Question about Akai Televison & Video
When you press the power botton the TV turns on breifly then shuts down on its own. the timer light is solid for a few seconds then flashes three to four times then shuts its self off. theres no picture when this all happens AKAI model #pth5498
  • Akai Master
  • 12,061 Answers
Well usually with these sets from my professional experience this symptom, is a fairly classic switchmode power supply, shutting down to avoid a fire, explosion, or both. This set had developed a problem, that is so severe that the set must be shut down, This set should be removed from the Power. It is my professional recommendation, that you should get a "Quote" for repair, from, an, Approved Service Center, this point is very important for a good result, Always contact, their local, "Head Office" Now, when you get the information you want, then you can decide as to repair of replacement. The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free.
IF you wish, to have a go, and try to repair you set, well OK, I guess. But PLEASE, if you do, please always start in the right place, otherwise you will simply waste your time and money, You see, you MUST start, in the right place, and troubleshoot,he power supply, FIRST, as, if, that isn't right, nothing else can be. But, here you simply cannot do anything without a Service Manual. (I have searched for one BUT couldn't find one, so one would have to obtain one from the manufacturer) In this it has everything one needs to troubleshoot & repair the set.
OK if it is shutting down, after that amount of time, of working and then faulting, then it is most definitely a "Thermal" problem, the way we "Find" problems such as this is, to examine each component and feel if it is too hot... then use "Freeze Spray" you use this on each component that is suspected of being the "Culprit" and you will soon,find that errant component. Now, also many people think that ALL capacitors, are the problem, well not every fault is a Capacitor, I see many, many people that think, that Capacitors are always the "Culprit" and replace them, Willy-nilly because someone else had done so and it worked, well that maybe sometimes true, but most Symptoms, can, and do have many, many different "Causes" & also, now while that may be true in a few cases, a faulty Electrolytic Cap, or even, ordinary, Cap goes faulty, this is only a SYMPTOM, something has damaged those caps causing them to "Fail". One MUST always find the root "Cause", otherwise if you just treat, the SYMPTOM, the "Cause" will just make the "Symptom" come back, in short order, as the prime cause still, because that "Cause" hasn't been fixed., Now Capacitors hate AC ripple, or Over Voltage. Thats it. Oh.. and Heat, if these Capacitors, are too close to a Heat Source, then thats a prime cause of failure. Resistors, hardly ever go faulty,and if they do, it is generally obvious. However it doesn't hurt to check values with our Multimeter. Remember though resistors are made, with up to 20% tolerance from stated value, as such, are not too critical, unless in Timing circuits etc. Always check, the Values, of resistors, as with any other component, with the power OFF. Now Diodes especially "Zener Diode", are another thing to check, those and ordinary "Signal Diode" should always be suspect. next we have Transistors and IC's. The Transistors MUST ALL be checked to see if they have a good, "Junction" this is done, with our meter set to "Diode Test" and usually are about 0.6 to 0.7. With IC's you must check, voltage levels, or Logic Levels, going in and out, have a look at the circuit diagram, and it will tell you what they should be. It is a good idea to always measure the Power Supply voltages, see if a "Rail" is Low, that will be because some component has gone somewhat or all short circuit, to Earth, now, if the "Rail" is Higher, suspect an "Open Circuit" component, like a Diode, or Transistor. The voltages expressed in the manual are spot on, ANY variation MUST be investigated. I have been doing all this for over 30 years now, and I do indeed wish, we could have a set of "Symptoms" and be ables to say.. "Oh that;s the so-in-so and replace this" however unfortunately this although does happen, most "Symptoms" can have literally tens, of "Causes" all often "Interlinked" One simply has to do a methodical troubleshooting procedure, and always think, "are my Voltages Correct" as this is how, you Fix the problem, by making them so. Keep up the good work. If that link above doesn't furnish a Service manual, it is imperative you get one, even if you must pay for it. It will pay for itself in about 2 mins.
Posted on Aug 29, 2010
We have a wd 57732 a solid yellow light on when turn tv on message air flow block shut down in few seconds shuts off with two green lights flashing and solid yellow acks as if room temp to warm. sometimes...
The lamp needs to be replaced. It's on the back and easy to do. I replaced mine about 3 months ago and it was about $182.00. Hope this works, I know it's hard to fork out that kind of money at this time but once you do the TV will be as good as new. Take care
Jun 09, 2011 | Mitsubishi WD-57732 Projection Television
On timer light is flashing.and tv shuts off in about 5 seconds after turnig it on.
Hello
Timer function is in ON position and have been set to the least time I thinks. You just go to the menu and put the timer fuction of OFF.
The On/Off timer lets you program your television to turn itself on or off. You can use it as an alarm
to wake up, to help you remember important programs, or as a decoy when you're not home.
Press the MENU button
Press UP or DOWN button on the remote control hanset to ON/OFF TIMER
Make it OFF.
Switch off the TV by its front panel power button, and switch it ON again after 10 seconds.
OK.
Dec 06, 2010 | JVC AV-27D302 27" TV
I need the code to program my dish network remote for the Polaroid 42 inch LCD television
press and hold the tv botton on you dish remote till all the lights light up release the tv botton it should stay flashing then hit the larger of the two red power bottons next you will need to hit the up arrow one at a time till the tv shuts off when the tv shuts off you then hit the # botton at the bottom you wiil see the tv botton flash your code will then be saved
Dec 02, 2008 | Televison & Video
I have a Mitsubishi WD-62525. This morning my TV would not turn on so I pressed the rest button. After the Timer light stopped blinking I pressed power. I could hear the fans start than a somewhat loud...
the status light blinking red means a fan (the unit hs 4 of them) has failed. you need to determine which one. use the self diagnostic function:
Error Code Operational Check
Note:
The TV must be in “Shut Down” and not manually switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to “12” No Error.
Press the front panel “DEVICE” and “MENU” buttons at the same time, and hold for 5 seconds to
activate the Error Code Operational Check. The LED will then flash denoting a two digit Code.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
Example: If the Error Code is “32”, the LED will flash three times, pause, and then flash two times.
• The Error Code is repeated a total of 5 times.
and read the code.
35= Chassis Fan failure
36 =Exhaust (Back Cover) or Lamp Ballast Fan failure
37= Engine (DMD or Lamp) Fan failure
Nov 15, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Fujitsu Plasmavision PDS-4233
HI, I haHe a Fujitsu Plasma HDTV Model PDS4233. The TV won't power ON, When i turn on the master power button the light starts flashing a red light repeatedly. I also observed that the Fans power up for about three seconds immediatly after i press the master power button, after the three seconds the fans shut OFF and the light continues to blink.. I haven't observed the light to see if there is a pattern with the blinking..
Aug 30, 2008 | Fujitsu Televison & Video
Won't come on
hy i got a toshiba 42" LCD tv ,when i press the power boton
iget the red light,& it stay that way ontil i pressthe power back off
thanks for any help
Jun 26, 2008 | Toshiba 62HM95 62" HDTV
Sony bravia tv
Solution is simple....
First, unplug power cable from the back of your TV. You will notice the flashing light is still flashing. Don't worry, go to the Second step.
Second, keep pressing on the POWER button, located on the panel at the top of your TV, to shut off your TV. This will stop the flashing light from appearing.
Third, Plug the power cable back onto your TV
Fourth, press the POWER botton ONCE, using the same button used in the Second step to turn your TV back on.
Fifth, you will see the POWER light comes on, as normal.
Sixth, using your remote control, press the green button to turn on. Your TV should work as normal.
Jun 08, 2008 | Televison & Video
Mitsubishi WS73713 - Now working - Timer light flashing.
My Mitsubishi WS-73713 had the same blinking green timer light problem and would not turn on. I tried the reset button and unplugging power to no avail. I found that by simultaneously holding down the remote control "power" button and "volume" button for about 30 seconds the blinking light would go out and a solid green light would come on. Even though the solid green light came on the unit would still not power up. After doing this several times however the unit did finally power up in a normal mode and appears to be working again. It's worth trying before calling in for an expensive repair. PS - From here on out I'm sticking with SONY or Toshiba sets which have given be great service.
Nov 09, 2007 | Televison & Video
TV shuts off automatically
I Can Assure You That This Problem Is Associated With 2 Capicators On The Power Supply Board.
Aug 24, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Televison & Video Logo
61 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
