Question about Hunter 28096 Westminster 52" Ceiling Fan with Light
After installing new fan, lights work, but fan doesn't.
  • Hunter Master
  • 17,129 Answers
Make sure that the fan was connected in the unit. If there is no manula control then you must check if the connection has come off in the dual assembly. Check the fan coils and the connecction to the starter capacitor. If open connect, if there is connection to the unit check for failure of the line.
Posted on Aug 29, 2010
Strobe light
If it has a remote control you probably need a new receiver. Call 1-888-830-1326
May 25, 2013 | Hunter (25417) Ceiling Fan
Ceiling fan remote control doesn't work
Sounds like you have an add-on remote. Try changing the frequency in the receiver & transmitter. If that doesn't work you probably need a new receiver.
Feb 03, 2013 | Hampton Bay Dryers
Newly installed Hunter remote will work light and fan if only 2 of the 3 bulbs are installed.
Did you install the correct wattage? If you put in 2-60 watt try 3-40 watt instead .
Dec 30, 2012 | Hunter 52" Ceiling Fan With Light And...
Hunter ceiling fan remote will not turn off light it just dims the light
Try this. Remove power from the fan. Remove batteries from the remote. Press butttons on remote (might be stuck). Apply power to the fan. Install batteries in the remote and try all functions. If this doesn't work, the remote may be defective or the remote receiver may be defective. I can tell you from my own experience I have a ceiling fan that loses its mind whenever there is a power outage. Has to be reeducated from scratch
Oct 06, 2012 | Hunter Ceiling Fan Remote Transmitter...
My fan works but the lighting unit doesn't. Take it back? Wiring problem? I have the San Marino model.
If this is new piece and has not worked you need to recheck teh wiring before the unit is suspected.
Check the seperate line for the light circuit. If the connections are correct then the light unit can be faulty . If this is new get a replacement.
Jul 17, 2011 | Hampton Bay 24002 Ceiling Fan
INSTALLED NEW LIGHT SWITCH IN CEILING FAN LIGHT PULL CHAIN TYPE AND THE LIGHTS WILL NOT TURN OFF WITH THE PULL CHAIN? THERE ARE 4 WHT WIRES AND 4 BLK WIRES IN LIGHT KIT WERE DO THE 2 WIRES FROM THE NEW...
twist the 4 black wires from the lights together and use a wirenut to either connect them to one side of the switch or to a pigtail that will go into one side of the switch. The other side of the switch will be wired to the hot wire coming from the fan meant for the light kit. All of the whit wires get twisted together and connected to the neutral light wire coming from the fan. If you've already connected it that way and it doesn't work, the switch may be defective.
Jun 26, 2011 | Westinghouse Electric Ceiling Fan Light...
Got projector out after several years of non use. Lamp would not light. We purchased a new bulb and installed it. Still doesn't work. Fan runs and all, but bulb will not light.
Check the internal power and lamp fuse. Sometimes, when a projector is stored, an area of corrosion develops around the lamp pins and lamp holder. If you carefully clean both the holder and the pins on the original lamp you may find it works OK!
May 21, 2011 | Kodak Ektagraphic III-E-Plus 35mm 140...
Doesn work at all
I've had the same problem. Get the technical assistance phone # out of the manual that came with the fan. They can give you the proper part # so that you can then call Home Depot and special order the receiver. However, I have done this and then installed the new receiver as advised by Hampton Bay and I still am unable to get the remote to operate the fan or the lights. I know the fan works becaue I bypassed the receiver and wired directly to house power. I don't know if perhaps I have a bad transmitter (remote). I'll try that next. The fan worked for about a year, now its just a headache.
Jan 30, 2009 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
New fan not working but lights work
There is less than 120v getting to the fan. Its possible that the lights will turn on etc. Take an extension cord and plug it in another plug and grab both power wires from the fan and stick them in other end of extension and I do service calls for broan & Nutone
Jean-Marc
try it out. Im sure your not getting 120v completelty.
Feb 05, 2008 | Broan-NuTone Allure QS130SS Kitchen Hood
Hunter 28096 Westminster 52" Ceiling Fan with Light Logo
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
