Question about Gaggia Syncrony Compact Coffee Maker/Espresso Machine
There is no water coming out of the machine at all. No error light come on but when you go to make a coffee with beans or pre ground it goes through the process but just dry coffee comes out. Also no water or steam comes out the dispenser yet all the lights indicate things are working
    President:
  • 1,618 Answers
For the steam check the end of the nozzle to make sure it is not blocked.
For the coffee run a coffee using the pre ground method but without coffee grounds, if water comes out then grinder is too fine, if no water remove brew unit and clean top shower screen, you might have to clean tube leaving from shower to discharge.
Posted on Sep 01, 2010
Why does no brewed coffee comes out? bypass preground does work
- coffee-channel is stuck.
check google for calibrating/cleaning your gaggia.
Aug 27, 2014 | Gaggia Titanium Espresso Machine
The problem is when I use pre ground coffee beans. The water doesn't run through. It comes over the top and the grounds get in the coffee. I buy them that way because they mark them down half price. I
There are whole coffee beans, and there are ground coffee beans, but there is no such thing as "pre-ground" coffee beans because you wouldn't want the beans to be ground AFTER making coffee.
If you have a problem using "pre-ground" beans, then STOP using pre-ground beans and grind them yourself.
I hope this helps.
Randy
Dec 01, 2012 | Coffee Makers & Espresso Machines
Dispensing Failed- Saeco Talea Ring Plus
Try adjusting the grind four numbers coarser and brew a coffee, if you are getting the same result then the brew unit is clogged and the screen needs to be cleaned.
Jun 20, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
Fill beans message keeps coming up on jura capresso impressa s9
You need to open the grinder, it`s probably packed with old fine powdered coffee that blocks the outlet. Clean this out and try again. Since it works normal when you use pre-ground coffee, there shouldn`t be any problems with any other parts.
Let me know if you want a description for have to open and clean the grinder.
Jun 01, 2009 | Jura Capresso Impressa S9 Coffee...
V'spresso problem
There is a sensor in there that detects when there is coffee beans in it.
When the sensor is not engaged, it thinks there is no beans.
I would suggest a more thorough clean of the are that the sensor is likely to be.
Worst case, empty the machine of water and coffee, tip it upside down on an old towel or something, and play a light bongo-drum on the base of it, then try cleaning in where the coffee goes with high pressure air.
Should fix it, let us know, hope this helps.
Apr 26, 2009 | Saeco V-spresso Espresso Machine
Magic Comfort machine won't make one cup of decaf coffee
Make sure to use pre-ground coffee only (MEDIUM
ground) and not soluble coffee.
Question- check to see where the coffee is going- did it end up in the brew group- but you did not get coffee? Then, the filter is clogged. Clean the filter. If you have used oily beans, they can clog filter easily.
Jun 19, 2008 | Coffee Makers & Espresso Machines
Coffee Grinder not working
the grinder is most likely stripped and needs to be replaced:-{
Jul 23, 2006 | Saeco Caffe Charisma Espresso Machine
Gaggia Syncrony Compact Coffee Maker/Espresso Machine Logo
604 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
