersized wiring. When fan motor or compressor grounded, then it will trip the breaker or blow the fuse.Fuse wires should be 3 times amps of actual running amps.Breaker should be same. If your a/c model current is 8.3 amps, breaker/fuse should be 25 amps.
on Jan 10, 2011 | Heating & Cooling
Dryer blows circuit breaker after running 10-20 minutes.
indicates problem motor , overheating in the wiring or excessive loads in the drier
Jun 07, 2017 | Kenmore Dryers
Kenmore elite dryer runs for about 3 min. then trips the breakers
The circuit breaker may be tripping because of a fault with the dryer or it may be a fault with the circuit breaker being weak.
From the description you give the circuit breakers trip frequently.
I'd suggest you first try selecting the no heat air fluff cycle and run it to see if the breaker trips. If the circuit breaker doesn't trip in air fluff then there is likely a short in the heating element.
With a clamp-on amp meter you can read the amp draw of the dryer when it is heating. With the motor and element both working you would see approximately 25-26 amperes being drawn. The breaker is rated at 30 amps. If the breaker trips and only 26 amps are being drawn then the breaker is the problem.
Try the air fluff cycle first and see if the breaker will trip. Then with additional details I may be able to help you further.
Jan 05, 2011 | Kenmore Dryers
Start capacitor keeps blowing. saw starts up
SOUNDS LIKE THE CENTRIFUGAL SWITCH IS NOT WORKING.
THE MOTOR IS STARTING ON THE START WINDING AND NOT SWITCHING TO THE RUN WINDING. THAT IS THE REASON IT IS RUNNING SLOW.
May 13, 2010 | Diamond Products Mk - 101 10" Tile Saw
I have a Craftsman 25 Gal Air compressor that is about 15 years old ans all of a sudden it is tripping the breaker instantly on start up. nevr had this probplem before, every now and then it would trip the...
Try plugging something of similar amperage into same outlet, see what happens. If breaker trips, check wires in outlet box.
If not, start checking wiring in compressor, from plug back - ALL of wiring,
And scrutinize connections! Good luck! Joe.
Feb 14, 2010 | Craftsman Air Tools & Compressors
My LG window ac continues to shut down after 20 or 25 minutes
The button on the plug is a GFI. Ground fault interuppter. Like on your hair dryer. When the unit is running, or has just tripped out, feel the plug and the well receptical. If either feel warm or hot, do not continue to run the A/c unit. Get an electrician to check for a faulty/ worn/improperly wired outlet. The units tripping out for a reason.
Aug 01, 2009 | Samsung AW0603B Air Conditioner
Tile saw tripping breaker even after letting it cool down for 24hrs .
2 things first what is the motor rated at for AMPS and second the circuit you plug it into what is the rating. The saw will draw more than the namplate rating for startup but it would still pull a lot and if you have something else on that circuit it could be causing the problem assuming there is no major electrical problem with motor
Jul 02, 2009 | Mk Diamond MK 101Pro Tile Saw
Mk Diamond MK - 170 Wet Cutting Tile Saw Logo
378 people viewed this question
Top Mk Diamond Saws Experts
JonSnell Electronic
JonSnell Electronic
Regalo Tiles
Are you a Mk Diamond Saw Expert? Answer questions, earn points and help others
