Question about Kenmore TRIO® 77553 Stainless Steel Bottom Freezer French Door Refrigerator
The ice maker stopped making ice. We still get water from the door and the filter is new.
  • Kenmore Master
  • 43,501 Answers
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Posted on Aug 29, 2010
Ice machine won't make ice! kenmore 363.9537883 bought whirlpool filter 4378411RB water comes out of door but pressure isnt good. Told me i needed a new filter. Is this the problem or something else?
The filter is for water AND the ice maker. The ice maker expects a certain amount of water to flow into it during the fill time. If no water flows at all into the ice maker, then suspect the clock mechanism of the ice maker.
Aug 14, 2016 | Kenmore Refrigerators
Ice maker making clicking noises even though water and ice working
Hi orangebomber, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
Feb 03, 2014 | Samsung RFG297AARS (285 cu ft) Bottom...
No water no ice
Change the=> 67006531 Water Inlet Valve I believe the side of your 67006531 Water Inlet Valve that controls water flow to the ice maker has weakened and cannot open properly. Replace the water valves and I believe the ice maker will work fine, Sea Breeze
Jun 07, 2012 | Whirlpool GX5FHTXVA Bottom Freezer French...
Not making ice after changing filter.
Hi and welcome to FixYa I am Kelly.
A new filter can take several cycles of the ice maker to fill the filter up with water before. The average filter is around 30 oz and the average ice maker fill cycle is 3.2 oz. The new filter did not have any water in it. The water in the door has a resercoir so the air in the filter will still make the water work until you get air. Drain abour 3 tall glasses from the water in door. The ice maker should then work properly. The filter filters water for water in door (inside) and the ice maker so if you have water inside the door you should have ice UNLESS one of the inlet water valve solenoids has failed. Also make sure the Freezer door / light switch functions properly. The door switch is supposed to stop water and ice functions with the door open.
I would like to know if it starts making ice.
Thanks for choosing FixYa,
Kelly
Jul 26, 2011 | Jenn-Air JFC2089HE French Door...
My ice maker stopped making ice all the sudden. there is no water in the ice maker
do you have a water dispensor in the door? if you aren't getting water check the filter. if the water line is not clogged you may have a bad water fill valve or the motor/gear in the ice maker is bad.
Sep 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Not making ice
Hi: Change or just remove the water filter first. As your water dispensing slowed that is a clue. If the water filter is that clogged it will cause a problem with the ice maker. Plus the water you drink is not filtered anymore. City water is being run through 2 years of crud. If you don't replace it just remove it. I hope this helps, Jeff
Jun 03, 2009 | Frigidaire FRS3R5EMB Side by Side...
Ice maker has stopped working. Put in new filter but still no ice. Water dispenser is fine but water will not go into ice maker to make ice. Please advise.
The ice maker has its own valve which is the same part as the water in the door with its own valve as well , replace the dual valve for the fix. It is located where the water line connects.
Phil
Apr 11, 2009 | Refrigerators
GE side by side refrigerator: water/ice dispensor
I bought a brand new smartwater replacement filter and after a very short time, my water stopped coming through the door.. took out the new replacement filter and inserted a brand new one .. problem solved.. apparently some of the g.e. smartwater filter replacement cartridges don't have the high enough two plastic inserts which are attached to them at the top of the filter when you screw them on... if you have taken your cartridge in and out a few times, i think it wears down the plastic so it doesn't fit properly and won't put up whatever it is supposed to push up to make the water come through.. I personally think this is a g.e. problem with the replacement filters...
Jan 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore TRIO® 77553 Stainless Steel Bottom Freezer French Door Refrigerator Logo
205 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
