Question about Maytag 24 in. MDB4100 Built-in Dishwasher
We have a Model MDB4100AW8 dishwasher that is at least six years old. Recently we notice that it isn't cleaning properly. We use Calgon (we have been using powder but are switching to the liquid). Any suggestions? Thanks, Tom & Doris Shea
  • Maytag Master
  • 43,501 Answers
I have an older dishwasher also and recently my wife also complained about it not cleaning right… so me being the man I am tried in vain to clean the things…
Bought new spray arms online and installed them in minutes…now the thing works like new…
However I have also found that if the heating element goes bad then that also can mess things up bad…
So I would buy new spray arms, and also check out the heating element to make sure it is working…
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Aug 29, 2010
Dishwasher not cleaning/rinsing properly
try connect a water filter (carbon and particle), and connect the machine on output filter, mormaly resolve this problem. Some old houses has water supplie problems, as dirty water, and contamined problems, check for water purity.
Jan 14, 2010 | Dishwashers
My dishwasher is no longer cleaning properly. A
Clean out the area where food gets caught and consider using different dishwashing tablets - especially the Calgon ones which clean out the drains of teh machine whilst cleaning the dishes.
Alternitivly you should call in a plumber to clean the pipes (Or purchase the equiptment to do it yourself, there are often all-in-one cleaners that'll flush out the pipes)
Dec 24, 2009 | KitchenAid Dishwashers
My 15 year old zanussi dishwasher won't drain!
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 08, 2009 | Dishwashers
Kitchenaid Dishwasher KUDK01ILBS1
Yes, you are at the point that where the wash motor needs to be replaced. There is no magic bullet to avoid doing the replacement.
If you want further guidance, please post back here. Ok?
Apr 11, 2009 | KitchenAid KUDK01TK - Multiple Color...
Water on floor after Kenmore dishwasher runs
you could fix this, however the price of repair will be 1/2 of the price of a new dishasher.  I would suggest you buy a new oneand not waste money on a six year old dishwasher.  find a good scratch and dent model.
Mar 15, 2009 | Kenmore Dishwashers
Dishwasher not cleaning the dishes
have you cleaned the fliter in the bottom
Feb 15, 2009 | Frigidare FGB24S5DC Gas Single Oven
BOSCH DISHWASHER SHU43C06UC/17 NO WATER UPPER ARM
Ours is a SHU3300UC/06 model, basic model which we bought in 1999 so have had 9 years of trouble free service.
Recently we noticed that there was soap left in the soap dispenser after the machine had finished all the cycles. On further inspection we noticed that the upper level glasses, cups and bowels are not consistently clean and it appears that the upper washing arm is not working properly. At the back of the upper washer arm, there is a rectangular piece that slides over the two water outlet tubes projecting out of the back of the washer which supply H20 to the upper arm. On removing the upper arm and the rectangular connector, I noticed there is an inner place that I think is supposed to work like a washer that fits tightly over the 2 water outlet tubes in the protruding from the back of the washer. I noted that the upper opening in the washer/seal is broken so a proper seal is not established. This would cause insufficient water pressure getting to the upper arm and reduce its effectiveness. Now I'm trying to find the replacement part. It appears to be something than can easily be replaced.
Dec 06, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Doesn't run
I asked for help when the dishwasher (GE 1991) started up and then quit. Your site was useful as we found a priority list of things to check, thus saving much time and confusion. Our problem turned out to be a disconnected ground wire.
Thanks for the help. You probably saved us a couple of hundred dollars for a repairman. We intend to replace the dishwasher next year when the kitchen is renovated so the timing was important.
Nov 23, 2008 | GE 24 in. GSD4020Z Built-in Dishwasher
Bosch dishwasher approx 14 years old
modek no is usually on a label on side of door or etched in on side or top of door.
black staining not due to heater but possibly from rubber door seals
Nov 20, 2008 | Bosch Dishwashers
Maytag 24 in. MDB4100 Built-in Dishwasher Logo
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
