Question about Nintendo 64 Console
My nintendo 64 is like broken by every time no matter what i do my controller is plugged in and i turn it on and it says a controller is not connected please turn of your control deck and i do ive done like 100 times no joke and a diffrent controller and it still does it please please help me
    President:
  • 894 Answers
Well its an internal problem with the console like the controller port might be broken or the motherboard of the console is messed up and needs to be fixed.
Posted on Jul 21, 2011
Why is my Nintendo 64 controller not working?
Well it might be that the controller ports might be loose or broken so you could find some one that repairs old consoles to have a look to see what the problem is then.
Jul 06, 2012 | Nintendo 64 Console
Cant seem to get my nintendo 64 console hooked up..need to hook it up through the vcr
Just follow these steps and you will be playing your Nintendo 64 in no time at all.
  1. Set your Nintendo 64 in it's desired location
  2. Plug the power cord into the back of your console
  3. Plug the other end of the power cord into an electrical outlet
  4. Plug the AV cable into the back of your Nintendo 64 system
  5. On the back of your VCR find 3 cable sockets colored red white and yellow
  6. Plug the the red plug of the AV cable into the red socket
  7. Plug the the white plug of the AV cable into the white socket
  8. Plug the the yellow plug of the AV cable into the yellow socket
  9. Plug your Nintendo 64 controller into the front of your console
  10. Place your game into the game cartage slot
  11. Turn on the Nintendo 64
If you encounter any problems at all feel free to comment on this solution so that I can further assist you.
Jun 13, 2011 | Nintendo Video Game Consoles & Games
I was playing my n64 for the first time in like a year. I fixed my broken controller by splicing the wires back together. i plugged in the controller and turned my system off and on then it wouldn't turn...
Well you are not suppose to fix a broken controller then always buy a new controller so the consoles controller ports might be have problems reading the controller so buy a new controller to see if it makes a difference then.
Jan 08, 2011 | Nintendo 64 Console
On the nintendo 64 if your data keeps getting corupted after evey time you shut it off what do u do to prevent that?
It may be a problem with that particular game cartridge. I recommend saving your data to a memory card which you plug into the back of the controller. You can find one here:
http://www.amazon.com/Nintendo-64-Memory-Card-Storage-Case/dp/B0009NWQDW
Dec 20, 2010 | Video Game Consoles & Games
I can't seem to get my nintendo 64 connected. I've tried 3 different tvs and I got it to work for a short period of time today but it was not the game I wanted to play. After I turned the game off, I...
Nintendo 64 Power Problems
Make sure you are using a licensed AC Adapter (the system's power cord). The name Nintendo should be molded into the actual AC Adapter unit. Unlicensed products are not fully compatible with Nintendo systems and may not work correctly. Also ensure all accessories connected to your system are licensed as well. (Expansion Pak, Controllers, Rumble Pak and Controller Pak.)
Make sure you are not using any game enhancing devices. Such devices are unlicensed and are not recommended by Nintendo, as they may not let your system function properly.
Firmly plug the AC Adapter into the AC Power Supply port on the back of the Control Deck and firmly plug the AC Adapter into the wall outlet.
Make sure your wall outlet works. To check it, try plugging a lamp into the same outlet where your system was plugged in. Turn the lamp on the verify the outlet works. Also, make sure you are not using an outlet that is operated from a wall switch. If you do, make sure the wall switch is in the ON position.
Slide the Power Switch on the Control Deck to the ON position.
If it still does not work, you'll need to RESET the AC Adapter. To do this, remove all the accessories (including the Game Pak and all controllers) from the deck. Unplug the power supply from the wall outlet for at least 30 seconds, then plug it back in. If your system works without the Game Pak and controllers plugged in, there may be something defective with either the Game Pak or one of the accessories. Turn the power off and plug ONE accessory into your system, then turn the system on to see if it still works. Repeat this process with ONE accessory at a time to see if you can figure out which accessory may be in need of repair.
If these steps do not resolve the symptoms you are experiencing with your system, your system may need to be replaced. For more information on what options are available, please click here.
Nov 27, 2010 | Nintendo 64 Console
How do you erase memory from the memory pak
  • Plug an N64 controller into the "Player 1" port on the Nintendo 64.
  • 2 Place the N64 Controller Pack into the memory card slot on the Nintendo 64 controller.
  • 3 Insert a Nintendo 64 game into the cartridge slot on the N64.
  • 4 Hold down "Start" on the N64 controller.
  • 5 Turn the Nintendo 64 on via the "Power" switch on the device. After the console loads, the Controller Pack menu will appear on the screen.
  • 6 Release the "Start" button on the N64 controller.
  • 7 Browse through the saves listed, using the N64 controller's directional pad.
  • 8 Highlight the game you want to erase.
  • 9 Select the "Delete" option. The pages that were occupied by the game save will be erased from the Controller Pack.
  • 10 Repeat Steps 7 though 9 until you're finished erasing pages on the Controller Pak. Restart the N64 if you wish to play the game that was inserted into the device, or turn the Nintendo 64 off if you are done using the console.
  • Read more: How to Erase Pages on an N64 Controller Pack ' eHow.com http://www.ehow.com/how_6566153_erase-pages-n64-controller-pack.html#ixzz15ZouU9Pe
    Nov 17, 2010 | Nintendo 64 Console
    Can we play gamecubegames inside the wii console, if so how?
    You can do both. With internet you can download Nintendo 64 games on the wii shop channel. For game cube games enter the controller in slot one, enter the game and it's like you don't have a wii!
    Note: due to the fact the the wii remote does not have enough buttons ALL N-64 games need a gamecube controller or a classical controller. Game Cube games are not compatible with classical controllers.
    Apr 02, 2008 | Nintendo Wii Console
    Picture and audio for nintendo 64
    Does it plug ino the antenna plug or red/white/yellowPlug?
    Dec 14, 2007 | Nintendo 64 Console
    Nintendo 64 Console Logo
    48 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Bee Santiago
    Raj Patel
    Martin Murray
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
