Question about LG W2353V-PF 23' LCD Monitor
The image leaves about 2.5 inches not used on each side of the monitor.
Actually, I believe I have the same problem which is the below solutions don't resolve.
When I hooked up my W2353 to HDMI the screen leaves about 1 in" blank borders on the lateral sides and 0.5" blank borders on the top-bottom. This is not a 4:3 aspect ratio problem and I have tried different resolutions. When in DVI mode it fills the viewable completely. Any ideas?
Posted on Oct 11, 2010
  • 1,684 Answers
The bands are caused by the monitor displaying a picture that is not the correct resolution. This model has a native resolution of 1920 x 1080 according to LG - see http://www.pcworld.com/reviews/product/124873/review/w2353vpf.html#specs When you have your video card set to a different resolution that this the monitor tries to adjust the display to best fit the screen. The native or default resolution is 16:9 or wide-screen and if you have the video card displaying at 4:3 then you will have the blank bars displayed. Go to display properties and change your resolution to one that is 16:9 ratio and the bars should fill out.
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Posted on Aug 29, 2010
  • 131 Answers
If it is Windows, then open the display properties by right clicking on the desktop and selecting Properties. Click on the Settings tab and adjust the resolution until you fill the screen. Look for 1920x1080, if your video card can handle it. Press the Apply button to try the setting. If it works, press Yes and then OK.
How do i make it full screen?
Look in the settings for apex then adjust the wide and t in there.
Terry
May 02, 2014 | BenQ G2250 21.5 Full HD LCD Monitor BENQ
I have a SAMSUNG SyncMaster 940bw about 4 years old which is on about 20 hours a day. A one inch grey stripe appears on the left side of the monitor running from top to bottom. Words and images on the...
Monitor this old will more likely to have bad DC filter caps by now, but you also may have failing LCD panel also. I would inspect the caps and voltages in the power supply section first.
You can failed SAMSUNG monitors due to bad caps in my albums.
You should read my guides also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Jan 06, 2011 | Samsung SyncMaster 940N Flat panel Monitor
My apple cinema 30 is connected to my PC and works fine, but there is a slightly darkened region with corners x=0, y=4 to x=8, y=6 (inches). So the region is about 2 inches high and 8 inches long. I...
Hi and welcome to FixYa!
Is the monitor near a speaker or in any magnetic interference? If it is, I strongly suggest that you move the lcd a little farther. If it still fails then the problem will be on the monitor itself. It's better to get a replacement than repairing for it will surely cost you.
Hope this helps and thank you for using FixYa! Have a good one!
Dec 27, 2010 | Apple Cinema HD 30" LCD Monitor
My Monitor, which had never been used but been in storage for about 1 year, has a 2 inch translucent vertical pink stripe down the left hand side. Rest of image is perfect. Any idea how to make this go...
Check the RGB settings from the monitor panel.... Plus try moving the neck of the monitor left and right a couple of times.... Sometimes, the picture tube displays illegitimate pictures with some twisted cables or so...
Jan 09, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Mag Innovision LT917s 19 inch monitor- On and Off !!
Replace it.  It would probably cost more to get it repaired.
May 28, 2009 | Mag Innovision LT917S 19 inch Monitor
Entire image shifted
Press the Select/Auto button. The monitor will then automatically adjust to match the incoming signal and will save that setting in the internal memory of the monitor.
Nov 06, 2008 | Hyundai L90D+ 19" LCD Monitor
2 inch black on both sides of the monitor (Horizontal)
Hi Bj, Is it an aftermarket video-card? If it is, like ATI or Nvidia, Download the recent drivers for your particular card, Uninstall your Videocard from device manager, then install the software.
CoDoc
Dec 10, 2007 | Dell Dimension 4600 PC Desktop
1 it is due to horizntal output trnansistor. 2 capacitor connected to horz output. 3 flyback transformer. hope this will help you.
Oct 08, 2007 | Hansol (720ESB) (Black, Silver) 17 in.CRT...
Blurring of images and text
mt, the 6 to 8 lines you were seeing were most likley the prelude to the end of the monitor. If the problem only occurs when the screen saver comes on then I could say the driver maybe being corrupted by a certain screensaver picture or program. When the monitor warms up to a certain temprature the electronics start to fail. You may want to turn off the monitor while your not right in front of it to cool it down and prolong its use.
Jan 27, 2007 | LaCie Electron 22" CRT Monitor
Hansol 730E CRT monitor
REPLACE THE BOOSTER C 5,6nF-1600V
Oct 18, 2006 | Hansol 730E 17" CRT Monitor
LG W2353V-PF 23'  LCD Monitor Logo
533 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
