Sir/Madam, I haven't been able to connect my wireless router to have wifi access at home. I've tried many times to connect it but it usually failed at step 4.3, according to the handbook, and just once it passed that step, however it requested a series of different numbers that I honestly didn't know where I had to take them from. So here I am trying to make use of it as soon as possible because I need it at home for my work
  • 2,260 Answers
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Posted on Aug 29, 2010
Cannot connect to Wireless with my Linksys WRT120N Router.
If you have 2 devices not be able to connect to it suddenly, then it is probably the router that changed, as opposed to it being the 2 devices changing at the same time. Sometimes wireless routers just go bad like that.Try a factory reset, and then set the appropriate settings back to where you need them. If that doesn't help, you likely need a new one.
Feb 09, 2012 | Linksys WRT120N Router
Dear Sir / Madam, I would like to know the
The default settings are:
Username: admin
Password: admin
If that does not work then you may have to do a hard reset on your router. Note that this will wipe out any custom settings that may have been set on the router.
May 07, 2011 | TP-LINK TL-WR740N 150Mbps Wireless Lite N...
Dear Sir / Madam, I have just recently installed a DIR-615N wireless router in my home and am delighted with the performance. My only concern is that I have no security to outsiders accessing this device...
You need to limit your number of connection by browsing your router in explorer. In order to do that simply enter 192.168.1.1 or whatever is the IP of your router and enter admin name and password out there and go to settings limit connections and there you can limit the connections to the number of connections you make with the router. In case you need other options kindly let me know.
Mar 08, 2011 | Computers & Internet
DIR655 Will not allow my iphone to access my wifi network
Home wireless networks usually need a wireless password, make sure you know this before you try and connect with your iPhone. If your wireless network is named something generic (like d-link), your phone may have a hard time connecting, rename it to something unique.
Mar 01, 2011 | D-Link Xtreme N DIR-655 Wireless Router
DEAR SIR/MADAM TO WHO IT MAY CONCERN I HAVE A LINKSYS WAG325N ROUTER , I did REST IT ALREADY i GOT THE POWER LIGHT GREEN THE DSL GREEN THE WIRELESS GREEN BUT THE LOCK (SECURITY) IS YELLOW/ORANGE AM...
connect direct to the router using a cable connection then try accessing the routers setup page again you must be connected before you can access.. also i noticed its a "N" type router and if your pc doesnt have the drivers for an N router then its sure to cause problems..
Feb 12, 2011 | Linksys Wireless-G WRT54G Router
Dear sir a client has a belkin N series router
Couldnt you just buy another wireless access point to extend the existing network?
E.g
http://www.netgear.co.uk/wireless_access_points_WPN802.php
Good luck :)
Jun 13, 2010 | Computers & Internet
Excellent signal low speed transfer
You can boost the signal range of a WiFi computer network in several ways: Answer:
  • reposition your router (or access point) to avoid obstructions and radio interference. Both reduce the range of WiFi network equipment. Common sources of interference in residences include brick or plaster walls, microwave ovens, and cordless phones. Additionally, consider changing the WiFi channel number on your equipment to avoid interference.
  • upgrade the antenna on your router (or access point). WiFi antennas on most wireless base stations can be removed and replaced with more powerful ones.
  • add another access point (or router). Large residences typically require no more than two APs, whereas businesses may employ dozens of APs. In a home, this option requires connecting your primary wireless router (access point) to the second one with Ethernet cable; home wireless routers and/or APs don't normally communicate with each other directly.
  • add a bi-directional WiFi signal amplifier to wireless devices as needed. A WiFi signal amplifier (sometimes called "signal booster") attaches to a router, access point or Wi-Fi client at the place where the antenna connects. Bi-directional antennas amplify the wireless signal in both transmit and receive directions. These should be used as WiFi transmissions are two-way radio communications.
  • add a WiFi repeater. A wireless repeater is a stand-alone unit positioned within range of a wireless router (access point). Repeaters (sometimes called "range expanders") serve as a two-way relay station for WiFi signals. Clients too far away from the original router / AP can instead associate with the WLAN through the repeater.
Nov 19, 2009 | Sony Computers & Internet
How to Configure D-link dwl-510 WiFi Card
To configure your linksys, access point, we need more information, the ipaddress oif your dlink router and the wireless settings on your dlink router..,
for more informations, check this link http:kb.linksys.com
for more details contact linksys; 18005465797
Dec 14, 2007 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
