Question about Refrigerators
Lower half of refrigerator is freezing - Refrigerators
  • Refrigerators Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 29, 2010
Frigidaire up right freezer the top half if warm and the bottom half is freezing. The freezer is only about 3 months old. Help.
contact the manufacturer for your warranty .any attempt to DIY fix will probably void any and all warranty you have
Sep 17, 2017 | Frigidaire Refrigerators
Lower half of fridge is freezing food while upper half is fine
it needs room to breathe,too many things blocking air flow and turn it down a couple degrees,40 is good
May 30, 2015 | LG LFX21971ST Stainless Steel Bottom...
Upright freezer-GE. BOTTOM half of cavity freezes very well, TOP half is just cold refrigerator temp. There was a bit of water under the unit before this started. 10 years old.
is it a 2 door? 2 compressor? settings for upper and lower?
omg what is wrong with u people?
water? is it a self defrosting model?
have you checked the pressures and amped the compressors?
omg CALL A PROFESSIONAL
Dec 29, 2014 | Refrigerators
Vegetables freezing in lower trays
lower the temperature in the temperate control and then lower the humidity control vent to half open on the trays themselves.
the main reason is your temperate is to cold.
Dec 30, 2012 | LG LRTP1231W Top Freezer Refrigerator
What causes the coils behind the panel in the freezer to freeze up and stop the freezer fan? top half of freezer defrosts, lower half stays cold.Fridge is side by side and freezer fan keeps turning of
When the evaporator fan motor stops running the top half of the back wall of the freezer will frost over and the the only reason the lower portion stays cool is because cold air falls. More than likely you have a a dc motor fan and its bad, but be wary with ge, the main control board could also go bad causing the fan not to run.
Sep 05, 2012 | GE Refrigerators
Top shelf on ceiling of freezer only half freezes and the lower shelves do not freeze or get cold at all
Guessing this is a manual defrost freezer. If so, ether a restriction in sealed system, weak compressor our a leak in the sealed system.
Aug 19, 2012 | Refrigerators
Our refrigerator is freezing our vegetables. it is turned all the way down.what is the problem?
Is food freezing in the rest of the fresh food side as well, or just the food in the lower half, like in the crispers. if its freezing everywhere in the fresh food section, you have a bad cold control most likely, without knowing the type or brand, i cant be 100%. If its a GE, you could have a different issue, but most any other brand will be a bad cold control.
If the food is only freezing in the lower half, then your evaporator fan motor is likely the problem, located in the freezer
Mar 19, 2010 | Refrigerators
Kenmore 106.536323000 S/S: Not Cooling Enough
YOU HAVE A DEFROST PROBLEM. FROST HAS BUILT UP SOMEWHERE AND THE FAN CAN'T BLOW PAST THE BLOCKAGE. OR ONLY A SMALL SECTION OF YOUR COILS IN THE FREEZER ARE COOLING DUE TO A CLOGGED FILTER OR BAD COMPRESSOR. PULL THE BACK COVER FROM INSIDE THE FREEZER AND LOOK AT THE COILS. THEY SHOULD HAVE A LIGHT FROST AVER THE ENTIRE COIL.IF IT IS A BIG BLOCK OF ICE YOU HAVE A DEFROST PROBLEM.
Oct 28, 2009 | Kenmore 53642 / 53644 Side by Side...
The freezer side not freezing just cool, the
Open freezer door, pull food off shelves on lower half of inside freezer and look if you have frost building up on the back wall of freezer. If you do then you have a defrost heater or thermostat possible gone bad.
Advise if you have frost build up and I will advise on how to check it.
Oct 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
Freezer and fridge not cooling (halfway)
SxS Amana upper half of feezer and Refrigerator not working
Jun 22, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
