Question about Car Audio & Video
Receiver someone fixed a oil leak on my truck. when I got it back the word PROTECT appears on the screen.
  • nikolaswest Feb 10, 2009
    my kenwood is in da same spot. my owner manual says 2 make sure speakers wires r not grounding out. and if thats not it than it says to take it 2 a repair shop
  • 1,224 Answers
Need to reset code in sterio
pull out radio
look on side of radio
there should say something like security with letter next to it this should be your unlock code for radio
Posted on May 07, 2008
I have a2001 holden astra 4 cylinder 1.8 litre can i remove the oil pan without taking the motor out
If had someone replace the seals you should take it back to them and let them fix it.
You can remove the oil pan without taking the motor out, but it's a LOT easier to work on if you do. You will probably take 3 times longer by trying to leave it in the car vs. taking the motor out.
Mar 10, 2015 | Holden Cars & Trucks
Leak under distributer
The most common cause is the heater hose coming off the head, below and behind the distributer. Usually the distributer is leaking oil, which gets on the hose and damages it. If you don't fix the oil leak, which could be the distributer "o" ring, (inexpensive) or the distributer shaft seal, (expensive) cut a piece of the old hose and use it to protect the new hose from the oil.
Apr 12, 2014 | 1998 Honda Odyssey
Marantz receiver SR4023 has blinking stand-by linght and displays "protect" on and off
Turn OFF receiver dis-connect all speakers and turn it back ON if it dosent go to PROTECT then some of your speakers or cables are shorted and should be changed. If it goes into PROTECT with all speakers dis-connected try factory reset ,if the problem appears again then you should take your receiver to some service for a check up. :)
Jan 21, 2014 | Audio Players & Recorders
Camry csi 2000 oil leak between engine and transmission
Lots of Camrys do this.
The oil will typically leak from the rear main bearing seal between engine and transmission, but that will appear at the bottom of the joint line, and will not reach the exhaust. This leak is expensive to fix and is usually left as is.
A leak from the cam cover gasket can drip into the exhaust.
The other typical leak is from the distributor shaft o-ring seal. This appears at the top of the join line between engine and trans, and can blow back onto the exhaust.
Jan 03, 2014 | Toyota Cars & Trucks
Can someone please tell me how to fix my car. I have a 2001 Mishibishi montero sport with 121,200 miles. I recently had an oil change and drove 4 hours back to college and smelled a burning, I opened my...
Is it leaking oil or burning it i ask,as for a estimate of a repair then iam the wrong one here as iam in spain .Too know exactly whats wrong here i would need my gnarled old head under the bonnet with a cuppa in one hand ,ciggy in the other and kick it up the exhaust with my steel capped boots on .Now is theri blue smoke out the back or a puddle of oil underneath the engine then this would give me a better idea as to whats wrong
Dec 25, 2012 | Mitsubishi Montero Sport Cars & Trucks
Protect message comes on and my radio doesnt work.what should i do?
Firstly, are you able to remove the head unit from your dash?
Usually, when PROTECT appears, the unit has detected a short circuit (or overload) somewhere, and has shut down to prevent damage.
Problems in the wiring (e.g. loom or speaker wire) can often cause this condition.
I recommend you have someone remove the head and:
- check the fuse in the back of the head unit.
- disconnect one speaker wire, then turn unit on to see if Protect message comes up.
- do this with all speaker wires, until the unit operates without going into Protect mode.
If the above does not solve the problem, then you may need to decide whether repair is viable, or to replace.
Jul 12, 2011 | Kenwood KDC-MP142 Car CD/ MP3 Player
Hi. I just bought a micra 2003 with 66,000 miles, but have had a tensioner on the timing chain fixed and an oil seal nearby fixed. I took it back to Charles Hurst and they spotted 2 more oil leaks one...
Hard to say, it depends on how trustworthy you think they are. From what you say, it appears to be oil seals leaking, you can take a chance and add a Wynn's product to you oil that swells and softens oil seals and stops them leaking. It would be a lot cheaper than a day in the shop and could fix the problem.
Mar 02, 2011 | Nissan Versa Cars & Trucks
Oil leak from black vent on top of crowncase wheel housing
its possible if someone overfilled the gearbox with gear oil.
Mar 31, 2010 | 1999 BMW R 850 R
Lots of oil leaking how many seals are there that could leak and is it a big job to fix. the leak appears to be on the back drivers side of the engine, it is a 1999 mazda protege 4 cylinder
you need to clean the engine off and fill it with oil,put your car on a hoist to find the oil leak when it starts so it doesn't run to other places and you think its leaking there.
Dec 18, 2009 | 1999 Mazda Protege
Car Audio & Video Logo
117 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
