FixYa.com
Tags:
Intel D845EPI  Motherboard
Graphics Driver failure on Intel D845GVSR
posted by sam007ind on May 07, 2008
Dear Friendz,
I am having a lot of problem in installing the Intel Extreme graphics driver in my PC. The driver was supplied in the CD that came with the MB. Whenever I'm trying to install it, It is showing failure. Please help me out
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jun 17, 2008
Not Rated (0)
irshadahmed
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
i need Intel D845GVSR VGA driver for windows vista. can u help me.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on May 07, 2008
Not Rated (0)
map9966
Rank:Guru Guru
Rating: 88%, 1055 votes
Hi sam, could you explain why you found you needed to re-install the graphic driver for you're Intel board?
The graphics driver fails to install means the onboard video is defective. You can replace the the integrated graphics card with a new PCI video card. Please click on the link below. Any one of these cards will run in you're Intel motherboard.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=319&name=PCI-Video-Cards
When you install the new video card you will gain system memory because you're onboard old graphics uses you're main system memory to function.
For you're Intel D845GVSR manual click this link.
ftp://download.intel.com/support/motherboards/desktop/D845GVSR/SR_English.pdf
Intel's D845GVSR main page driver link.
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=1065&OSFullName=Windows*+XP+Home+Edition&lang=eng&strOSs=45&submit=Go%21
If you have more questions, please feel free to ask.
Good Luck!
Mike
Can you Help with these Motherboards problems?
Motherboards
link is broken
hi srinubabu epox ep-4pdaei... Answer This...
Motherboards
urgente¡¡¡¡...
como puedo hacer para... Answer This...
Motherboards
retrouver pilote audio
Carte m?re ASV533MSD+ de... Answer This...
Motherboards
je veut des instrustion
instrustion pour le produit:... Answer This...
Motherboards
MOTHER BOARD
dear sir i have a qss-3300... Answer This...
Repair Service
Find Motherboard Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
