Question about Technics SUV500 2-Channel Amplifier
Volume turn up switch just goes on to 82 theres not much sound but it was working great
    Genius:
  • 1,175 Answers
Main volume control either needs to be re-soldered or replaced
Posted on Sep 01, 2010
My 82 750 Nighthawk and the headlight does not work before and after it starts
First, test for voltage at the plug that attaches to the headlight, if you have voltage at each terminal when set to it's respective hi or low position it could only be your headlight. If you don't have voltage then you need to work back from the wire to the switch and etc etc
Apr 19, 2014 | 1993 Honda CB 750 Nighthawk
Volume control
Poltergeist in volume circuit is the diagnosis. Try a hard reset of the receiver to see if that does the trick with the electronics.
Sep 01, 2017 | Mitsubishi WD-82737 82" DLP TV
Sound goes up and down
Sounds like a dry joint or a capacitor has broken down, you will need to take back off and check, just remember there is 240volts in the PSU of the system.
Jan 27, 2012 | LG 42LD520 42 in. HD-Ready LCD TV
I have a 32 inch toshiba t.v and my volume randomly comes on as zero, and If i turn it up it goes back to zero. When the volume is on the t.v I cannot turn the t.v off or change any of the chanels I can...
I would start at the front panel switches. It sounds as if one is sticking internally. If it is not a switch it would be a microprocessor problem. www.encompassparts.com has the switches. Part number 23344507. Unless you are good with a solder iron best leave this one to a pro. Thanks
Oct 28, 2009 | Toshiba 32A32 32" TV
Volume fade
Check to be sure there are no speaker wires touching ground, and that the wires are connected in phase to the head unit.
Front Speakers 5 1/4" Doors Left Front (+) Green Left Front (-) Black/White Right Front (+) White/Red Right Front (-) Black/White Rear Speakers 6" x 9" Rear Deck Left Rear (+) Pink/Red Left Rear (-) Pink/Blue Right Rear (+) Pink/Light Blue Right Rear (-) Green/Red
The symptoms you are relaying definately sound like an internal amplifier problem. It is fading in and out for a reason - usually due to heat.
Have you had the radio bench tested (seperate from the car) to eliminate the car as being the culprit?
Since the radio was run with damaged speakers originally, the output or amplifier power supply on the amplifier may be bad.
As an alternative to repairing, I would suggest investing in a small 2 channel amplifier to power the speakers.
The radios claim 50W per channel, but in reality give 12-15W RMS power.
A dedicated amplifier with built in crossovers and gain adjustments will prolong the life of your speakers and add to the tonal qualities of your new speakers. Instead of turning up the volume on the head Unit, and sending out a distorted signal that will blow your speakers, an amplifier will give more CLEAN power to them, so it will be louder at a lower volume setting.
This will bypass the internal amplifier on the radio, and send a Low Level signal ONLY thru a set of RCA cables.
Good Luck!!
Jan 10, 2009 | Car Audio & Video
Car Audio Fade
sounds like you got a bad stereo. it happens. i've i had the same thing happen, but the volume went up instead of down. check all the wires and make SURE they are all hooked up right.
Jan 10, 2009 | 2000 Jaguar Vanden Plas
VOLUME ISSUE
I had my older bose 321 hooked up through vcr and sounded great. Then hooked it up through directv receiver and sounded better. then switched from direct to comcast and hooked the bose up throught the comcast hd receiver and the volume is aweful. same deal, have to crank it up high. Since the stereo built into the tv sounds so much better I disconnected the bose and am going to sell it.
Dec 28, 2007 | Bose 3 2 1 GSX System
Disappearing sound, Low sound, no sound
Unplug the system from the wall and plug in again...It worked for me...hope it works for you too.
Aug 18, 2007 | Bose 3 2 1 GSX System
Technics SUV500 2-Channel Amplifier Logo
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
