Question about LG 50PX5D 50 in. Plasma HDTV
We have had our magnavox TV almost two years and get an odor around it sporatically. We sometimes burn a candle to over ride the odor which smells to me somewhat like rubber. we have not had headaches or irritating reaction other than the offending odor. Is there actually an answer that will resolve the issue? Is this odor toxic?
  • midlife101 Aug 29, 2010
    I would appreciate an explanation and way to resolve the problem.
    thank you.
  • 4,472 Answers
I would try cleaning the entire tv with a lint free cloth, Also if you have it plugged into a surge protector, try plugging it directly into the wall. If the smell continues most times it is the result of a capacitor failing in the tv. You would want to have it looked at sooner then later before it causes more damage.
Thank you,
Lee
Posted on Aug 29, 2010
Burning plastic smell when cold out run heater and fan inside car and out
Are you loosing radiator fluid. sometimes the heater core will rupture and you will smell burn odor. also check for strange rubbing sounds or screeching coming from the blower fan motor. or engine exhaust manifolds are hot when car is on, make sure nothing is leaning on them which will cause a burn odor. Any odor coming from outside will find it's way inside through the fresh air vents.
Feb 13, 2016 | Cars & Trucks
Burning smell inside car. Not under hood. What could it be?
I had the same problem with my 2005 Honda Accord. I would happen only sometime but is a distant odor I smell from inside the cabin. Older Hondas sometimes have gasket problems that leak small amounts of oil onto the exhaust manifold. Ask the mechanic to go check the valve cover gaskets. They replaced a new gasket to my car at the Honda dealer and I haven't smelled that burning odor since then. Good luck.
Jul 21, 2014 | 2005 Honda Accord
I have a 1990s JVC tv that we were wattching the other day then we smelled a smoky smell. Then horizontal lines and staticy sound started to go through the tv. We tried canned air to clean the vents a few...
That tv is very close to catching on fire. UNPLUG IMMEDIATELY. When electronic equipment is old they dont just stop working sometimes. Sometimes the electrical current starts burning the wires and the dust inside. there is a definare odor to electronics burning or shorting out. smell around the air vents in the back of the TV. youll know if wires were burning its a distinct odor
Jun 03, 2012 | JVC Televison & Video
I have a blueflame probane heater ventless and when burning it has a slight smell. Is that normal for this ventless heater.
It depends on what it smells like. Initially, when the unit is installed it should be burned on HIGH for 45 minutes to an hour. Doings that, burns off all the oils and seasons the heater. Sort of like seasoning a cast iron skillet. After that, the newness odors should be gone. It's normal to get a whiff of gas when the burner lights or turns off. It should dissipate rather quickly.
Although Vent-free (ventless) heaters are very safe to use and are 99.5% efficient, their one drawback is that pick up strong household odors, like strong cleaning products, carpet shampoos, new paint or stain odors, strong cooking odors, etc and make them worse. That's why it's always best not to use the heater during or after painting, for at least 2 weeks. Although your nose may not detect the paint odor, the heater can and will make it worse. Also, always use your range's exhaust hood when cooking. Hopefully, it's the vented type and not one of do nothing recycling hoods.
Also, thoroughly cleaning the heater inside and out , at least once a season, will go along way in reducing odors and maintaining the longevity of your heater.
One other caution, do not burn scented candles and operate the heater at the same time. Scented candles soot anyway, but adding the warm moist, comfortable heat from the vent-free heater, will cause them to soot 50 times worse. Trust me, it's not the heater, it's the scented candles sooting.
Hope this helped explain some of the things that you asked about and more. If I can be of further help, please ask me through the Leave a Comment link.
Apr 22, 2011 | Procom MN300HGB Heater
We have 3 unvented gas heaters that have worked fine. turned them all off while painting work was being done. turned them all back on and the smell of the fumes makes us turn them back off. i took them...
Becky, heaters are picking up the fresh paint smell and making it 50 times worse. Although you may not be able to detect the odor, the heaters are picking it up. You need to turn the heaters completely OFF (pilot lights too). Wait at least 2 weeks before trying to use them again. If you have some good, warm days that you can open some windows, that will help to get the paint odor out of the house.
The odor is really not in the heaters, it's still picking up the fresh paint odor that your nose can't detect.
In addition, if you use commercial carpet cleaning products, the heaters should be turned OFF before cleaning the carpets and remain OFF for several days.
Vent-free Gas Heaters are very, very safe & efficient. But, because they use interior air for combustion, they pickup any strong odors and make them worse. Also, never burn scented candles and operate the heaters at the same time. Scented Candles soot anyway, adding the warm moist heat from the heater(s), will make them soot 50 times worse.
This should solve your problem.
Mar 29, 2011 | Rinnai Unvented Gas Zone Heater. 99% fuel...
The tv smells like a burning wire
Can you describe where the odor is coming from. Is it coming out from the side panels on the tv set itself, or perhaps the plug, on end of the main power wire. Check around the electrical outlet. Make sure nothing else is plugged into the same outlet. It sounds as if some of the electrical components on the circuit board are burnt or burning out. Tv may have experienced a power surge, etc. Check also if the power plug is heating up. Be careful and smell around top side vents on tv. Be sure and unplug the set before leaving it unattended if you cannot locate the source of the "burning wire smell."
Jan 22, 2011 | Polaroid TDA-03211C 32 in. LCD HDTV
I have noticed a rubber/candle burning smell when the heater is going, very strong odor, what could it be?
look for loose conectors in the blower assembly or trash inside the intake duct from outside especialy around the fan resistors.
Jan 13, 2010 | 2002 Pontiac Grand Prix
Back to problems with my 2000 Buick La Sabre. I noticed this last year and now it's happening again. Sometimes when the heat is on there is an odor that smells like melted candle wax, the smell can be so...
I don't really know what could be causing a wax smell specifically, but if crayons made their way into the duct-work then that could be your problem. Other wise you may want to inspect the heater-core, could be clogged (for debris or mold) and cabin air-filter (IF APPLICABLE).
Dec 10, 2009 | 2000 Buick LeSabre
Tv does not come on
Those are not good signs. The TV needs repair. I would unplug it and not turn it on again. If the TV is still fairly new say within five years or so, try to find a reputable repair shop. Sometimes the local Better Business Bureau may help or ask around.
Sep 23, 2008 | Philips TP3281C TV
Burning smell from AC Unit
http://www.hannabery.com/faq14.shtml
"Odor problems can be as serious as a gas leak or as simple as a dirty air filter. But remember, a good mechanic doesn't just use his hands. He uses his ears and nose. Unusual odors could indicate a serious problem and should not be ignored.
We will go through each of the five categories and list the possible causes and things to check.
1. Electrical odor - Electrical odors are usually caused by parts overheating. Indoor blower motors are a common example. If there is a mechanical failure such as the bearings seizing up, the motor over-heats and the insulation on the wires and the motor windings themselves start to melt, causing the odor.
Sometimes loose electrical connections cause wires or plastic relays to overheat causing electrical odors.
It is possible for a very dirty air filter to cause the odor. If the airflow is restricted enough, it could cause electric resistance heaters to overheat, even burn-out.
If you smell an electrical odor, check your air filter. If it is not blocked, shut off equipment at the breaker if possible and call for service.
2. Burning odor - This is similar to an electrical odor only worse. It is also sometimes accompanied by smoke. Once again, this can be caused by parts or wiring burning-up.
It can also be debri such as plastic getting into the ductwork and melting on the electric resistance heaters or heat exchanger.
If you smell a burning odor, check your air filter. If it is not blocked, shut off equipment at the breaker if possible and call for service.
3. Gas odor - First of all, if you really smell gas and suspect a gas leak, you should open the windows, get out of the house, then call the gas company.
Now excluding that "worse-case" scenario, if you notice an odor that smells like gas and it seems to be coming out of the supply vents, it usually isn't gas. Sometimes dust that settles on the heat exchanger during the summer months burns off at the beginning of each heating season and it smell just like gas.
If the odor doesn't seem to be coming from the vents, try to pinpoint where the smell is coming from. Use your nose. If it is gas, it usually would be from a leak in a pipe fitting or at the equipment itself.
Gas odor is the one that causes the most fear. People think of gas explosions or carbon-monoxide poisoning. Well, gas explosions are very rare and carbon-monoxide for the most part is odorless.
Having said that though, don't take a gas odor lightly. If you can't locate the source of the odor and you are worried you have a gas leak, remember, open the windows, get out of the house, then call the gas company.
4. Oil odor - Oil odors are usually caused by one of two things. An oil leak/drip or an oil burner that is not working properly.
The oil leak is usually easy to spot. Just look for oil. Check the burner itself, the oil tank, filter and oil line. Sometimes it is just a matter of tightening a fitting. If there are no signs of an oil leak then it is most likely a burner problem.
This can be caused by many things, too many to list. It could be a minor adjustment to the burner to a faulty or blocked chimney. From a bad fuel pump to a plugged oil nozzle. Listen for any unusual rumbling or banging sounds or smoke or soot while the burner is running. If you notice any of these things and/or you have an oil odor, you should call for service immediately.
One other common problem today is that new houses are insulated so well and are built so tight that they run out of combustion air, causing odor problems. In this case it is just a matter of bringing in a fresh air for the burner. Call your local Heating Company to assist in a proper diagnosis.
5. Damp and musty odor - This is more common in the air conditioning mode. Sometimes attic units or very damp basements have this problem. Check for air leaks in the return ducts. Check for water damage to the ducts or air handler itself. Possibly consider having your ducts cleaned. Run a dehumidifier and see if the odor goes away.
But this odor problem is almost never due to a problem with your equipment.
Final Tips:
Keep in mind that almost all heating systems cause an odor the first time they are fired-up. And the first few times at the beginning of each heating season. Brand new furnaces are coated with oil to keep the heat exchangers from rusting. This burns off, creating a bad odor - even smoke. But it usually only lasts for about 20 minutes. Opening the windows usually solves the problem. And the first few times the backup heat on a heat pump kicks on, it smells like an electrical smell. This might last for a few days but isn't that bad. If you are worried, call for service.
Remember to check for a clean air filter and that your vents are opened. Check to see if the fan is working which mean your motor hasn't burned-up.
Check for air leaks in damp areas, oil stains or rumbling sounds, strong gas odors - these all indicate problems. Do not ignore them.
Hope this helps, remember - these are just rough guidelines and not all possible situations are covered."
Jul 28, 2008 | Sharp CV-P09FX Air Conditioner
LG 50PX5D 50 in. Plasma HDTV Logo
27 people viewed this question
Computer Repairing
Computer Repairing
