Question about Western Digital External USB 2.0 80 GB Hard Drive
The computer is not recognising the USB when I plug it in. The light is on and power working?
  • 6,831 Answers
Body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 27, 2010
HD-PE250U2 had it for 3 years - very much loved and working last night. Computer will not recognise it this morning - but power and blue lights are on. Computer does not register the 'name' of
Either the hard drive went bad or the electronics of the enclosure went fubar. Suggest you remove HD and directly connect it to your desktop computer to see if the cmos recognizes it along with the OS. If so you can access your data. If not, the drive is ng - if the drive at least spins and is recognized you may be able to retrieve the contents using windows explorer. If unit will not spin you are in deep doo doo.
Do not format - that will erase everything - try to access the data.
Sep 03, 2017 | Buffalo Technology (HD-PE250U2/BK) 250 GB...
Computer not recognising hard drive. I have even looked in disk management and it's not recognised there either. The hard drive is lighting up when connected so it is working.
HI sineadkirk1
There are several reasons why your hard disk can not be recognised by the computer
1> usb cable problem
2> usb port problem
3> the problem on a computer virus or hard disk
4> computer problem
5> hard disk problem
do the test one by one to ensure that the root cause
thanks&regards
Jan 09, 2011 | Western Digital Elements powered by WD 320...
ST300003U2 hard drive powers up ok, power light on, message on pc "usb device not recognised " .one of the usb devices has malfunctioned and windows does not recognise it.
Try to plug it in to another PC to see if you get the same message. See if you can run a scan disk on it from Windows to see if it's bad or going bad too.
To be honest, device not recognised is a bad sign. :(
Dec 22, 2010 | Seagate (ST3320820U2-RK) 320 GB USB 2.0...
I cannot get the computer to recognise the Maxtor device. I had it working 18 mths ago and have now just reconnected it. Not sure if I have all things plugged in correctly but can't find a diagram of...
The correct lead should be Y shaped and two of the limbs plug into two USB sockets on the PC, the third lead has a small jack which goes into the OneTouch. It should light up if it is getting power from the USB and there should be an icon showing for it in My Computer.
Aug 17, 2010 | Maxtor OneTouch 4 Mini 120GB External USB...
When I plug in my Usb into the computer, it doesn't recognise
HAVE YOU CHECKED YOUR PENDRIVE ON SOME OTHER COMPUTER. THIS HAPPENS WHEN YOUR PENDRIVE BECOMES FAULTY.
Apr 09, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
My SanDisk 2GB USB just stopped working whilst I was typing
pls try to connect this usb drive to a linux machine and see what u get? let me know if you get ur data back :-)
Aug 21, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
WD320 GB 2.0 USB external hard drive is not working.
bad driver chip... call the manufacturer.. have the HDD changed...
Jul 09, 2009 | Western Digital Passport 320GB External...
Power to 1T EHD not going through
yay, I plugged it back into my computer at home and it worked... might have not been enough power or the USB connection wasn't strong enough. anyway, happy happy happy...but have learnt a big lesson...BACK IT UP ON DVD as well.
Mar 26, 2009 | Western Digital My Book Essential 1TB...
Lights on but no one at home
you'll need to add it in my computer, as a logical external drive...
and when plugging into usb, recommend plugging in when it's powered down, not when it's active.
Apr 20, 2008 | LaCie (300770) 250 GB Hard Drive
Computer won't recognise camera to download images
** Problem Solved **
I found it wasn't the camera entirely to blame. I tried another USB cable on another pc, and although the camera was doing the same thing as my problem, the computer recognised the camera as new hardware, and asked me how to access the pictures. So I was able to get the pictures from the camera to the computer, and then saved them on to my Kingston flash drive. So taking the flash drive to my daily PC, I plugged in my flash drive via a USB extension lead, and discovered that would read either... alarm bells rang. So I unplugged the lead, and put the flash drive straight into the computer direct. The computer recognised it immediately. So plugging in the extension lead again, and the flash drive, it read this now. So I tried the camera, and it recognised it.
So I don't know exactly what the problem was, but it was solved... saved me a lot of running around and money ;)
Feb 13, 2008 | Cameras
Western Digital External USB 2.0 80 GB Hard Drive Logo
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
