Question about National Geographic NG70CA (225 x 70mm) Telescope
How do i use the peice that hooks up to your laptop?
  • 3,186 Answers
This is NOT a computer controlled scope--
http://www99.shopping.com/xPO-National-Geographic-National-Geographic-70mm-Compact-AZ-Refractor-w-table-top-tripod-
You probably have some kind of CD disk that has a planetarium program on it.
Here is a review of the telescope.
http://www99.epinions.com/reviews/pr-National_Geographic_NG70CA_Telescope
Posted on Aug 29, 2010
Is the aspire 5517 power inlet two peices or one peice connected to the motherboad
2 if you are referring to the power cord. 1st piece with an adapter that connects to laptop. 2nd piece is just an extension cord.
Sep 30, 2012 | Acer Aspire 5517 Laptop
Can I hook up my saltwater system to the 16 foot pro-series that has the filter mounted to the sidewall of the pool
you can go to ace hardware or true value and spend under ten dollars. you need a 1 1/4" to 1 1/2" flex drain & trap con.[ it is rubber and has two hose clamps on it] and a white pvc reducer 1 1/2" to 1" and a small peice of 1" pvc. you hook the 1 1/4" side to your pool pump then the pvc reducer into the1 1/2' side then you glue the 1'pvc [about a 5" peice] into the reducer the other end of the 1'' will go into the adapter it fits tight but it will go now you are ready to go
May 16, 2012 | Pool & Spa
Need to get carpet out of the way to replace rear blinker bulb.
these hooks will twist out, there may be two for the bottom also. These may be a little hard to twist, but a small pair of pliers should help.
Mar 25, 2010 | 1997 Chevrolet Cavalier
Replacing interior door handles on 98 Sierra
on the inside of the trim peice take a flathead screwdriver and gently work around the inside of the trim peice and if you find the right spots were the clips are it will just pop off.
Jan 14, 2010 | 1998 GMC Sierra
1998 exteriour door handle does nothing when lifted
take the inside pannel off of your door...up where your door handle is you should see something that looks like a hook loop ... this will be on the door handle assy itself .... now there should also be a peice of metal that is long and the end is in the shape of an L or U... hook the metal into the hook on the door handle and it should fix the problem...
Aug 30, 2009 | 1997 Toyota Camry
How do you pop off the top of the dryer?..is it bolted in any way
Hello.
Reomve the door from the unit and the plastic peices from the other side in the same spot as the hinges. Remove the front panel. You will see one metal peice on each side that hooks the top on. Remove the screws and the metal hooks. The top will lift up now.
Jul 22, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Broken earhook
sadly there is no replacement part for this, you can only use a super glue that you can buy in home depot to fix this, just a small amount and let it dry
Aug 08, 2008 | Jabra BT125 Headset
Fell apart..help please!!!
The larger white pieice that has holes in it should be connected between both the spring and the smaller razor, The bottom of the larger white peice has to be able to fit in the peice of medal that moves in a circular motion inside the top part.
First, Try to make the hooks of the spring go in pretty securly inside the small holes. The flat side of the white peice has to be connected to the flat side of the smaller razor. They should kinda snap together on the top hole. I had to gently place the parts together and push the larger white peice in the medal by placeing the larger razor peice right on top and pressing down really hard. You might hear some snapping but the peices should all connect together and the large medal peice should connect to the black groves and press hard. Hold in place while putting the screws back in.
Jun 21, 2008 | Conair GMT182CS
National Geographic NG70CA (225 x 70mm) Telescope Logo
365 people viewed this question
Top National Geographic Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Greg Cann
Greg Cann
Tom Chichester
Are you a National Geographic Optic Expert? Answer questions, earn points and help others
