Question about Lakewood WC-1600 Floor / Box Fan
How do you clean the fan blades on a lakewood floor / box fan
SOURCE: Lakewood 200I Floor / Box Fan
The fan blade just pulls off. I have a Lakewood 200/1PG and my grills are installed with phillip head screws.
Posted on Jun 03, 2007
bigg t
  • 640 Answers
SOURCE: lakewood floor fan
most likley the set screw that secures the blade to the motor is loose.
Posted on Aug 01, 2007
dodgecharger
  • 254 Answers
SOURCE: cleaned a fan, now it's broken!!!
Is this the speed switch itself? These multi-speed fans have 4 or 5 wires which come from the motor which go into the speed select switch. The wiring may have the ends stripped, and this stripped end just pushes into the hole on the switch, and a little metal piece grips that stripped end.
Anyway, one possibility is to contact the manufacturer- look on their website or give them a call, see if a tech can give that info. Another poss. is to locate an identical fan and note the wiring locations on it. You can also experiment trial and error, though caution needs to be exercised here.
Posted on Jul 31, 2008
SOURCE: need help with fixing my lakewood floor fan.
Throw away the fan and buy a new one.
Posted on Aug 05, 2008
konzzz
  • 255 Answers
try cleaning it and put oil especially at the base of the shaft.then try wiggling the shaft for bushing tolerance.if you feel the shaft wiggles to wide, then you'll need to replace the bushing and the shaft.but before anything else check the thermal fuse.it is found on the motor itself or try to borrow a tester with resistance measurement to check for continuity of the winding by connecting the probes with the plug, one each terminal.then turn the fan on.the pointer should move if its ok, unless burn out.if not.then the thermal fuse blow-out.
Posted on May 28, 2009
How do I clean the Lakewood Tower Fan LWTF-42/RC-DLX. How can I open it to clean the blades
Open the grills and use a long stem tipped with cloth dipped in kerosene to lightly clean the dust. Then use a similar arrangement of dry cloth wound on it to wipe clean the moist dirt. Repeat the process and you will have a clean blade. Use a jet air blower to assist you , use face mask and do it out in the open.
Helpful ?
Aug 20, 2010 | Lakewood 007 Floor / Box Fan
Are replacement motors available for these fans? Lakewood HV 18 Lakewood HV 21 Lakewood HV 21T
mcdevito75 here, If the fan is not too old I would figure yes, but a replacement motor will cost as a new fan, if not more, then you have to install and the blades are a presss fit to the motor.
Jul 27, 2010 | Lakewood HV-18 Floor / Box Fan
Need help with fixing my lakewood floor fan.
May 28, 2009 | Lakewood HV 18-c Floor / Box Fan
Can here motor running but blades do not turn
go and take it apart and clean it afterwards. dont forget to put oil. you might want to check the carbon inside the motor, they may need replacement.
Mar 18, 2008 | Lakewood HV 18-c Floor / Box Fan
Lakewood floor fan
Jun 09, 2007 | Lakewood HV9 Floor / Box Fan
May 27, 2007 | Lakewood 200I Floor / Box Fan
Probably requires cleaning- take the grille off, pull the blade free (most pull straight out- some have a pin/socket deal right behind the blades that need to be removed first) and clean out any gunk you may find inside. Be sure to unplug it first. before replacing the blade, turn the shaft with your hands to see how it moves; you might want to grease it with an electricity friendly lube of your choice. If it's still hard to turn, it may just be this fans time; box fans are cheap, and made cheap, and the wear-and-tear adds up.
May 23, 2007 | Lakewood 200I Floor / Box Fan
Lakewood WC-1600 Floor / Box Fan Logo
Top Lakewood Dryers Experts
Jerry Greenberg
Jerry Greenberg
tfelton3
Jay Finke
Jay Finke
Are you a Lakewood Dryer Expert? Answer questions, earn points and help others
