Question about Hotpoint Dryers
I have a hotpoint dryer that has a fire wire plug connected to it. The house i have now has a three prong receptacle on the wall. Can i just buy a three prong receptacle and tape off the extra red wire.
  • Hotpoint Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Posted on Sep 12, 2010
Three prong to 4 prong outlet
Yes it can be. I suggest you get a licensed electrician to handle it.
Jan 27, 2013 | Bosch Nexxt 500 Dryer
I have an Electrolux dryer with a four prong cord, and have moved to a house with a three prong receptacle. The dryer appears to have an integrated grounding strap connecting the frame to the center...
Connect the three-prong wire you have the way the same wires (Line 1, Neutral, and Line 2) of the four-prong wires are connected to the terminal block then connect the integrated grounding strap to the Neutral (center) terminal.
Jul 16, 2011 | Washing Machines
I have a 4 prong dryer but the plug in the wall is a three prong, ibought a four prong plug and i dont know how to connect a three wire into a four prong plug please help me.. hugo
Do NOT try and change the receptacle please. It is dangerous and we do not want anyone getting hurt. In your case, it would be better to put a 3 prong cord on the dryer. Overall you could call an electrician to install the 4 prong receptacle, which will require new 4 conductor wire as well and run to the breaker box. Get a flat style 3 prong dryer cord and we'll tell you how to install it. Unless you call an electrician. ;-) If this helps you, please rate my answer. Thank you.
Jan 07, 2010 | GE Dryers
Replacing eletrical cord to a four prong cord. there are only three connections. there are no color codes to make it easier. How do I replace the cord
Dryers are 220 Volts AC and the outer connections inside the dryer are "hot" or live legs (black or black and red wires) of the circuit, while the center one is typically the neutral (white) wire.
The difference between a 3 prong plug and receptacle and a 4 pronged one is simply that the 4 prong plug and receptacle has a dedicated ground integrated into it, whereas the 3 prong plug is what's commonly referred to as an ungrounded circuit. There is no dedicated ground in a 3 prong plug and receptacle that makes a separate, grounded connection from the dryer to the receptacle to the electrical panel of the house.
Also, please look at either the back of the dryer for a basic wiring diagram, or look inside the access panel where the dryer cord is connected. There should be indications as to what each terminal is for, as I stated, typically the outer connections are the "hot" while the center one is typically the neutral. If you notice a strap running from one of the dryer's connection terminals to the cabinet/frame of the dryer, that is the neutral. The others are the hot terminals, which are the outside ones.
Look for a green grounding screw inside the dryer's electrical connection section. That is where the green wire on the cordset would be connected/terminated.
If you wish, you can get a free Installation Guide for your dryer at the following link to download and/or print out at:
http://www.managemyhome.com/mmh/lis_pdf/INSTL/L0520950.pdf
It will show you the connections for both a 3 and 4 wire cordset.
Hope you find this Very Helpful and best regards!
Nov 29, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Installing a four prong plug
best bet would to be to buy a plug that matches your receptical.....this is somthing you do not want to monkey with as if not wired right could turn your dryer into a fire hazzard. white to white green to green black to black and the other wire goes to earth ground for like trailer houses and modular homes.
Nov 23, 2009 | Whirlpool Dryers
My 220 plug is a three prong and the used dryer I bought has four prongs. Is there some type of adaptor I can buy to connect the two plugs such as what used for adapting a 110 line that has two different...
Hello Doris, You really don't want to get an adpater for this, (even if you could find one - they're not at all common) since the thickness of adding in an adapter would make the dryer stick out further from the wall, etc.
What you need to do is to get a new "pigtail" for the dryer that has the three (3) prong plug that matches your 220 Volt-AC wall outlet. These are available at most Home Depot, Lowes, Sears, or at any appliance or Hardware store. They don't cost all that much and will provide you with the correct plug and cord set for your house's electric dryer outlet.
The four (4) prong cord & plug has a separate ground wire in them, while the standard thre (3) prong plug uses the netural as the ground, or has a separate green wire running from the dryer cabinet to either a grounding screw on the wal plate, or to a ground ******** a water pipe (typically found in older homes)
Just be sure to unplug the dryer before changing the cordset out for the 3 prong one. Make sure the power is also off at the breaker panel too. Now at the rear of the dryer there is a small access panel where the cordset goes into the dryer. Remove that panle and you'll see three (3) connections on the panel along with a Green Grounding connection.
The connectors that get the power are the outside connectors, these are "HOT" and get 120 V-AC each (120 x 2 = 240 Volts AC) while the connector in the middle is the NEUTRAL connection point.
The wiring is straightforward and there should be a simple wiring diagram either on the access panel or the connection points should be labeled for each of the wiring fasteners (screws or nuts)
Just be sure to get the fasteners tight, and the new 3 prong cordset you buy should be long enough to reach from the dryer (when it's pulled away from the wall) to the house outlet. Typically they come in either a 3-4 foot length or the longer ones are 5-6 feet long. If in doubt, get the longer cordset. You can also check the wrapper of the new cordset, as they provide a simple wiring diagram also, to help you install it correctly.
http://z.about.com/d/electrical/1/0/r/0/-/-/DryerElectricalConnection.jpg
Just be sure to add the included strain relief, as instructed, onto the cordset and put the access panel back on when you're done and you'll be all set to use that "new" used dryer!
I hope you find this Very Helpful and best regards!
Nov 16, 2009 | Maytag PYE2300AY Electric Dryer
Elkectric dryer won't start
to put it kindly depending on way you connected wires unit could be damaged,replace pigtail with three wire and outlet to original.outlet wires should be black,red and white. turn breaker off attach white to middle and red,black to sides,"either side is fine".Attach dryer pigtail in same manner with white on white and if plug in and turn breaker on.If there is no operation at this point dryer possibly damaged from previous wiring.Just remember be safe when working with electrical and ask before trying to change things that aren't the same.
Apr 20, 2009 | Whirlpool LER5636P Electric Dryer
Four prong plug to three prong plug
Is the receptacle in the wall a four prong or three prong. You will have to match the cord on the dryer to the wall recepticle. If the wall is four prong the dryer cord has to be a four prong. The green wire with the yellow line, that is on the end of the dryer cord, is a cabinet ground and should be attached to the cabinet of the dryer and making good contact. The other three wires on the end of the dyrer cord attach to the terminal block.
Jul 08, 2008 | Whirlpool GEW9200L Electric Dryer
Dryers Logo
70 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
