Question about Safe T Alert Lp Propane Gas Alarm Rv Trailer
Our propane alarm sounded due to the camper battery dying. Wee turned off the propane....is there a way to disable the alarm?
    New Friend:
Mine was doing the same thing. I took off the cover to the alarm and unhooked the black wire. That did the trick. Make sure you pull on the connectors and not the wires. You just have to make sure to connect it before using the camper again.
Posted on Jan 25, 2013
  • 3 Answers
It is operating as designed. When there is low voltage it thinks there is a problem and lets you know it. The only way I know to disable the alarm is to disconnect it, depending on how it is wired.
Posted on Aug 29, 2010
Forklift died while in use, put the battery charger on it and with the charger on it I turned the lights on but on got a ticking sound when I tried to turn it over. Took the charger off and the lights...
We'll, since it was running, then it died, I'd say the propane tank was empty. If the tank was replaced, check that the tank valve is open. The next logical item if it still won't start is the pressure regulator. If it was not a fuel issue, and it died due to the battery being drained, then the alternator/voltage regulator is a good next step. Barring any of those being the issue, check the fuseable links and electrical connectors for corrosion.
Feb 03, 2018 | Toyota Cars & Trucks
99 explorer alarm disables. Motor dies
Anti-theft system can keep vehicle from starting , Alarm is for vehicle content theft , open door without key alarm sounds (horns) ! PATS - passive anti theft system PATS enables and disables the engine from starting ,it will not cause the engine to die ! You have some other kind of problem ! If the vehicle engine doesn't turn over an red light on top of dash flashes fast ,then you have anti-theft system problem !
PATS differs from the perimeter anti-theft system in that PATS enables and disables the engine from starting. If equipped, the perimeter anti-theft system protects the perimeter of the vehicle (doors, hood and trunk) and sounds an alarm.
Aug 17, 2016 | Cars & Trucks
Why is the protechtor alarm going off 2010 springdale travel trailer?
Have you checked all gas line fitting, to ensure that you do not have a true leak? Some spray cans , like deodorants, can cause the alarm to sound.
May 13, 2014 | Safe T Alert Lp Propane Gas Alarm Rv ...
1998 toyota Avalon, the car alarm is going off when opening the drivers door manually with the key (remote is broke) and then the car will not start.
Same here... I have a 1998 Toyota Avalon XL. My car battery died. Replaced my car battery, but found out that when you unplug and plug the car battery with this car it engages in security mode (I have factory car alarm). This disables the engine and wont let you turn the ignition aka start the car engine until the remote (keyless entry) "UNLOCK" is applied. My remote is also lost so I cannot disable the alarm.
The only thing I can think of to do is unplug the battery again to disable everything (car alarms are annoying...) and call the dealer to pick the car up and perform the diagnosis. Most likely they will offer you another keyless (ugh... expensive) and/or you could ask to disable the factory car alarm.
I know thats not much help but it seems to be the only option from what I researched currently....
Sep 17, 2010 | 1998 Toyota Avalon
My refrigerator and stove will not run on propane. I have 3/4 tank of propane and my RV is level. Any ideas?
theres a transfer switch that may have went bad.......also (I know you've done this) but check all your valves to make sure there open
Feb 13, 2010 | Safe T Alert Lp Propane Gas Alarm Rv ...
Propane refrigerator?
Yes , when the refer needs to cool it will fire up only with the LP. In the electric selection it will work the same way. Do not fret , it is working ok.
Aug 31, 2009 | Rv Motorhome Dual Co & Lp Gas Alarm...
1997 Honda Civic: Battery died and the Alarm won't disable
If you hook up the jumper cables can you disable the alarm with the remote?
Jun 24, 2009 | 1997 Honda Civic
Camper electrical wiring and propane lines dont work
you need to find the propane lines and where ever you have a joint you need to put "snoop" on it. which is basicly soap and water sorry my spelling sucks. anyway you do this with the propane on and whereever you have bubbles you have troubles. you can even check your lines with it. Now yoiur electrical woes can be fixed by tracing your wiring and finding out where you have a short this is when two wires are either touching eachother both of these problems take time and they take some experience. If you mess this up you could blow yourself up. Let me know what you are going to do. I'm worried for you
Apr 30, 2009 | Rv Motorhome Dual Co & Lp Gas Alarm...
88 735 Alarm won't let me start car and I don't have remote.
I had a 740 il bmw 97 befor it won't start turn the key juste the light in the dach on now tech on bmw had it start but the alarm still on tell the cause of it what can ido to to stop the alarm
Mar 01, 2009 | 1998 BMW 7 Series
Safe T Alert Lp Propane Gas Alarm Rv  Trailer Logo
680 people viewed this question
Top Camper Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
Mike
Are you a Camper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
