Question about Toshiba NB205-N210 Netbook
When I turn my netbook on, its say press F2 for setup and F12 for boot device selection menu but when i press either, nothing happens. (Its stuck at this menu and will not power up)
  • 707 Answers
You can try checking RAM modules to see if properly seated. If are then its probably a shot motherboard. Quite common unfortunately.
Good luck
Posted on Oct 18, 2010
2 Suggested Answers
  • 25 Answers
SOURCE: missing or corrupt file on
depending on the model, sometimes F11 is the OS recovery key for Toshibas, it's possible your hard drive could be going bad. if the laptop is under warranty I recommend contacting Toshiba. If out of warranty it's best to take the laptop to a local computer shop.
Posted on May 03, 2011
Got an Acer 4050 from ebay and it goes straight to enter boot password
can you click on f12 before it goes to boot password?
The F12 Boot Menu allows you to choose which device that you would like to boot the computer's Operating System from by pressing the F12 key during the computer's Power On Self Test, or POST process. Some notebook and netbook models have the F12 Boot Menu disabled by default.
If this sounds like your problem then try this:
If this sounds like
To enable the F12 Boot Menu:
  1. Restart the computer.
  2. Press the F2 key to enter computer's BIOS Setup during Power-On Self-Test, or POST, process while the Acer logo is being displayed.
  3. Press the Right Arrow key to select Main
  4. Select F12 Boot Menu
  5. Press the Enter key
  6. Select Enabled
  7. Press the Enter key
  8. Press the F10 key and then press the Enter key to save the changes and restart the computer.
Note: Not all Acer notebooks or netbooks have the F12 Boot Menu feature. Computers that do not have the F12 Boot Menu feature will not be able to enable the feature within the BIOS. I hope this works for you if not, then the problem is obviously not the boot menu. Go to Acer support for more help
Aug 30, 2014 | Computers & Internet
How do I know if my boot ste up is correct
If your PC doesn't boot up using the hard drive, you can check that by looking for the F2 or F12 displayed on the screen during boot up. Then start pressing F2 or F12 quickly to get setup.
In setup follow the directions and set your "boot device" to "hard drive"
Hope this is what you needed.
Feb 15, 2012 | Dell Inspiron 531 Athlon 64 X2 4400+...
How can i boot my dell studio from cdrom so i can reinsall from external drive?
Turn on the machine, press F12 once the Dell splash screen is displayed, the boot menu will show up. From the Boot Menu, use up-down arrow keys on the keyboard and highlight the CD/DVD/CD-RW and press Enter.You will see another menu, select "Boot from Cd-Rom" and press enter to select it. The system will boot up from the CD-Rom. Please note that this settings is only for one time boot, once the system is restarted, the boot sequence will be restored to the previous saved settings. If you wish to set it from the Bios, enter the Bios settings by hitting F2 or Delete (should be shown at the bottom of the Dell splash screen) while you see the Dell Splash Screen. In the Bios settings menu, go to Boot options and make the changes with the boot sequence.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
May 21, 2011 | Computers & Internet
How do I access the screen that shows BIOS options as I wish to upload UBUNTU 11.04 from a pendrive, so I want to make my first and possibly second BIOS options to be for the pendrive.
At boot time repeatedly pressing either, F2 , F12, or possibly Fn+F1 this is depending upon the bios wether it has been updated or upgraded. One of these should do the trick.....
May 15, 2011 | Dell Latitude CPI-A Notebook
When I power on my Toshiba laptop is tells me to press f2 for SETUP, Press f12 for boot device selection menu. But am not sure what to do after I get on either screen
the one you press are the setup for bios settings..in the boot menu,you will select which is your priority to be your first boot,2nd and 3rd..the first boot you choice will be the one boot first..highlight the boot selection then navigate your choice..if you are going to boot it first from cd drive then select cd-rom,and if you to boot your drive which contains your system,then select hard drive as first boot..
Feb 15, 2011 | Computers & Internet
What is the boot up sequence please
You need to go inside BIOS to find out whats the boot sequence. To activate the BIOS Utility, press F2 during POST (when “Press <F2> to enter Setup” message is prompted on the bottom of screen).
Press F2 to enter setup. The default parameter of F12 Boot Menu is set to “disabled”. If you want to change boot device without entering BIOS Setup Utility, please set the parameter to “enabled”.
Press <F12> during POST to enter multi-boot menu. In this menu, user can change boot device without entering BIOS SETUP Utility. Navigate to BOOT page on top.
Hope this helps!
Aug 22, 2010 | Acer Aspire 5535-5050 Notebook
I have an Acer Aspire One notebook. I cant seem to start it. I turn it on and this displays : Check cable connection..! PXE-E63 : Error while initializing the NIC PXE-M0F : Exiting Intel PXE ROM. No...
It happens when no boot device is selected, the default is network boot first, you must select CDROM/DVDROM or HD as your first startup device. boot up machine and enter bios setup think its F2 key to enter bios generally it del or f1 or f2 it may say onscreen at start if f2 doesnt work
in the bios set boot order to HD as firstboot option then save and exit
hope this helps
dont know if all acers do this but also if you press f12 on boot up it gives you current boot options select HD that way is current boot and would have to be done everytime
Nov 06, 2009 | Acer Aspire One Netbook 8.9" Notebook
My laptop freezes on the main start screen
enter to bios set up then disable the f1 and f2
May 01, 2009 | Computers & Internet
Can not Boot from OnBoard SATA Hard drive.....it keeping looping...
Turn on (or restart) your computer.
When F2 = Setup, F12 = Boot Menu appears in the upper-right corner of the screen, press <F12>.
The Boot Device Menu appears, listing all available boot devices. Each device has a number next to it.
At the bottom of the menu, enter the number of the device that is to be used for the current boot only.
If this works and you want to change the setting permanently do the following:
When F2 = Setup, F12 = Boot Menu appears in the upper-right corner of the screen, press <F2>.
Use the arrow keys to highlight the Boot Sequence menu option and press <Enter> to access the menu.
NOTE: Write down your current boot sequence in case you want to restore it.
Press the up- and down-arrow keys to move through the list of devices.
Press the spacebar to enable or disable a device (enabled devices have a checkmark).
Press plus (+) or minus (–) to move a selected device up or down the list.
Feb 17, 2008 | Dell Dimension 4700 PC Desktop
Toshiba NB205-N210 Netbook Logo
149 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
