Question about Ingersoll Rand Type 30 Reciprocating Air Compressor 5 Hp, 80 Gallon, 230 Volt 3 Phase, Model# 2340N5
1 month old compressor has oil in tank - Ingersoll Rand Type 30 Reciprocating Air Compressor 5 Hp, 80 Gallon, 230 Volt 3 Phase, Model# 2340N5
    Novelist:
  • 214 Answers
The piston rings may have not seated allowing oil to get by. The oil is then carried to the tank with the air. After enough run time and cycles they should seat. If not and this is a new unit I would call the 800 # on the unit and talk to customer service at IR.
Posted on Feb 05, 2011
I have a Ridgid 5 gallon stackable air compressor that when I shut the compressor off, all the air discharges from the tanks. Do you know what the problem is?
You don't say how old this unit is. I had an older one and it had a small rust hole in it's tank. Had to get rid of it because the tank was rusted bad on the inside. Also check all the lines as they could be leaking as well. Also the one I have now leaked air because the compressor was low on oil. I got compressor oil and its ok now. Do not over fill as it will blow oil all over.
Dec 05, 2017 | Ridgid Air Tools & Compressors
How many liters of compredssor oil to fill tha compressor tank
I don't know which model of air compressor you own, some models require no oil whatsoever. The important thing to remember is that you should never put oil inside the tank. While it probably won't damage the compressor and may, in fact, be good for air tools, oil does not belong in the tank. The tank itself should contain clean, dry, air ONLY. Depending on the job you're performing, oil and water in the air tank will ruin your hard work, especially if you are spray painting. The air compressor motor does require oil (unless, again, it's oilless), just fill it through the oil filler hole until it barely starts to leak out. You can change the oil every year if you use your air compressor professionally. Most people who use their compressor only occasionally never change their oil or even check the level. My compressor is a 20 year old Campbell Hausfield with the original oil. I don't recommend that, just stating the facts...I do religiously drain the water out of the tank with the drain valve, and I have replaced the drive belt. Once.
Feb 25, 2015 | Air Tools & Compressors
What compressor oil do i need for my puma air compressor
Any name brand compressor oil will be fine, just make sure to drain the old first, and then refill
May 30, 2014 | Puma Air Air Compressors Puma Air PUK5520G...
What grade of oil do air compessors use
iso 32 // 30wt. compressor oil, or no additive mineral oil, never use automotive oil in a air compressor
May 06, 2014 | Eagle C5160v1 - Single Stage - 5hp 60...
I have a 1.8 HP, 25 gallon compressor. There is oil in the air tank
Just drain it out, an air tank should be drained every month or so. Do check the oil in the compressor to be sure that wasn't the source of the oil in the tank though, and if it's low change it out with proper compressor oil, it's available at all the home improvement chain stores.
lp
Dec 28, 2010 | Garden
OIL FILLED COMPRESSOR SEEMS TO FREEZE UP ???
Cold weather will freeze the water the compressor normally makes and this can prevent the motor from driving the compressor. Drain the tank and warm it up as needed......
Jan 10, 2010 | Craftsman Air Tools & Compressors
Need a guide on how to operate and maintain clark compressor.
easy buddy just every week check the oil level and weekly drain the tank by underneith the tank uis a vlave you turn this and water will come out and every 6 months change the air filter and to start pull the red/black switch up and dont worry about leaving air in the tank is doesnt matter good luck buddy any more info get back to me
Sep 13, 2009 | Clarke Power Products Inc AC2001 2HP 4...
Low psi while running continuously.
i am assuming this is an oil less compressor as I have never seen a crapsman compressor that is not
you need to feel around the head and see if there is air leaking anywhere usually around the tube that goes to the tank or the pressure relief valve
Apr 16, 2009 | Heating & Cooling
Ingersoll Rand Type 30 Reciprocating Air Compressor 5 Hp, 80 Gallon, 230 Volt 3 Phase, Model# 2340N5 Logo
52 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
