Question about Nordic Track NordicTrack Treadmill, A2550
I have a old dp powertrac 2500 treadmill. where can i find a control box that has speed\distance\pulse and calorie counter.???? someone left the batterys in the box and they exploded.
maxtreadmill
  • 832 Answers
SOURCE: the digital display
If the display has a gray back ground and black numbers this unit maybe using 2 AA size batteries to operate the console
Posted on Mar 12, 2010
SOURCE: How accurate are the calorie counters on treadmills and cardio equipment?
Here's what the Sole exercise equipment makers say about calorie counters on exercise equipment. it's from their E-95 users manual: "Calorie readings on every piece of exercise equipment, whether it is in a gym or at home, are not accurate and tend to vary widely. They are meant only as a guide to monitor your progress from workout to workout. The only way to measure your calorie burn accurately is in a clinical setting connected to a host of machines. This is because every person is different and burns calories at a different rate. Some good news is that you will continue to burn calories at an accelerated rate for at least an hour after you have finished exercising!"
Posted on Mar 19, 2009
  • 14 Answers
SOURCE: My treadmill won't keep up with the time,
Most like the casue is a loss of speed signal. There is a sensor with 2 wires that sits near the front roller where the walking belts wraps around. The fromt roller had a pulley where the drive belt goes around the motor and front roller. Look at the pulley on the front roller and there should be a small magnet glued in it. There should be the wire mentioned eariler near this roller.
Sometime moving the sensor at the end of the wire closer to the pulley where the magnet is will solve all ot the speed, distance, etc....problems. If that doesn't do it , it's time for the repairman.........
Posted on Apr 29, 2009
  • 48 Answers
SOURCE: i can not get the
hi
open the hood and check the speed sensor i think it is unconnected or to far from magnet
as speed sensor does not feel the speed console does not know if treadmill running or not
Posted on Nov 23, 2010
AJIN G
  • 6694 Answers
SOURCE: The meter that you set
hi,
check ur tread mill's control consoles press button switches first. if all good the other chance is, ur control console have a programmed ic (integated circuit) in it. some programs are loaded in that ic, with which its displays speed distance traveled and all other settings. may be posibiliy for the ic get faulty. if so, the any way is consult the manufacturer, because you will not get the same in open market.
ok
Posted on Dec 27, 2010
Proform L18 treadmill display doesn't work. Incline and speed switches work but no led display
f6627a04-b106-44a9-8b92-9f8216f7b081.gifsee the diagram attached. Clean it. Test for open or faulty. Tight the connector. God bless youecb0db45-4f21-4a62-9528-93bd2d358ee3.gif
Apr 03, 2013 | Startrac Fitness Products Star Trac 4500...
NORDICTRACK X9I CALORIE COUNTER IS WRONG
Yes the repairmen is o.k when he says the controllers nothing to do with the calorie counter.
See the block diagram attached, the problem is the display board or upper board. However adjust the REED switch, test for open or faulty, clean it, and tigh very well the connector b) tight the ribbon cable for keypads inside the display board. c) replace batteries from display by new one, with the same polarity, same markay such hybrid rayovac. c) clean the contacts battery.
God bless you
Jan 08, 2013 | Nordic Track Treadmill Motor Controller...
How do you calibrate a york treadmill?
yes you must read the instruction manual for software calibration.
or open the hood motor, and read the instruction attached.
or you must call to York supply for customer service and ask them where is located in case that you will not find them.
God bless you
Jul 12, 2012 | Exercise & Fitness
York 2750 treadmill: How do I reset distance display? regards
Does anyone know where I can buy a replacement earlip pulse monitor for York 2750 treadmill?
Jun 27, 2011 | Health & Beauty
The meter that you set that tells you your speed, distance and calories burned stays at 0:0...the mode moves around when you push that but it stays registered at 0 for all modes. I put new batteries in it...
hi,
ok
Dec 27, 2010 | Treadmill Doctor Weslo Cadence Ex16...
I can not get the speed, distance, or calorie numbers to come up they are showing 0.00 on them and the pulse rate is working I have a DX15. I have replace the batteries and still only showing the numbers...
hi
Nov 22, 2010 | Weslo Exercise & Fitness
The digital display for calories burned/speed/pulse, etc is not working, yet treadmill works fine, it all worked the last time I used it!
Mar 11, 2010 | Exercise & Fitness
Nordic Track NordicTrack Treadmill, A2550 Logo
512 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Paul Sikkema
Paul Sikkema
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
