My computer and my cellphone can't even read or analyze or open my 8GB SanDisk Micro SD! I can't even format it!
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 108 Answers
I've had this problem with other Sandisk products. Sometimes, using the setup disk supplied with the unit is the only way to get a computer to recognize the unit. Often, once the computer recognizes the Sandisk unit, you can format it and use it reliably. If you don't have a setup disk, the Sandisk site, or others that have the appropriate drivers may help, but I've had less luck going that route. As a last resort, I've gotten a warranty replacement of the Sandisk unit, which usually works.
Posted on Aug 29, 2010
Hi I have 8gb Transcent Micro Sd Card that is encounted a problem when i m downloading using 5130. After that its not opening Its Says that not Formatted. when i insert in to my pc only showed my card...
If there are hidden partitions on the memory card, Windows 7 will not allow you to change the partition. So to format use a PC with windows XP or older. You also could format this card in most camera's. For that place the card in a SD adapter and put it in your camera. Let the camera do the format.
When you put the card back in the phone, make sure you first format the card with the phone software. Just to be sure the phone can read and write the card.
Jan 15, 2014 | SanDisk 8gb Micro Sdhc Memory Card Bundle...
I am unable to format my new 8gb sandisk Can you
click start click on my computer to open you should see your drive
right click then select format
another way
click start control panel administration tools computer management disk management right
click on your usb drive select format
if you need more help with this post a reply
hope this helps you
Sep 18, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I have an 8GB micro sd card for my blackberry storm when i put it in. It says media card has inserted contains errors. to correct the errors use a disk error-checking utility on a computer. what do i need...
The chances on any micro sd card showing errors can be either the files stored in it are corrupted or the card is simply bad already. You may try to identify the problem by performing the following steps.
1· Access micro sd card through a card reader. May it be built-in in a computer or an accessory that needs to be plugged-in to a computer.
2· Wait for a few seconds for the computer to read the micro sd card.
a· If it asked you to "open the folder to view files", do so then copy all contents in a new folder on your desktop. This is to make a backup copy of your files. Then, format the micro sd card with FAT32 format. Copy all files back to your micro sd card.
b· If it asked you to format the micro sd card, most likely all files are corrupted. Try to format the card for re-use. If not successful, your micro sd card is bad already and needs replacement.
I hope this works for you. Good Luck!
Mongkey
"Understanding explains better..."
Jan 30, 2011 | SanDisk 2GB microSD Memory Card
Sandisk U3 Cruzer Micro 8Gb Cant Format :S
rite click on it in mycomputer and click propertys to see if your thunb drive even has memory on it could have ben fried by sum and has no memory now
Nov 07, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Unable to open to read micro sd 8gb in window mobile and pc
just try to clan the connector port (bronze part), clean it with eraser and wife it clean. Not 100% solution, but no harm on trying.
If still not working then I suggest get a new one, your memory card might be corrupted
Nov 02, 2009 | SanDisk 2GB microSD Memory Card
Bought a new Sandisk 8GB microSDHC card (Product Description : Micro SD/8GB SDSDQ-8192-P36M) for my Nokia E51. It worked fine for two months, in this had many times used in PC with my card reader for...
try formatting ur card with the following steps:
right click om my comp then click on manage then disk menagement and right click on ur card then format it will forcely format ur card. gud luck....
Oct 19, 2009 | SanDisk 8GB microSDHC Memory Card with...
SanDisk 8GB microSDHC has an error that tells me i need to format it. so i use Panasonic SD formatter and when the process is done it says completed but when i go to open it up it says it still needs to be...
umm You will get a ready adapter through which you can connect your memory stick to computer directly . Format it ...
I have no idea about panasonic SD formatter . But basically your SD card has a lock to one of its corner . try to unlock it and retry formatting .
This can help you . Bye .
Jul 14, 2009 | SanDisk 8GB microSDHC Memory Card with...
Format 8gb sandisk micro sd problem
Often times, these jump drives have a tiny, nearly invisible read-only switch on them. Check to see that it isn't set to read only, which will inhibit formatting, among other things.
Jun 14, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Formatting troubles for a 8gb Sandisk Micro SDHC
Hi Tony,
Have your My Computer window open and re-insert the card into the reader. If it doesn't show immediately, then right click and choose refresh. It should show up then.
Rob
Feb 27, 2009 | SanDisk 8GB microSDHC Memory Card with...
Can 8GB micro SD be use in SanDisk Fuze 4GB mp3 player?
In order to use an 8gb micro sd, the device has to be SDHC approved. If you don't see an SDHC (Secure Digital High Capacity) logo on the device or on the owners manual, It isn't compatible. It will read up to a 2 gb micro sd card.
Dec 10, 2008 | SanDisk Sansa MP3 Player
Computers & Internet Logo
David Payne
David Payne
