Question about Nikon N65 35mm SLR Camera
MY N65 SUDDENLY DONT WORK, WHEN I TRY TO TURN ON THE CAMERA DONT RESPOND, THE LCD PANEL REMAIN OFF EVEN A NUMBER 3 THATS ALWAYS EAMIN ON SCREEN DISAPEAR
  • kakima Aug 30, 2010
    I realize this is a dumb question, but have you tried a new set of batteries?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Having gone a month without a response to my query, I assume it was just a battery issue.
Posted on Sep 30, 2010
N65 shutter button failure
Follow this link: Nikon N65 Camera Body 35mm SLR. You can buy a working replacement body for $19.99. A camera repair man will charge you three to five times the replacement cost.
Jul 04, 2012 | Nikon N65 35mm SLR Camera
For several years my C-3020 zoom camera has worked fine. Suddenly, now when I take a picture, the picture leaves when I snap the shutter. Always before the picture remained on the screen so I could see if...
In the camera menu, there should be a setting for "review" to allow you to set the number of seconds the picture remains on the screen. Also, you can always review the pictures you've taken by pressing the review button on the camera...it's usually a button with an arrow that points to the right.
Jan 21, 2011 | Olympus Camedia C-3020 Zoom Digital Camera
N65. has been sitting in case for a few years. Prior to that it had been used a handful of times. It won't do anything when I insert a battery. No noise, LCD screen shows nothing, flash nothing, not a...
Cameras need to be used regularly to stay in working order. If left, the lubricant films inside dry out and gum up.
As your camera is virtually worthless these days a professional repair makes no economic sense. You can try to free up the camera by leaving it in a warm dry place for a few hours and then trying a fresh battery. As the camera is already effectively a write off you may also wish to try slapping the base down fairly hard on a table as you switch it on. The combination of heat-softened lube films, a fresh battery and the physical shock might just be enough to free off the gummed part, but if there's more than a few gummed up parts then this won't work.
N65's/F65's or similar models can be easily obtained on your local FreeCycle/Freegle groups if you're a bit patient and check often. It's where I've got almost every Canon and Nikon model in my (regularly used) collection. Preventing the fault means turning a stored camera on at least once a month and operating everything you can a few times.
Oct 06, 2010 | Nikon N65 35mm SLR Camera
Dark and blurry
It will clear instantly with a fresh battery.
The viewfinder screen has an LCD overlay and even when the camera is switched off the screen uses a small amount of power. When the batteries are flat the screen is unpowered, the crystals in the LCD align randomly to both darken and blur the viewfinder image.
Please don't forget to rate my answer.
Jul 18, 2009 | Nikon N65 35mm SLR Camera
Auto Focus Nikon N65
amyfesh,
I have been finding a lot of these concerns while looking back at unsolved SLR issues, it shoots at the ceiling or the sky because there is just enough light the camera detects. Check the lens ring for a white dot and the ring for the aperture rotate the ring so the red f-stop (usually in red and f-22 or somewhere near that number) align, now the lens will open enough to allow the light that the camera has determined that it needs, now it will allow the shutter to open. I just joined the fixya in December, so I hope to hear from you if this helped and if you have any other questions about the N65.
rnady320sgi
Jul 13, 2008 | Nikon N65 35mm SLR Camera
My n56 stopped working
I've read recently of a slew of older Nikon amateur film cameras from the late '80's to mid-'90's that have electronics that have failed. Their prosumer cameras (8008, N90, F100, etc) don't seem to be affected as much as their amateur cameras (N2000, N60, N65, etc). You could try cleaning the contacts of both the camera body and lens - as well as the battery compartment, but if that doesn't work, you may be out of luck. The good news is that you can pick up another N65 for less than ten bucks at most camera shops, both online and brick and mortar.
Aug 24, 2017 | Nikon F65 35mm SLR Camera
Coolpix s6
You should be able to turn the screen on while taking pictures so that you can see what is going on a little easier. Here is a link to the manual where you can find where in the menu to turn the LCD on. I tried to get the manual for myself so that I could give you page numbers and such, but it requires that i give a serial number number off the camera, so be sure to have your camera handy when you do this.
Aug 27, 2007 | Nikon COOLPIX S6 Digital Camera
Nikon N65 broken status window pane
kumar1177,
It won't affect you pictures and it is more an aestheric thing so if you can live with it do so. If you want it repaced a reputable camera shop or Nikon can replace the cracked viewfinder, get an estimate first since that work will most likely have to be done by the shop or Nikon.
randy320sgi
Aug 18, 2007 | Nikon N65 35mm SLR Camera
LCD screen isn't working.
Hello, the special flat cable connecting LCD panel with main board is broken. If you want I can supply you with further info (part number, etc.) at LIVE Expert Assistance. Best regards, Arpi
Jul 01, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Slr camera's lcd screen only says i have taken 3 pictures, and keeps sayin ERROR, what could be wrong? I tried replacing the batteries and the camera still says ive only take 3 pictures, even when i out...
Try resetting the counter by pushing and holding the two rewind buttons simultaneously ( red symbols ), one on each side of the top cover. Then open and close the film door.
Sep 23, 2006 | Nikon N65 QD 35mm SLR Camera
Nikon N65 35mm SLR Camera Logo
47 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Nikon Photography Expert? Answer questions, earn points and help others
