Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
JD Z TRAK 757 BATTERY LIGHT IS ON WHILE BLADES ARE ENGAGED. AFTER MOWING FOR 15 MINUTES OR SO THE BLADES DON'T HAVE ENOUGH POWER TO CUT ANYTHING.
SOURCE: I have a 757 Z-TRAK. It just won't throttle up
A small air bleed tube is located under the carb. It makes a 90 degree turn and if it is folded from fatigue or heat the mower will have little or no power. Simply remove it from its bracket and it will relieve the tension enough to allow air to bleed.
Posted on Apr 26, 2010
  • 52 Answers
SOURCE: craftsman 42" riding lawn mower blade free spinning but wont cut
It sounds to me that you need a new mower deck drive belt, or your blades need sharpening. If the blade edges are rounded, they won't cut butter... Also, when mower is off, check mower deck drive pulleys to make sure you don't have any that are locked up or are dragging. You can check this by pulling the belt away from pulley and spinning the pulley by hand. MOWER MUST BE OFF before attempting any of these checks. You would be surprised how many people would try this with the mower running.
Hope this helps
Posted on Mar 11, 2009
lester482529
  • 226 Answers
SOURCE: mowing deck makes ticking noise when blades are engaged.
A FEW THINGS TO LOOK AT ARE ,1THE PULLY SHIELDSMAKE SURE THEY AREN'T BENT TO CLOSE TO THE PULLEY'S.2 THE PULLEY BEARING'S MAY BE WORE OUT AND TO BREAK .3LOOK UNDER THE DECK TO MAKE SURE YOU DIDN'T GET SOMETHING TRAPED IN THE CUTTING DECK.HOPE THIS HELPED.
Posted on Jun 11, 2009
moretons
  • 155 Answers
SOURCE: JD X320 blades stay engaged, always. Narrowed it
Hi you can adjust the gap on these clutches , The recomended gap is 0.10 thou you slide this size feeler guage into the hole on the side of the clutch there is three holes and three adjusting nuts you have to try and get it even .
Hope this is some help
Mark.
Posted on Jul 23, 2009
  • 3911 Answers
SOURCE: Runs fine when blades not
If it has a B&S engine, and many do, try this. Remove one spark plug at a time and start the engine. If it runs with one plug, but not the other, then you have a dead cylinder. That is why it seems to run OK so long as no load is on it.
I have had 2 different mowers with B&S engines which bent the valve push rods on the left (as the driver sits) side of the engine causing the problem you speak of. And if you google this issue you will find that I am not the only person who ever had this scenario.
If you have the OHV type engine you can pull off the little valve cover, next to the spark plug, and see the rocker arms and the push rods behind them. Replacing them is about as easy as it looks, however setting the gap between the top of the valve and the rocker is best left to someone who knows what they are doing.
Posted on Sep 11, 2011
JD ltr180 stalls when blades engaged
if it has an electric pto for the blades, it is possible that by engaging that pto, there is not sufficient power left to run the engine
check charge rate , battery condition and pto system
Jun 30, 2016 | Garden
757 Ztrac. Why do I keep burning belts off?
if you dont use kevlar belts,then you are wasting money,they cost more,but,they last ten times longer,use the widest width that it can handle,dont buy from jd,it will cost you 100.00,go to ebay,etc,your tensioner should not be tight enoughto stretch the belt also,here is a jd belt,you can get cheaper just make sure it looks green or red,not rubber black, JOHN DEERE oem Mule Drive Belt TCU13195 737 757 Trak below 030000
OEM Replacement PTO Belt John Deere 737 757 Zero Turn Lawn Mower
JOHN DEERE TRAK 737 757 797 60 DECKS DRIVE BELT TCU13198 12760
Jun 24, 2015 | John Deere Garden
I have an Ariens 46"Hydro Model 936053. Tractor is 2 years old and thought I just had a dead battery.. After charging, I began mowing, after about 15 minutes the Blades stopped turning while still...
First: check the battery because if it was dead then it might not be any good... Then after replacing said battery, hook a volt meter up to your battery and it should read over 13.2 and might even climb up to 14+. Anything over 15.5 or so will cook your battery. Your engine died because the safety solenoid in the bottom of the carb lost voltage... but I am only supplying what I would do in this situation by using your description.
Oct 20, 2013 | Ariens Garden
When the blades of the mowing deck are engaged the engine starts missing and shutting down. Otherwise the engine runs fine.
Sounds like you may have safety switch problems. Does it have an electric clutch, or is it all manual pulleys. Check the switch on the engager for the blades first before doing anything else.
Nov 18, 2010 | John Deere 420,1020,2010,2020,2510,2520...
I have a 2005 JD 757 Z Trak. had to replace the ...
Assuming everything is correctly aligned that should be and everything below the deck is not binding in any way then the excessive fuel consumption and the dying under load is probably connected.
Something is clearly not to specifications - fuelling or timing or restricted breathing (intake or exhaust), spark power and suchlike. I suggest you revisit both the list of specifications and the motor...
Aug 26, 2017 | Garden
Apr 03, 2010 | John Deere 420,1020,2010,2020,2510,2520...
My JD riding mower just stopped during a recent mowing
There was a time when my JD just quit and did nothing. After doubting the battery that is what it was-the battery. Jump start your JD and if it starts up then your battery needs replaced.
Oct 20, 2009 | Garden
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
543 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
