Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
The wiring of an AC motor panel
I would like to know more on the above subject along with the components required for switch gear circuit and motor circuit, circuit diagrams and the procedure for wiring the motor circuits.
Solomon
ntjanas@yahoo.co.uk
If you can let me know exactly what it is you are trying to achieve I will be able to help out. For instance do you need the motor to run continously, does it need to have variable speed, is it single or three phase, what rating is the motor
daz
Posted on May 14, 2008
I have a 04 Pontiac G6 4 door sedan the sun shade opens up no problem but when I try to open the glass the first one lifts up but that's it the other 3 pieces dont
Power Sunroof System Components
The power sunroof system consists of the following components:
• One tilting glass sunroof panel--For sunroof vent functions
• Three sliding glass sunroof panels, which allow the sunroof to open in sections
• Power sunshade panel--An adaptable panel which is rolled out or rolled in and stored by the sunshade motor/actuator in order to cover or uncover the sunroof glass panels
• Power sunroof switch--A rotary style switch controlling sunroof switch signal inputs to the sunroof motor/actuator
• Power sunshade switch--A momentary press style switch controlling sunshade switch signal inputs to the sunshade motor/actuator
• Power sunroof motor/actuator--Comprised of both the sunroof motor/actuator and the sunroof electronic control module, it is sometimes referred to as the sunroof control module/motor assembly.
• Power sunshade motor/actuator--Comprised of both the sunshade motor/actuator and the sunshade electronic control module, it is sometimes referred to as the sunroof slave module.
Sunroof Motor/Actuator and Sunroof Switch
The sunroof motor/actuator assembly is located at the rear of the passenger compartment, above the rear view window, between the headliner and the roof structure. The sunroof motor/actuator assembly also contains the sunroof electronic control module and the two components are serviced together as a unit.
Battery positive voltage is supplied to the motor/actuator at all times through the 25-amp LAMELLA ROOF fuse located in the rear fuse block. Whenever the ignition is turned to RUN or ACCESSORY, or when the retained accessory power (RAP) system is active, the motor/actuator is also supplied battery positive voltage through the accessory voltage circuit and the 10-amp ROOF/HEAT SEAT fuse which is located in the body control module (BCM). The sunroof motor/actuator is grounded through splice S403 to body ground G302.
The sunroof motor/actuator supplies voltage to the sunroof switch through three internal resistors and three hard wire circuits. The 3 hard wire circuits are:
• Sunroof switch data 1 signal circuit
• Sunroof switch data 2 signal circuit
• Sunroof switch data 3 signal circuit
The sunroof switch, which is also grounded to G302, is a rotary style switch. When the switch control lever is turned in a rotational direction, the appropriate switch contacts and signal circuits for the selected mode are simultaneously opened and/or closed to ground in order to provide the appropriate combination of voltage signals to the sunroof motor/actuator. The sunroof motor/actuator interprets the signals, and then applies battery positive voltage and ground to the appropriate circuits of the integral power sunroof motor in order to move the sunroof glass panels. At the same time, the sunroof motor/actuator sends a serial data message, via the keyword 2000 serial data circuit, to the sunshade motor/actuator to open the sunshade panel in conjunction with the sunroof glass. As the sunroof glass panels slide rearward to the open position, the sunshade motor/actuator simultaneously rolls in the adaptable sunshade panel.
The sunroof switch is mounted in a bezel which is located above the rearview mirror.
Circuit/System Description
The sunroof system is controlled by the sunroof switch and the sunroof control module/motor assembly, which is also known as the motor/actuator assembly.
The sunroof control module is supplied battery positive voltage at all times through the 15A SUNROOF fuse located in the rear fuse block. Whenever the ignition is turned to RUN or ACCESSORY, or when the retained accessory power (RAP) system is active, the module is also supplied voltage through the accessory voltage circuit and the 10-amp ROOF/HEAT SEAT fuse located in the body control module (BCM). The sunroof control module is grounded through the ground circuit at G302.
The sunroof control module supplies voltage to the contacts of the sunroof switch through the sunroof switch close signal circuit and the sunroof switch open signal circuit. The sunroof control module also supplies ground to the switch contacts through the sunroof switch low reference circuit. When the switch is operated, the contacts and signal circuit for the selected mode are closed to ground, the voltage is pulled low in the module, and the appropriate signal is recognized by the control module. The control module then internally applies battery positive voltage and ground to the appropriate circuits of the reversible power sunroof motor in order to move the sunroof glass panel to the open, close, or vent
Do you know how to do electrical testing ?
Circuit/System Testing
Ignition OFF, disconnect the harness connector at the sunroof control module.
Ignition OFF, test for less than 1.0 ohm of resistance between the ground circuit terminal 1 and ground.
? If greater than the specified range, test the ground circuit for an open/high resistance.
Ignition ON, verify that a test lamp illuminates between the ignition circuit terminal 3 and ground.
? If the test lamp does not illuminate, test the ignition circuit for a short to ground or an open/high resistance.
Verify that a test lamp illuminates between the B+ circuit terminal 6 and ground.
? If the test lamp does not illuminate, test the B+ circuit for a short to ground or an open/high resistance.
Connect the harness connector at the sunroof control module.
Ignition OFF, disconnect the harness connector at the sunroof switch.
Ignition OFF, test for less than 1.0 ohm of resistance between the low reference circuit terminal B and ground.
? If greater than the specified range, test the low reference circuit for an open/high resistance. If the circuit tests normal, test or replace the sunroof control module.
Ignition ON, test for B+ between the signal circuit terminal C and ground.
? If not the specified value, test the signal circuit for a short to ground or an open/high resistance. If the circuit tests normal, test or replace the sunroof control module.
Test for B+ between the signal circuit terminal A and ground.
If all circuits test normal, test or replace the sunroof switch.
Oct 13, 2017 | Pontiac Cars & Trucks
Power windows dont work
There is a circuit breaker for power windows .
Power Window System Components
The power window system consists of the following components:
Driver Door Switch (DDS)
Passenger Door Switch (PDS)
Body Control Module (BCM)
Rear door power window switches
Power window motors in each of the doors
PWR WDO Circuit Breaker
Power Window System Controls
The power window system will operate anytime the Retained Accessory Power (RAP) system is active or when the ignition switch is in the ACCY or ON position.
The driver master control switches are integrated into the DDS. When a power window switch is activated in the up or down positions the DDS supplies power and ground to the window motor control circuits to drive the window motor in the required direction. Prior to activating a power window motor the DDS will supply the control circuit with a low current bias voltage in order to determine that a short to ground condition does not exist and during window motor operation the DDS continues to monitor the motor current to verify proper window motor operation.
The DDS controls the passenger window by a serial message to the PDS. When a power window switch is activated in the up or down positions the PDS supplies power and ground to the window motor control circuits to drive the window motor in the required direction. Prior to activating a power window motor the PDS will supply the control circuit with a low current bias voltage in order to determine that a short to ground condition does not exist, and during window motor operation the PDS continues to monitor the motor current to verify proper window motor operation. (Scan tool support is available for this system
Check this circuit breaker
RETAINED ACCSRY PRW BRKR 30 amp. located in the left instrument panel fuse box . if the breaker is good check power B+ at the drivers door switch . connector 1 terminal b yellow wire . Sometimes the wires inside the rubber boot coming from body to door break .
Oct 29, 2015 | 2005 Chevrolet Impala
1993 Ford Escort Blower Motor & AC Switch
I'm going to start from the beginning.
The blower motor gets power from the high blower relay and it is grounded thru the fan switch and the resistor. So you should have power on the pink white blower wire coming from the high relay to the blower motor. The orange black wire from the motor is ground going to the resistor and fan switch. The blue wires on the control panel are for the ac compressor.
The high blower relay gets power from fuse number 5 in the box. The blower motor is grounded thru the resistor and then thru the fan switch.
Photo courtesy of AutoZone.com
Jun 10, 2013 | 1993 Ford Explorer Limited
2004 Honda Accord a/c will not come on. Blower motor resister was replaced last year. compressor would start and stop. now nothing. I have switched relays around but to no avail. Also winsheildwipers work...
You will probably need a shop manual to have the wiring diagrams needed to trace the circuits.
There may be other components that affect both the wipers and ac but I know the key switch does.
Jul 07, 2012 | 2004 Honda Accord
I have a motorguide electric motor model # st 200 made in 1991 it is a perfect trolling motor but gears #1 &#2 are gone.This a superb little motor for fishing just the right speed on small lakes.I'm...
How about selling your friend's old Motor to me for some $ . I don't care about the "gone gears" as I 'am converting a gas Brushwacker 37.7cc, to a boat motor. Charles Craver 336 254 9276 quietus.charles@gmail.com.
Aug 27, 2010 | MotorGuide Standard Motor Replacement...
Power windows wont work what fuses can i check i have replaces the driverside switch.
Fuses, Switches, Circuit Breakers And Relays
Check under hood and under the dash driver's side.
There may be a sticker on the inside of the panel cover that tells you the legend. Otherwise, it requires testing each and every one of those fuses, preferably with a fuse tester that can do it more expediently than pulling each one out and looking for a broken conductor.
Most vehicles use one or more fuse panels. This one is located on the driver’s side kick panel tcca6p01.jpg
It is possible for large surges of current to pass through the electrical system of your vehicle. If this surge of current were to reach the load in the circuit, this surge could burn it out or cause severe damage to the vehicle’s electrical system. It can overload the wiring, causing the harness to get hot and melt the insulation. To protect vehicle wiring, fuses, circuit breakers and/or fusible links are typically installed into the power supply wires throughout the electrical system. These items are nothing more than a built-in weak spot in the system. When an excessive amount of current flows through a circuit it causes an increase in heat throughout the wiring. Fuses and circuit breakers are designed as the weak link in the system and will disconnect the circuit to prevent damage to the components contained within that circuit. Components are equipped with connectors so they may be replaced in situations where they were damaged due to a power surge.
The following are descriptions as to how fuses and circuit breakers protect the electrical system:
  • Fuse- A fuse is a weak link in the system designed to create an open circuit when the amperage flowing through that circuit exceeds the limits of the fuse. As the amperage increases, the conductor within the fuse heats up and eventually melts and breaks apart. This open circuit interrupts the flow of current and protects the components in the circuit.
  • Circuit Breaker- A circuit breaker is a "self-repairing" fuse. It will open the circuit in the same fashion as a fuse. The surge creates heat the same way that a fuse is affected. When the surge subsides and the circuit cools down, the circuit breaker will reset and allow current to flow through the circuit. Typically circuit breakers do not need to be replaced.
  • Fusible Link- A fusible link (fuse link or main link) is a short length of special, high temperature insulated wire that acts as a fuse. When an excessive electrical current passes through a fusible link, the thin gauge wire inside the link melts, creating an open to protect the circuit. To repair the circuit, the link must be replaced. Some newer type fusible links are housed in plug-in modules, which are simply replaced like a fuse, while older type fusible links must be cut and spliced if they melt
CAUTION
Always replace fuses, circuit breakers and fusible links with identically rated components. Under no circumstances should a protection device of higher or lower amperage rating be substituted.
Switches Switches are used in electrical circuits to control current flow. The most common use of relays and switches is to open and close circuits between the battery and various electrical loads in a circuit. loads are rated according to the amount of amperage they can handle. All of the current that the controlled load uses flows through a switch. Using a switch with an amperage rating lower than what the circuit is rated for could overload and cause damage to the components located on that circuit. Relays
The underhood fuse and relay panel contains fuses, relays, flashers and fusible links tcca6p02.jpg
Relays are used to control high-current loads with lower currents. Since these some loads require a large amount of current, the thickness of the wire in the circuit is also greater. If a switch were used to control the circuit, all of the current required to power the high-current load would have to pass through the switch. From a design standpoint, relays are used to limit current through switches and reduce the amount of heavy gauge wiring in the vehicle.
Relays are constructed of a set of switch contacts and a small electro-magnetic coil. When current flow through the coil a magnetic field is created. This field causes the contacts to touch, in turn completing the high-current circuit. Typically, relays are constructed so that the secondary contacts are open when the relay is de-energized (turned off). Circuits where relays are used include, but are not limited to, the horns, headlights, starter motor, electric fuel pump, blower motor and cooling fan motor.
Relays are composed of a coil and a set of switch contacts. The large wires connect a high current power source to one side of the relay switch contacts and from the other side of the relay switch contacts to the load. The smaller wires connect a low current power source to the relay control coil and from the control coil to the control switch and then to ground. tcca6g02.gif
Load Every electrical circuit must include a "load'' (something to consume voltage from the power source). Loads are resistances included in circuits to limit current flow. Loads are the components installed in circuits, such as headlights, wiper motors, door lock solenoids. Without a load, the battery would flow all of its energy through a circuit directly to ground. This is called a "dead-short to ground". The unchecked flow of electricity would cause a great amount of damage to the circuit by developing a tremendous amount of heat. Short circuits can develop sufficient heat to melt the insulation of surrounding wires, even reducing a multiple wire cable to a lump of plastic and copper.
Jul 26, 2010 | 2001 Ford Taurus
I want to know the components required to make 6HP load pump pane
You havent indicated what voltage of phase. Is it single phase or 3 phase. 120V or 480V? Bacically you need some type of fuseable disconnect (breaker or fuses) a motor starter (contactor with overloads) and something to control the starter (either manual starter or coil energized starter controlled remotly. A good source of info is: www. Mikeholt.com
May 25, 2010 | Electrical Supplies
Heater bower won't blow
There is a blower motor relay,near the motor i think,check it.
Apr 12, 2010 | 1998 Ford Contour
I have a panasonic NV-HD620 with a F04 error message.
You appear to have a K Mech model. F04 means the mechanism locks unloading. The cause of this is the Load Motor timing.
Sep 09, 2009 | Panasonic NV-HD680 VCR
Subject: 2004 isuzu rodeo...my ac/heater blower is not working
The resistors are in circuit only on the lower fan speed settings.
On the highest speed setting, power is switched directly to the fan motor.
Check fan power supply fuses,
Check power is available to the fan when high speed selected.
If all above OK, apply power directly to the motor to verify fan motor runs- if it doesn't the motor may need replacement/repair.
Jul 29, 2009 | 2004 Isuzu Rodeo
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
95 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
