Question about Tomtom GPS
Tomtom wont turn on i put new battery and also used the reset button but still wont turn on. green light is on for power
  • 944 Answers
This is a common type of problem occurs,this could occur due to the following reason
1)Reset the phone will solve it.-(mainly this will solve)
2)Firmware corrupted needs update.
3)Jumper IC inside the GPS could have burnt.You should replace the IC or re hot it or If you don't have take it to the nearest service centre.
To reset your Tom Tom device:
Check that the battery is charged properly.
Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
Remove the SD card
If your device uses an SD card, remove it.
Reset your device.
Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. See the pictures below for where to find the reset button.
Turn your device on.
Press the On/off button for at least 5 seconds.
Insert the SD card
If your device uses an SD card, insert the SD card.
Firmware upgrade solution:
1. turn on tom tom software in computer and install updates
2. hold power button on tom tom device for 15 sec then it will turn off
3. connect tom tom device to computer AFTER updates have been installed. (i recommend rebooting computer so software takes affect)
4. hold power button to turn on device once connected to computer(this will install updates into device)
5. once install is done disconnect dive and turn power off.
6. turn device back on in an area were you get a good signal this should fix the problem might take 5min to get GPS Signal.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Posted on Aug 29, 2010
My TomTom One V3 won't switch on. The green light shows it as charging but it won't power up. Tried reset as discussed with TomTom
If reset not worked, then must open up, take out battery and then reset, then you must hook up USB and upgrade software, also maybe need to get new battery too, often battery seems OK, but not,.
Apr 10, 2010 | Tomtom ONE 3rd Edition GPS
Wil not turn on
Put the receiver in the charging cradle. Does the green charging light appear? If it does not, you might just have a defective cradle and hence a completely flat battery; try charging with the car charger and retry. If it doesn't charge with either charger, the power section of the TomTom is obviously gone.
Assuming you now have a charged TomTom, keep the power button pressed for five seconds. If it does not turn on, try resetting it by inserting a paper clip in the RESET hole hidden below the front cover.
If it still does not turn on, it's either a defective power button or a faulty mainboard, and I'm afraid you can't easily fix either; you'll have to send it to maintenance.
Let me know how it goes...
Mar 15, 2010 | Tomtom GO 910 GPS Receiver
Tomtom wont turn on.
try putting a pin into the reset button (right next to the memory slot) do this for about 15 secs, good luck
Jul 27, 2009 | Tomtom ONE GPS Receiver
Tomtom 910 power problem
It is very small - a pinhole. Use a paperclip to press the button which is sunk inside the small hole.
Jun 27, 2009 | Tomtom GO 910
Doesn' t turn on
1. Connect the TomTom to the USB for power (green light should be on).
2. Hit the reset button on the bottom of the device - you should feel it depress slightly.
3. Press firmly and hold the power button and count to 10.
5. Try this a couple of times if it doesn't work the first time.
Even if your battery is ****, the power connection has a pass-through, so you can still use the device as long as its connected to the charger.
Dec 19, 2008 | Tomtom GO 720 GPS Receiver
TOMTOM 910 will not turn on after charging
According to Kevin A who says, and thanks by the way (There is a reset button on the back at the top of the unit. It should be on the right side as you turn the unit around. Insert a paperclip or pin into this hole, and the unit should reset) at it works 100% because I tried this morning after being quoted £55 to have my GO910 fixed and now it works after the price of a paper clip. Doug rrp3
Nov 21, 2008 | Tomtom GO 910 GPS Receiver
Tomtom one
After a reset, hold down the power on button for at least 15 sec...
May 17, 2008 | Tomtom GO 300 GPS Receiver
Tomtom
stevi at the back of your tom tom where your windscreen dock goes there is a small rubber bumper if you look to the right and down you will see the reset button it is a small hole above the dock socket. sandy
Feb 21, 2008 | Tomtom GO 910
Doesn' t turn on
reset the device by pushing the reset button near the plug on the bottom of the unit , then it will come on i presume you upgraded by the internet you need to use a paper clip to reset the unit
Sep 25, 2007 | Tomtom GO 700 GPS Receiver
GPS Logo
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
