Question about Compaq Keyboard
The keyboard completely stopped working. Unable to type at all...any suggestions? I have disconnected and reconnected the keyboard and restarted the computer.
    Sergeant:
  • 235 Answers
Turn off the computer, disconnect and reconnect the keyboard, restart your computer. If that does not work, try a different keyboard. If that still does not work than try a usb keyboard instead of a ps/2 keyboard or vice-vers. Good luck and let me know how it goes.
Posted on Aug 29, 2010
Brither printer MFC 210c unable to clean
disconnect power
press and hold menu
reconnect power cord
power up the printer
when all lights are flashing, release the menu button
type 80
press start black until PURGE:xxxx appears on the screen
if the number after purge is greater than 6000, type CRUD (2 then 7 then 8 then 3)
it should now read purge:0000
press stop
type 99
restart the printer.
If this works, you will need to purchase an ink purge kit, or you risk the purge tank overflowing eventually.
Apr 09, 2011 | Office Equipment & Supplies
Laptop top keyboard will not function appropriately unless Dynex separate keyboard is used. I am unable to identify the Dynex device to uninstall. First listed states Std 101/102 Keyboard and the other HID...
Hi, these instructions will help you, first, click on the "Start" button, in the "Start Search Window, Type: keyboard; the "Keyboard's" Properties window will open. You can (Test) to see exactly how your keyboard is responding. if you are still having the same problem, (check the Keyboard Status), try "Updating the Drivers," by clicking on the "Properties" button. Now in the event that neither of these solutions solve the problem, which I hope you shouldn't have to do anymore; try "Uninstalling the Keyboard. To "Uninstall the "keyboard," do the following. Shut-down (turn- off completely), disconnect all the Keyboard Devices that are attached to the computer. Next, turn-on the computer, and go back to the "Keyboard Properties," this time click on the "Change Settings" button, next click on the "Driver" button, and select the "Uninstall" button. Once that is finished, shut-down the computer again. Now you want to "Reconnect" all the devices that were connected before, and "Turn-on" the computer. You will repeat exactly what you did from the start, this will "Reinstall the Keyboard. Restart the computer again after all changes have been made; this will ensure the changes take place properly. "Rating the solution will let me know if it worked, or you may need further assistance, thanks."
May 27, 2010 | Dynex Multimedia Keyboard
How to reconnect my dell wireless keyboard
Hi, these instructions will help you, first, click on the "Start" button, in the "Start Search Window, Type: keyboard; the "Keyboard's" Properties window will open. You can (Test) to see exactly how your keyboard is responding. if you are still having the same problem, (check the Keyboard Status), try "Updating the Drivers," by clicking on the "Properties" button. Now in the event that neither of these solution solve the problem, which I hope you shouldn't have to do anymore; try "Uninstalling the Keyboard. To "Uninstall the "keyboard," do the following. Shut-down (turn- off completely), disconnect all the Keyboard Devices that are attached to the Computer. Next, turn-on the computer, and go back to the "Keyboard Properties," this time click on the "Change Settings" button, next click on the "Driver" button, and select the "Uninstall" button. Once that is finished, shut-down the computer again. Now you want to "Reconnect" all the devices that were connected before, and "Turn-on" the computer. You will repeat exactly what you did from the start, this will "Reinstall the Keyboard. Restart the computer again after all changes have been made; this will ensure the changes take place properly. "Rating the solution will let me know if it worked, or you may need further assistance, thanks."
May 18, 2010 | Dell Wireless Keyboard Optical Mouse w0147
Keyboard is not working in msi A6000 laptop
if the problem is that keys are typing it could be that the cable came loose. Open laptop and disconnect cable and reconnect and restart the computer it should work.
Jan 26, 2010 | MSI Computers & Internet
Keyboard stopped working completely.
To, Fix the problem, do the following. Shutdown the Computer, Disconnect the keyboard from the computer, and unplug AC (adapter) from power outlet. Reconnect in reverse order. Turn on the computer. Turn on the keyboard. Go, to Control Panel; click on Device Manager. Click to open Keyboards, in the (Keyboard Properties) Click on Driver (Box), next click to "Update Drivers!"Click OK. Restart the computer. Check keyboards’ functionality.
Jan 17, 2010 | Dell OW7658 (J4624SK8115RT7D50) Keyboard
Keyboard is not responding it does sometimes then stop again
Step 1
  1. Check to be sure your "Number Lock" or "Function Lock" keys aren't lit. These can lock out certain parts of your keyboard. If either of these is lit, press them to unlock the locked portion of your keyboard. These can be found at the top right on a laptop and between the number pad and main keys on a desktop keyboard.
  2. Step 2 Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
  3. Step 3 Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
  4. Step 4 Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
    For desktops, disconnect the keyboard from the desktop. Reconnect after one or two minutes.
  5. Step 5 Reconnect the power adapter or AC cord. Start your computer.
  6. Step 6 If your keyboard is still locked on a Dell desktop, disconnect the keyboard. Restart your computer and reconnect the keyboard after the system boots. Allow your operating system to recognize and reinstall the keyboard.
Nov 15, 2009 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
No keyboard function at all
just restart the system and unplug the keyboard cable and reconnect it.
Sep 10, 2009 | ASUS Laptop Keyboard for Asus Eee PC
Mouse and keyboard suddenly stopped working on Dell b110 desktop
Disconnect external peripherials except keyboard and mouse .Disconnect the power cable.Hold the power button for 10 seconds to drain flea power.Reconnect the power cable and turn on the computer When the blue DELL™ logo appears, press immediately. In bios there is option for Function key F9 or F10 probably to reset to defaults.SAve and exit and restart the system .Then try to use the PC restore feature on dell. check http://support.dell.com/support/edocs/systems/dim1100/en/SM/syssetup.htm#wp1055545
Good Luck.
Apr 05, 2009 | Dell Dimension B110 PC Desktop
Mx3200 keyboard stoped typing
Unplug the USB (or PS/2) plug for a couple of seconds and reconnect them. That worked for me when this happened on my older Logitech keyboard.
Jul 05, 2008 | Logitech Cordless Desktop MX3200 Laser...
Keyboard lags
try to disconnect the cable from the PS/2 port that is located at the back of your system unit. it is color purple that is indicated from the cable of your keyboard. then reconnect the cable then restart your computer.
if still doesn't work, let me know here..
Jan 16, 2008 | Computers & Internet
Compaq Keyboard Logo
268 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
