Question about Dryers
I have a Whirlpool dryer model #LEN200LWO. It takes 3-4 times through the cycle to finally get the clothes dry. I've noticed too that there doesn't seem to be much lint on the screen - which I clean before every cycle.
  • trish340 May 12, 2008
    You were exactly right! We went to clean out the vent hose and it was FULL of twigs, straw etc! Birds had built a nest in the vent and up into our dryer! I've never seen anything like it! We were lucky there wasn't a fire! It works great now and we have blocked the outside vent from the birds!
    Scholar:
  • 150 Answers
Bad airflow definitely bad airflow use real metal vent hose not the coil and plastic or mylar. make sure the vent at the outside wall is not stopped up somewhere there is a blockage
Posted on May 07, 2008
How do you dry clothes in this machine please
A fairly common problem! The official instructions are
Before using your dryer, wipe the dryer drum with a damp cloth to
remove dust from storing and shipping.
1. Load clothes loosely into the dryer and close the door. Do not
pack the dryer. Allow space for clothes to tumble freely.
2. Turn the Cycle Control knob to the recommended cycle for the type of load being dried. Use the Energy Preferred Automatic Setting (,) to dry most heavyweight and medium weight loads. See "Drying, Cycle, and Temperature Tips."
3. Select a temperature setting on models with a Temp/Fabric selector. The cycle descriptions include temperature setting suggestions.
4. Push the START button.
Stopping and Restarting
You can stop your dryer any time during a cycle.
To stop your dryer
Open the dryer door or turn the Cycle Control knob to OFE
NOTE: The Cycle Control knob should point to an Off area when
the dryer is not in use.
To restart your dryer
1. Close the door.
2. Select a new cycle and temperature (if desired).
3. Press START
Extracted from
http://www.manualslib.com/manual/511763/Whirlpool-Lte5243dq.html?page=10#manual
Nov 14, 2015 | Whirlpool AWZ410 Front Load Washer/Dryer
Dryer won't dry clothes
How to check the timer:
Sep 26, 2012 | Whirlpool Dryers
My whirlpool electric dryer WED5560SQ0 takes an extremely long time to dry, almost like it steams
it defne sounds like one or more of your heating elements is faulty , try a simple continuity test on them
Feb 12, 2012 | Whirlpool Dryers
Hi there, I've got a Whirlpool dryer that doesn't dry clothes anymore. The clothes get really hot, but they stay damp, never properly dry after several cycles and then smell mouldy. Oddly,...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Sep 05, 2011 | Dryers
I have a whirlpool model# Ler4634pq0 electric dryer. Heats ok, takes 3 cycles to dry clothes. Cleaned vent hose, cleaned internal duct system, cleaned lent screen, and holes inside drum. Any ideas?
If you 've done all of that and it still doesn't dry properly, you may have a faulty limit switch. These limits switches are usually down by the burner assembly and not much bigger than a quarter with generally 2 wires going to them. Very easy to replace once you find it. Unplug the dryer before you work on it.
Apr 12, 2011 | Whirlpool Dryers
I have a whirlpool gas dryer model LGQ9508PW0. It is not drying. I noticed that it would egnited the firest time but not after that. I replaced the egniter thing it was worn. Now WITH NOTHING IN IT it I...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Aug 24, 2010 | Whirlpool Dryers
Whirlpool dryer model #GEW9250PT1 not drying properly
when was the last time you cleaned your dryer?all a dryer does is move air around and if it can't cycle through the dryer the clothes won't dry. unplug the dryer and then you need to clean the duct that the lint filter slides into,vac out the inside of dryer where the motor is and clean out the vent line,if the vent line is a long run from the back of dryer to the outside vent i use a leaf blower to clean it out,make sure the outside vent is clear first then blow it out,if it's a short run vac it out,most problems start just from lint buildup,the clothes don't dry the dryer runs hot and parts start messin up,also vac out under your fridge,take the bottom kick plate off and vac it out,you can kill the compreesor if you don't,good luck
Apr 05, 2010 | Whirlpool Dryers
My dryer takes 2 to 3 cycles to dry my clothes.
Check the following areas to combat this issue. in most cases, this will be a Venting issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 21, 2009 | Whirlpool LER4634J Electric Dryer
Washer won't spin dry clothes
What model is in reference here? Please post back with model number.
Jul 02, 2008 | Whirlpool 3.2 cu. ft. Plus Washer
Dryers Logo
51 people viewed this question
Top Dryers Experts
