Question about Whirlpool Dishwashers
Dishwasher will drain but not wash, is this a motor issue or control board. I guess my real question is does the pump motor, wash and drain as well???
  • 128 Answers
Your dishwasher s probably clogged take apart an clean this happens to me all the time my wife thinks its a garbage diposal its not
Posted on Aug 29, 2010
Kenmore elite dishwasher 665.12793k311 will not drain automatically. Drains fine when drain button is pressed. Has been running perfect for the past 14 months then all of a sudden stopped draining aut
Wow, that's interesting! I would have guessed the control module (control circuit board) too. But, once upon a time, I encountered a similar situation, and the problem turned out to be the drain pump! It seems like that after the dishwasher ran in the main cycle (where the heater is used to heat up the water), the heat somehow made the drain pump stop working! I don't know if it made the motor wires expand and break a connection, or if the heat made the seals of the motor expand or somehow impeded the free-turning of the motor, but replacing that drain pump fixed the problem! If you want to try this, I would really like hearing back from you on whether or not that fixes your problem. Good luck!
Jan 16, 2015 | Kenmore Elite Stainless Steel 24" BuiltIn...
FDB1050remo Making a squeaking sound almost as if a belt slipping. Not overloaded and nothing rubbing on washer blades. My only guess is that it may be related to low water pressure. Is that possible?
please make this test and fix it. God bless you
Drain Pump
If the dishwasher is loud during operation, the drain pump might be defective or might have some debris in it. This is a common problem.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Circulation Pump
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the circulation pump sound, it's likely that the circulation pump motor bearings have failed. Once this happens the circulation pump will have to be replaced, the bearings are not repairable.
Drain Impeller
If the dishwasher is loud during operation, the drain impeller might be broken, or there might be debris in the pump. Generally, to gain access to the pump the top of the pump housing will have to be removed.
Pump and Motor Assembly
If the dishwasher is loud the motor bearings, drain impeller or wash impeller might have worn out. All three of these components are part of the pump and motor assembly. It may be possible to replace one of the impellers, but the motor bearings cannot be repaired. In that case the pump and motor assembly will need to be replaced.
Wash Impeller
The wash impeller is a small, plastic blade. The motor spins the impeller forcing water through the spray arms to clean the dishes. If one or more blades has broken off of the impeller the dishwasher is loud. The impeller can also scrape against the pump housing if it is damaged, warped or bent.
Circulation and Drain Pump Motor
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the motor sound, it's likely that the circulation and drain pump motor bearings have failed. Once this happens the motor will have to be replaced, the bearings are not repairable.
Water Inlet Valve
The water inlet valve is an electrically controlled water valve. When it is new, the water inlet valve is very quiet. Over time, the diaphragm inside the valve deteriorates and deforms. This deformation interacts with the water rushing in and can cause a loud vibration, buzzing, squealing or other noises. If the dishwasher is loud during the filling cycle, replacing the water inlet valve may solve the problem.
Sep 18, 2013 | Dishwashers
My Viking DFUD042 is stuck in drain cycle while fresh water is entering the dishwasher through the grid on the right side. The pump is working continuously and it only stops after I turn off the power. ...
Hi, this could be a bad control board or a bad motor. It uses the same motor to wash as to drain. It just changes the direction of the motor in order to switch from drain to wash.
You'll need to run a cycle and you will need a multimeter to check which one needs to be replaced. Remove the kick panel and check the grey wire to the ground wire when it should be washing. If you have 120 volts, you need to order and replace your control board. Otherwise, if you don't have power and it's still draining, you need to order and replace the motor.
Jun 23, 2011 | Viking DFUD042 Built-in Dishwasher
The 4th green light on my Ariston dishwasher flashes. What does this mean?
You did not mention what model number that you had but this is what I found after a little digging:
From http://servicetechhelp.com/discus/messages/2801/6823.html?1205974228 :
For future reference, the technician who replaced the control board for me gave me a complete list of flashing LED fault codes for the Ariston LL65 (which are same as Ariston LL64):
001000 Float Switch: Water in Base Pan
001100 No Drain: Dranin Motor Disabled, Filters Clogged, Dramin Hose Blocked
001010 Main Motor Presure Switch Blocked Filter
100100 Control Board: Software of Control Board not Recognized.
000100 Water Valve: Water Valve Diabled <--- This one sounds like your error
000110 Fill Fault: Water Valve Disabled, Turbine Disabled or Control Board
000101 Heating Element disabled or High Limit Open or Control Board
000010 NTC defective or not positioned or control board
000001 NTC defective or not positioned or control board
KEY: 0 = LED off
1 = LED flashing
I also found this for a different model:
http://www.diybanter.com/home-ownership/89945-resetting-controller-ariston-dishwasher.html
No Program Code Fault condition
1 Heavy wash 1000 Operation of flood
protection system
2 Normal wash 0100 Heating
element/Thermistor/Thermostat fault
3 Rapid wash 0010 Drain pump fault or drain
blockage
4 Soak wash 0001 Not filling to correct
level within 6 minutes
Mar 02, 2011 | Dishwashers
Everything works except drain. I have 6 ohms resistance on the drain circuit of the motor. How can I test the control board? Is there some way to bypass it to know everything else is good? mod:DU945PWPQO
Check the following areas to combat this issue further. Use the connector pins on the back of the control to test its operational value.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Jun 21, 2009 | Whirlpool 24 in. GU980SCG Built-in...
Does nt drain
Check the following to address this issue further.
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer or Control board
Jun 19, 2009 | Bosch Dishwashers
Dishwasher will not wash.
Ok, i recommend testing the circulation motor for its operational value. if the motor is functional, replace the main control board or timer.
Jun 13, 2009 | Kenmore 24 in. 16352 / 16354 / 16359...
Will not reset or drain water
HI, usually, if the dishwasher dose not drain properly, it will be the fault of a defective or, malfunctioning pump. i will list several problem areas to check. Inspect each area properly and, replace any component that is faulty or fouled.
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer or control board
May 22, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
ASKO1385 DISHWASHER
Check the following to address this issue.
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
Dec 08, 2008 | Asko 1385 Dishwasher
Dishwashers Logo
43 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
