Question about Whirlpool Refrigerators
Water is dripping from a vent inside the top of the fridge section of the refrigerator. Model is a whirlpool wrx42rwh6
  • Whirlpool Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 29, 2010
Water in refridgerator
Have a look inside fridge compartment (especially the "roof", if it's a top-mount freezer) & see if you can see any ice build-up (look inside vents that allow cold air into fridge from freezer section. Also, if top-mount freezer, look inside the freezer compartment for ice build-up on "floor", inside vents, or on back wall. These symptoms, combined with water dripping from lots of the "roof" of fridge section (in a top-mount freezer model), can mean several different problems, so best to re-post with more info/symptoms included.
If there's no ice build-up (& the dividing area between fridge & freezer sections isn't particularly cold, which otherwise might indicate hidden ice build-up), it can be as simple as a plugged or obstructed drain tube, which is VERY COMMON. Easiest solution for this latter problem is to use a flexible plastic tube (think similar type as attached to aquarium air pumps), stuff it into drain hole, and blow on the other end. Sometimes you have to blow quite hard to clear an obstruction or complete blockage. If you can't clear the drain tube, it's likely a different problem. Again, a re-post with more info/symptoms will help narrow it down.
Sep 17, 2013 | Roper Refrigerators
Whirlpool Refridgerator + ET1FTTXKQ02 - Water leakage!
Try defrosting it, if this doen't work then do the following and ur problem will be solved..
BLOW AIR THROUGH THE DRIAN HOSE IN THE BACK OR BOTTOM OF THE FRIDGE FIND THE END OF THE DRAIN HOSE USE AIR COMPRESSOR .....
Goodluck,
Please don't forget to rate me as fixya..
Feb 03, 2008 | Whirlpool ET1FHTXM Top Freezer...
I have a whirlpool refrigerator, model GR9FHMXPQ. I got it about 4 years ago. When it was delivered, it had several pieces of styrofoam lodged in the inside ceiling of the fridge section (below the freezer...
You need to remove all of the styrofoam packing material.
Any insulation material would be installed inside the body of the fridge/freezer. The packing material is there so anything inside the compartment (like metal shelves, plastic holders, etc. don't bounce around during shipping and either scratch up the interior, or break. That is all that it is there for.
Apr 25, 2017 | Whirlpool GR9FHMXPS Stainless Steel Top...
Water is dripping inside the refrigerator ... Model f23elite
hello about the water dripping from inside your fridge.inside your fridge there should be a drainage hole were the water should drain out ,it should lead to a pipe that leads down the back of your fridge.try unblocking the hole and pipe this should help the water run away more freely
Apr 23, 2011 | Whirlpool Refrigerators
Water dripping inside top of refrigerator.
if freezer is on top what is happening is your drain hole behind freezer panel is clogged
Nov 11, 2009 | Refrigerators
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Ice & water dripping in refrigerator
Seems that you now have to little gas in the fridge.Somewhere on your apparatus there should be a factory tag where it should be info on amount of gas, prod date etc and also which type of gas to fill.
Other thing as fan not running properly,door gaskets leaking can lead to Ice build up.
High humidity and water all over inside fridge.Gas filling procedure.Make vacum(vacumpump)Fill in correct weight (grams or oz)of gas.Anyhow when you must fill gas there is usually a leak in your system and to find that i use liquid nitrogen.For this serviceman is the best option.
Regards. jan(Norway)
Feb 12, 2009 | Whirlpool GD2SHGX Refrigerator
Our Whirlpool top freezer unit is leaking water into the refrigerator. The model number is ET21NKXGW01 and at the top of the inside of the fridge, water is draining out into the fridge. The defrosting...
We were able to fix the freezer water leak. We unscrewed the false freezer floor and the inside back panel. Ice had accumulated on the freezer floor and the defrosting drain was frozen. We removed the ice by using a blow dryer then poured boiling hot water onto the frozen drain hole. The frozen water in the drain pipe hole eventually melted and the water released into the defrosting drip pan at the bottom of the refrigerator. Problem solved. We no longer have water leaking into the refrigerator.
Aug 05, 2008 | Refrigerators
Refrigerators Logo
186 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
