Question about Windchaser 18 in. Stand Fan
Windchaser NSR181 Remote fan stopped working. The fan motor doesn't seem to kick on but it appears to get power.
spurs21
  • 26 Answers
SOURCE: Windchaser remote control fan
How about this web site address it may help you locate the information you need. http://www.windchaserproducts.com/website/customer.htm Good Luck, Spurs21
Posted on Jun 21, 2007
SOURCE: windchaser 10000 btu air conditioner
blowing good but not cooling
Posted on May 01, 2008
  • 15 Answers
SOURCE: Remote stopped working, fan and light do not
click the reset and turn off the fuse box and then turn on
Posted on Feb 15, 2010
  • 588 Answers
SOURCE: Compressor appears to kick in, runs for short time
It sounds like your unit may have a bad run capacitor or start capacitor and relay. Low voltage will also cause this problem. First you need to make sure that you have the full rated voltages at the unit, if you do, then, have the run and start capacitors checked out and the start relay.
Posted on Jun 01, 2010
heatman101
  • 43501 Answers
SOURCE: The fan motor makes a noise but doesn not start
The motor probably is not starting because the bearings are a bit stiff....
Take the hood apart and give it a good cleaning, being careful to not get the motor wet...
Then if you can get the hood in a position to run some light motor oil down the shaft and into the motor... spin the shaft as you do this... get oil worked into the motor bearings then it will probably work again...
heatman101
Posted on Jan 17, 2011
Looking for replacement parts for Windchaser fan
You can take plumbers tape and wrap about 5 to 8 turns around the shaft threads and put blade on and cap. (Plumbers tape is white plastic tape on a roll with a pop off cap like medical tape comes in)
Remote? Maybe batteries.
Mar 15, 2015 | Windchaser Dryers
Remote
how to use windchaser w/o remote?
Oct 04, 2012 | Windchaser (WC163C) Stand (Pedestal) Fan
Wind chaser fan motor not working
Hard to find parts. Could contact manufacturer, but might not be cost effective.
Sep 21, 2012 | Windchaser Ionizer Tower Fan with Remote...
Stuck on standby
windchaser upright fan stuck on standby,no remote how to work without remote?
Aug 09, 2012 | Windchaser FTR163 SensorFan Stand...
I have windchaser misting fan for a year, worked all last summer, was stored in my garage for winter and when i plug it in this year. it will not turn on
Turn it on and try and spin the blades by hand or use a pen or something to give them a kick start. If it works then, you can bet the motor needs to be taken apart, cleaned, and oiled.
Jul 02, 2011 | Windchaser Dryers
Feb 15, 2010 | Casablanca Fan 3245T Ceiling
Humming noise from motor of oscillating fan.
Wd-40 is not a very good lubricant. It only lasts fror a few days and then dries up again. In order to get your fan working again, take some 3-in one oil and put a drop at the bearing side of each bearing top and bottom with the shaft upright. Spuin and tap the motor briskly with a small tack hammer or screw driver handle. This will impact and allow the oil to get into the bearings Keep tapping and turning until you feel it lighten up a spin freely. Turn it over and do the same thing again. I garuntee that all will be fine after this.
Sep 07, 2009 | Windchaser 3-way Oscillating Fan
My Windchaser fan model FTR184 does not work anymore - it did yesterday. The oscillator function still works but the fan doesn't come on. The red light indicating standby mode is lit. How do I get it out...
I have a Windchaser fan mode FTR184 also and it is in the same indicator STANDBY mode and now it will not come on and we have the remote, how do you fix this?
Jun 27, 2009 | Windchaser FTR163 SensorFan Stand...
Dryers Logo
65 people viewed this question
Top Windchaser Dryers Experts
Ian Summerfield
Ian Summerfield
john h
Vernon Taylor
Are you a Windchaser Dryer Expert? Answer questions, earn points and help others
