Question about Microsoft Xbox 360 Console
Xbox 360 no picture
when I put a game in I can hear it but no picture....
NEVER EVER!!! do the towel trick. NEVER PERIOD! It may work for a little while, but you are doing waaaaay more damage than good. The xclamp fix is the only way to rectify this. If you send it microsoft, thats what they're going to do, reball the gpu and cpu and put new, just as shitty, xclamps on it. Then, a couple months down the line, the same thing will happen. The xclamp fix is backed by engineers and is a permanent fix to over 90% of xbox problems. Here's why...
The xclamps microsoft uses are design flaws, they are all designed to fail. As the gpu and cpu heat and cool consistently, everytime the console is ran and turned off, the xclamps warp. The warping x clamps cause the heat sinks to raise from their respective gpu or cpu (most commonly the gpu, the short heat sink). At the same time, the solder balls beneath the gpu and cpu melt and re harden away from the mother board, causing the rrods. The xclamps have no way of dealing with this. Installing bolts fitted with lock washers on the bottom, nylon against the motherboard and stainless steal against the heat sinks works 95% of the time.
Posted on Jul 29, 2008
    Sniper:
  • 55 Answers
Here is my recommendation
If the xbox is still under warranty (I mean no one has broken the sticker) don't open it yet
The reason for this is microsoft will warranty an xbox 360 against the three RROD
The problem you are having is/maybe related to the same thing and what is happening is the graphics processor is no longer responding properly.
Many others on this site have recommended a fix that I am hesistant to recommend, but does work, TEMPORARILY.
I only recommend this fix if you are trying to preserve the console s warranty as this is a non invasive fix.
All you need to do is wrap the console up ina thick blanket or several towels (do not use wet towels as water damage is not covered under warranty) and turn the console on.
This will cause it to super heat and eventually overheat
(this is not particularly good for the console, or permanent)
Once it has overheated (about 45 minutes in the towels/blanket)
unwrap it and let it cool.
After about 1 hour of cooling try to restart the console and see if you have video
For an out of warranty more permanent fix try the xclamp replacement mods outlined in other sections of this forum or search on google for xclamp replacement
Posted on May 07, 2008
  • Edward Stewart
    Edward Stewart May 07, 2008
    Did you try this fix?
  • Edward Stewart
    Before trying any sort of hardware fix, or modification please check that your AV cables are connected properly and input source is selected correctly. If you are able try another AV cable for your xbox to see if this corrects the problem.
SOURCE: put this in an xbox 360 console
The Xbox 360 Wont Read The Disk
Posted on Jan 25, 2008
SOURCE: 360 drive only reads dvds, not xbox 360 games, just says put in an xbox 360 console.
how do i flash drive
Posted on Mar 02, 2008
  • 4 Answers
SOURCE: My Xbox 360 won't play Xbox 360 games
run through your initial set up again.
Posted on Aug 19, 2008
SOURCE: no picture but can hear the sound
We can fix this for you. Its the solder under the GPU has lost contact. We are a listed repair service on this site. www.videogamerepairservice.com
Posted on Apr 24, 2009
SOURCE: My xbox 360 won't read games. i put in disks just says open tray
The scaner is probobly brocken but you can fix it
Posted on Jun 30, 2009
Can only see the picture on tv, cant hear
it may be that a cable is loose, or the tv is broken. check these
Feb 24, 2010 | Microsoft Xbox 360 Console
No picture but can hear the sound
Apr 21, 2009 | Microsoft Xbox 360 Arcade
While playing a game -screen turned pink and then froze
We had the same problem with ours. We had to call XBox company and we ended up shipping ours off to be fixed.
Dec 21, 2008 | Microsoft Xbox 360 Console
No screen on the Xbox 360
right do the towel trick it works. wrap the 360 in 2 towels and leave it on for 15 mins. then go bk to your xbox un wrap it. put it near a window if possible ( i did and its working fine) due to it being near a window you will get no overheating and its well ventilated.
Dec 14, 2008 | Microsoft Xbox 360 Console
Xbox 360 no picture but sound, works on another HDTV
did you check to see if the av conponent was on tv/hdtv?
Nov 15, 2008 | Microsoft Xbox 360 Console
Broken Glass picture on Xbox 360
well all you have to do is just put your xbox on its side for 48 hours unplugged and it should just be abel to clear up
Oct 22, 2008 | Microsoft Xbox 360 Console
Xbox 360-hear sound, but no picture
sounds like a problem with the video scaler chip or HANNA. Sometimes the heat from the motherboard can cause it to malfunction. Go to you local video game store that's independently owned and see if they can fix it. good luck
Jul 23, 2008 | Microsoft Xbox 360 Console
Sound but no picture
Is the TV set to the right input?
Nov 09, 2007 | Microsoft Xbox 360 Console
Xbox wont play games
just call 1800-4my-xbox
Oct 23, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
170 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
