Question about Lite On LITEON 8X DVDRW +/- Burner
DVD disc door won't open. - Lite On LITEON 8X DVDRW +/- Burner
  • 320 Answers
Have you tried going to my computer right clicking on the drive and pick eject from the menu? if this doesnt open there is an emergency lock release on the from it is a very small hole in the face of the deck use a small paper clip or stiff piece of wire and insert it into the hole and push lightly this will release the door for you
Posted on Aug 29, 2010
Dell cd drive door won't open
CD/DVD Drive Tray problems
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
Feb 22, 2013 | Dell Studio XPS 8000 (DXCWKW12) PC Desktop
Door won;t open
I have a yellow light .on the front, and the disc tray won't
open. I have a cyberhome DVD player,CH-DVD 300.
Oct 28, 2012 | Cyberhome CH-DVD 300 DVD Player
Dvd door won't open
Someone is going to have to open the unit to see what is happening--either a disc is jammed inside or a mechanism problem.
Sometimes with unit apart you may be able to gently probe and free the jammed area--possible also something that does not belong there got inside--look closely.
Jun 16, 2012 | Daewoo DV6T-81N DVD Player / VCR Combo
Disc drive won't open
CD/DVD drive?
Some have a tiny hole, right under the tray that comes out. Use a paperclip in the hole to manually open the tray.
(Some desktop computer towers have a door in front, that needs to be eased open first, then access to the actual CD/DVD drive unit can be obtained)
Regards,
joecoolvette
Jun 02, 2012 | Dell Computers & Internet
GO VIDEO model 1030....VCR works fine...DVD..nothing happens...door won't even open?
Combo units have this essential flaw--if one half fails you are usually done especially if the DVD side fails.
If Door does not open either a disc is jammed inside the mechanism or the mechanism is out of alignment or damaged.
Good argument against buying these units--DVD individual parts are rarely sold--only (if available) would be the entire DVD unit itself--not cost effective to repair.
DVD players are now real cheap (see some for as little as $20) so if not a simple jammed disc or something like that buy a DVD player.
Apr 05, 2012 | GoVideo Go Video DVD/VCR Combo
Won't spin
Hello
The loading mechanism to your player is faulty. It doesn't engages the disc in to place perfectly. Replace the loading mechanism.
Mar 07, 2012 | Lite On LVW-1105HC DVD Recorder
CD DOOR WON'T OPEN
Just below the CD/DVD tray there is a tiny hole. Insert a straighten paper clip in this hole and gently push the paper clip until the CD/DVD tray pops out. You can now pull the tray out until it is in the fully opened position to remove the disc.
Try pushing the eject button to see if the tray closes, then push the eject button to see if the tray opens.
If this foes not work then the CD/DVD drive is faulty and it needs to be replaced.
Mar 06, 2012 | Dell Computers & Internet
Disc door won't open. DVD in will still play. How can we make the door open
try to re start the power first to reset the supply in which the door unable to open and then push the open/close button to open the door. if still won't open maybe their is an stuck up at mechanical part, so turn off the player then use a Phillip screw driver to loosen the screws and to remove the cover of the DVD player .you can now access the disc mechanical assembly of your DVD player, remove the CD first and then check if the plastic gear is mis aligned or the the drive belt is broken.much better if you can apply silicon grease in plastic gear for smooth operation.then make sure the open/close button is ok, good luck and good day.
May 03, 2011 | LG Televison & Video
Disc door will not open
hello,
the reason the disc door would not come out is because there is a problem withe the mechanism that opens the door.
to fix this,
1. you unscrew the dvd player,
2. take off the cover,
3. plug the dvd and press open to see if the door would open, then you will see where it is getting stuck,
4. replace the mechanism that is controlling the disc door, and press open to see if the door will open.
5. once it is able to open up, you can screw back the cover.
Jun 02, 2010 | Memorex MVD2040 DVD Player
The disc door frequently will not open and now it
One of the things you try for this , is to remove moisture that has collected in the machine, this could be due to it being in a cold room,or not used for sometime.
bring it into a warmer environment switch it on and leave for 2 hrs then retry your discs.
Also check the region on the dvd matches that on the discs.
Please see your manual for discs your dvd won`t play,also about finalising.
Oct 20, 2009 | Televison & Video
Computers & Internet Logo
60 people viewed this question
Top Lite On Computers & Internet Experts
John Anderson
John Anderson
Rommel Balcita
Michael Vanidestine
Michael Vanidestine
Level 1 Expert
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
