Question about NorStar M7310 Corded Phone
Inactive Feature Our office had a power outage and now our phones are not working properly. We are able to make and receive calls but we can't check our voicemail. When we do check our voicemail it says that it is an inactive feature. Also when we receive calls all the phones ring when only one phone is suppose to ring. When we try calling the other extensions on intercom it rings but the voicemail doesn't work. Please HELP.
The system lost programming. Call a vendor in...
Posted on May 09, 2008
  • 3 Answers
Disconnect the main unit and plug it back then wait 10 min.
Posted on May 19, 2010
Locked out of Nortel t7316 every time you press feature and #983 or 985 it displays inactive feature.
F983 and F985 are voice mail access feature codes. Try rebooting your voice mail system to see if the unit recovers. There is no switch so you will need to unplug the power to the VMS to reboot.
Jun 29, 2015 | Nortel Lands Phones
Inactive feature message displayed when we try to access any features on our M7310 phones. This occurred after a power outage.
Dear customer..here is the solution
Sometimes when you put a new (or alternate) voicemail system on a Norstar switch, The feature codes that accessed the old system stay in the KSU memory. If this is the case all of your feature codes will appear inactive even if the voicemail system is operating correctly.
To fix this issue you need to run an External Feature test (XFtest) to identify and remove the leftover codes from your KSU memory. You must have a programming set to access this menu (M7310, M7324, T7316).
Power down the Voicemail unit. Remove connection to voicemail ports from KSU.
1. Press [Feature] **938378 (XFtest). The password will be 266344 (Config).
2. Your display will read Feat code: and you will have options First and Exit.
3. Press First. The first stored feature code will appear, and you will have options Test, Back, and Next.
4. Press Test. Your options will read Remove and OK. Press Remove.
5. Once the feature code is removed, press Next to go to the next code.
6. Do this with all codes until your display reads None Registered
7. Release
Restore connections to the voicemail ports from the KSU. Power the system back up.
The feature codes will be restored to the correct defaults with the completion of the voicemail power-up cycle.
thank u
Jul 09, 2008 | NorStar Lands Phones
Messaging is inactive on all lines after push functions button and enter 981
Hi. Inactive feature often means that there's a problem with your connection to the call pilot. Do you have lights on your call pilot? Did you assign a mailbox to the extension you're working on? Did you remember to connect the call pilot to a station port?
Jun 11, 2015 | Nortel T7316E 2-Line Corded Phone
Admin nortel i can't access the adminstrative programming. i enter feature 983 and it says "inactive feature". how can i fix it to where i can set up a new mailbox?
If you are getting inactive feature when entering feature 983 the phone system and voice mail unit are not communicating. This usually requires a power reset to clear. Or the voice mail unit is in trouble and a vendor needs to be called.
Aug 12, 2013 | NorStar T7316E Corded Phone
Feature Button
Sounds like the voicemail either is disconnected from the phone system or has lost power to the voicemail.Open the cover to the voicemail and see if there are any lights on in the system.If so then disconnect the power tho the voicemail for about 30 seconds. the voicemail could take up to 10 minutes to fully reboot.
Feb 26, 2010 | NorStar Meridian M7310 Phone
Hi there, Feature 983 gives me inactive feature message, can't forward calls, voice mail not working, etc. We had a short power outage the night before these symptoms began. Do I need to turn the power off...
Cycle the power on the voicemail system and that should solve the problem. If you still get the "Feature inactive" message, you may have to replace the voicemail power supply or get the voicemail system repaired.
Good Luck!
Dec 21, 2009 | NorStar Cics 6.1 & Call Pilot 100...
Feature 981 is displayed as an inactive feature and not available
Try powering off the voicemail system and and then power it on again. I've had it happen many times that after a power failure they just don't boot up correctly.
Jul 06, 2009 | NorStar Startalk Flash 2 Phone
Individual phone disabled after power outage
It sounds like the phone lost its programming of feature buttons. To reprogram them, press "Feature (star) 3" press the button to be programmed, and enter the feature code for the feature to be programmed:
Transfer -- Feature 70
Call Fwd (to mailbox) -- Feature 984
Call Fwd (to another ext.) -- Feature 4
Transfer caller to mailbox -- Feature 986
Page (general) -- Feature 60
Hope this helps!
Jan 30, 2009 | NorStar MICS v.6.1 w/ CallPilot 150 (48...
Inactive features
Is the phone system working but the voicemail did not come back up ? Can you tell me what kind of voicemail you have, ist should be marked on the voicemail system ?
Aug 01, 2008 | Lands Phones
Voicemail
If the feature codes show as inactive, the phone system is not seeing the voicemail. Hopefully this has been fixed by now, but you may need to call in a Vendor.
Apr 15, 2008 | NorStar Meridian M7310 Phone
NorStar M7310 Corded Phone Logo
756 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Computer Repairing
Computer Repairing
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
