I have a centrex 80cm tv im trying to program phillips universal remote need code please so far only the mute function comes on screen
  • king buddha Aug 29, 2010
    thankyou for your reply can you please explain how to do a code search with my phillips sru 3030ii and i will try that.
  • king buddha Sep 03, 2010
    thank you for trying to resolve my centrex issues still no luck any other suggestions? That might help would be good. king buddha
  • 11,800 Answers
Unfortunately your tv isn't officially supported by your remote. The only thing you can do is to perform a code scan on the remote, maybe one of them will work.
If none of them will work satisfactorily then your remote is simply incompatible with your tv.
Posted on Aug 29, 2010
  • Azrael SRL Aug 29, 2010
    Start the tv with the buttons on its case and put it on any channel; press the TV button fr 5 seconds until it blinks twice and it will remain lit; press the standby/off key from the remote and keep it pressed until the tv shuts down - release the button immediately, the remote has fond a similar code and it has stored it; check that the other functions of the remote work as they should - if no then press again the standby button o search for a new code.
I need the codes for a phillips universal remote to control a toshiba TV.
  1. Manually turn on the tv.
  2. Hold code search button until the red light stays on.
  3. Press and release TV button-the light should blink
  4. Enter one of the following codes:517 419 512 613 719 112 506 111 618 627 437 041 891 802 111 313 715 With a valid code entry, the light should turn off.
  5. Press channel up button. If the tv responds, the code worked.
If some functions (like mute or menu) dont do what they should, try a different code.
Good luck.
Sep 28, 2011 | Televison & Video
Remote CTL model RM-V210 doesn't allow programming of the VCR.
Dear sir/madam,
http://www.thompsontv.com/rcarc.html
click the above link and programmed your remote control..
thanks
good luck
Oct 01, 2008 | Sony SLV-679HF VHS VCR
NEED SONY CODES FOR PHILLIPS REMOTE
Universal Remote Control Simple Setup
* Point it at a TV set and press the Mute/Power button. (Mute button if TV is already on, or Power button if the TV hasnt already been turned on)
* Keep pointing it at the TV until the TV turns on or muted, most TVs respond in about 5 seconds, the most is up to 20 seconds. (Other universal television remote you find in stores take minutes to program and enter long confusing codes)
* Once the TV is muted or turns on, simply let go of button and you have total control. You can use the remote as if you had the original remote, and responds instantly. ENJOY YOUR FREEDOM of choices with our remote!
Most remote controls require minutes of programming a universal remote code into each television while you read the confusing instruction manual.
Jan 02, 2010 | Philips Magnavox Learning Universal Remote
Need TV Remote code for Phillips 30pw8420/37
Have you check the manual universal remote? where you find the code, you have to cosiderate the philips on listed, then try all the code, before that tell him, how works this function the univeral remote.
Nov 21, 2009 | Philips 30PW8420 TV
Need codes for ge universal remote
I'm need a etec tv code to program DirecTV remote control can you help me please?
May 17, 2009 | GE JASRM24912 Remote Control
Hotel TV remote
for phillips tvs that come out of a hotel try this code with RCA universal remote. the big remote not a small remote. 319753 followed immediately by the mute button. this will pull up the tv setup menu.
Jul 31, 2008 | Philips Magnavox REM-350 Remote Control
Need code for universal remote control
I'm seeing codes 0808 and 0854 could work...
The original codes from the EU URC7711 manual are
Centrex 0780 0891
Also try these
0037 0178 1437 0556
If no luck... go buy a 7$ GE universal remote they work for even the most stubborn TV's
Also when you do the manual search function you have to press enter 999 times before you start the list over... so if you got frustrated... like after 100 tries... you only made it to code 0100 the list ends at 0999
May 05, 2008 | Televison & Video
Remote control code
bought a Phillips Universal Remote control and it worked!
Thank you
Mar 19, 2008 | Televison & Video
Philips universal remote codes
For the majority of phillips/magnavox universal remotes: Hold code search button down till red light satys on. Press the tv button and the red light should blink and stay lit. With the tv on, push the power button repeatedly until the tv turns off.(dont push the power button again after the tv turns off or it will go to the next code). Push the mute button to save the setting.
Feb 07, 2008 | Panasonic PT-47WX53 47" Rear Projection...
ILO universal remote code
I had the same problem trying to program my satellite remote to work with the ILO tv. I found that the emerson codes DO work. Yes local cable remotes will work as long as you have the code and the brand is getting more popular. The code that worked with both cable companys, Charter and DirecTv was 10171 I believe. You can find it under the Emerson codes. Hope this was helpful.
May 23, 2007 | iLO 3200 32 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
