Question about Hotpoint NVL333EY Electric Dryer
My dryer strats but doesn't keep running? - Hotpoint NVL333EY Electric Dryer
  • Hotpoint Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Posted on Aug 29, 2010
Cranks but will not start
my 1997 oldsmobile bravado cranks but don,t strat some times will strat and then one week cranks and don,t strat agine and its keeps doing this help me plaese
Jan 02, 2014 | Infiniti I35 Cars & Trucks
I have a Kenmore 90 series dryer, and I have power to the 220/240 plug then when I open the door the light doesn't come on or the dryer doesn't run. I'm not sure where to look next, I don't...
Make sure both sides of the receptacle has 110 volts. Take meter and keep prong in ground slot and then put red prong in the others. You should have 110 volts in each one. If not change receptacle.
Sep 11, 2017 | Dryers
My Maytag gas dryer, Model No, LDG7500AAW will run but not heat. The igniter glows red, but the gas will not flow. What might be wrong?
Replace the 2 burner coils ,if the igniter keeps cycling trying to start the flame. If it doesn't replace the flame sensor mounted on the side of the burner tube.
Nov 06, 2012 | Dryers
My Kenmore series 90 Gas dryer doesn't heat up.
This dryer is what I like to call a 4 wheel drive model. Because it has wheels on the front as well as the back. To access the gas assembly you pop open the bottom panel. Strat the dryer and observe the gas assembly. You should hear a click and then the ignitor should glow. Next the flame sensor should trip and cause the ignitor to shut down. The gas will now be allowed to come out and fire off a blast.I have 2 home videos. on shows the operation and replacement of the coils. The other is of an electric model but shows how to put the dryer together.
Sep 21, 2012 | Kenmore 73052 Gas Dryer
Pf keeps coming up wont run
if you haven't tried this,unplug the power or shut the circuit breaker off for 15 minutes,this may reset the defaults on the unit,if this doesn't help,then shut off power to the unit and open up unit and disconnect each and every connector to check for poor conduction,then reconnect power,if this doesn't help then replace the c.c.u. central control unit
Apr 20, 2012 | Kenmore Elite Oasis 6809 Electric Dryer
Replaced starter button and it worked for awhile. Now it doesn't. If I keep it pressed, dryer runs. If I release, it stops. wedged screwdriver beneath button and that works
The bad news is your switch spring isn't working or is broken. The good news is that you already know how to replace the switch.
Sep 04, 2011 | LG DLE2532W Electric Dryer
Engine strats,runs for thirty seconds shuts down and wont restart
Fuel pump is bad. It still runs enough to get gas to the engine, but doesn't put out the pressure to keep it running. Replace the fuel filter with it.
Mar 08, 2011 | 2000 Chrysler Town & Country
Push the button to start dryer and if you hold it in it will run, as soon as you let go of the button it stops.
The centrifugal start switch on the end of the motor shaft is stuck, has burned contacts or, has a broken spring.
Sometimes just lubricating and/or cleaning contacts will fix it.
If you need to know how to access the motor, please let me know.
Charlie
Sep 01, 2009 | Dryers
Hotpoint NVL333EY Electric Dryer Logo
66 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
