Question about Canon PowerShot A520 Digital Camera
Won't playback most of the time. changed batteries, turned camera on and off. At random times, it will playback. Am able to download to laptop.
    Master:
  • Canon Master
  • 443 Answers
You may need to take it in to the camera place to get the internal batery for the clock replaced also you may need to up load the driver program for the camera
Posted on Dec 26, 2011
My Computer Kepps Turning off!
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Aug 15, 2012 | ASUS Computers & Internet
In playback my camcorder stops and 31:11 flashes. Any ideas?
This most likely means the taps is jammed.
You can try and get the tape to eject. To do this, remove your battery from the back of the camera. Also if your camera has another small battery under the LCD (the size if a nickel) remove it too. Wait 2 minutes. Then, plug the camera in with the power cord. Try changing the camera from playback to record mode. The tape should eject at this point. If this doesn't work, try it again but this time start in record mode and change to playback after plugging it in.
I hope this helps.
Mar 31, 2011 | Cameras
Camera only takes one or two pictures then message tells me to change batteries. Batteries are new and camera turns off.
After surveying the web, I see that this problem has been around for at around 3 years. I use fully charged NiMh batteries and get the “change batteries” message after only a few shots or immediately.
In my case, changing to alkaline 1.5V batteries solves the problem (versus ~1.3V for NiMh or other rechargeables.) Cleaning the contacts (stainless steel) makes no difference.
Interestingly, I can operate the camera in the playback mode and view pictures and movies with no problem. This involves driving the display on the camera back, probably the most power hungry part of the instrument. This suggests the problem is record mode specific.
My guess is that there is a voltage reference problem. References can drift over time, and depending on the initial value, cause problems any time during a camera's life. The reference isn't necessarily needed in playback but is critical for recording should the image sensor voltage be too low.
Jul 28, 2010 | Canon PowerShot S5 IS Digital Camera
Fresh batteries, clear playback, but still won't take a picture
Change the teeny date/time battery--dig it:
http://www.fixya.com/support/t2374899-change_batteries_message_even_new_nimh
I was all set to send my camera off to canon for repair when I happened across that solution. I don't have a replacement on hand, but just removing that battery allows me to take pics again.
Nov 01, 2009 | Canon PowerShot S2 IS Digital Camera
Cq50 laptop touchpad random issue
Remove the battery and the power chord and press the power button for about 30 seconds. Then place the power chord and battery and turn on the system.
Sep 04, 2009 | Compaq Computers & Internet
Canon PowerShot SD 870 IS Movie playback speed is too fast!
You've got it on Time Lapse video. Turn on, slide to video, press func. set button, toggle to standard instead of time lapse. Maybe next time try your owners manual. Of course you all are probably like my mom and just get a new camera, put in the batteries and start taking pictures. These stupid expensive cameras have too many options and get messed up too easily with the wrong press of the button. Try a simple cheap on next time.
Feb 14, 2009 | Canon PowerShot SD870 IS Digital Camera
No playback on DCR-TRV103
In playback mode the lCD displays the battery time, hi8 symbol and the tape counter. all the functions work the tape will play, rewind, fast forward. The screen stays blank on playback and the tape counter stays at 0:00:00 eventhough I can see the tape turning. I also hooke the camera to my tv and I got no picture.
Dec 23, 2007 | Sony Handycam DCR-TRV103 Digital Camcorder
Shooting mode will not operate
Your camera has a defective CCD imager. Please return the camera to Canon in New Jersey and they will replace the CCD at no charge to you. This is a known issue and should be covered under extended warranty. Good luck my friend. Joe Weibel customelectronics.org
Feb 27, 2007 | Canon PowerShot A75 Digital Camera
S5i won't turn on in Capture mode
Hi Aunty Edna. I had exactly the same problem with my S5I 4 weeks ago. Went out and bought another camera then decided had nothing to lose by doing heart segury on S5I. Found it has a watch battery soldered to board under memmory card holder which was flat. I replaced that with a similar battery and it fixed the problem. Its not an easy job but if you know someone good with there hands it would take about an hour.Hope this helps. Regards Andy
Dec 15, 2006 | Pentax Optio S5i Digital Camera
Canon PowerShot A520 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
