Question about Coleman Powermate Powermate 5000W Generator
I have an opportunity to purchase a used powermate maxa 5000 er and a used transfer switch that it was used with. it is a 6 circuit type box. i was suprised to see that the generator was old enough that it did not have a twist lock plug on it, but had (2) 240 3-prong plugs. the gentlemen had a cord that someone had made him and one end was a three prong to fit the generator, and the other end was a twist lock to go into the switch. is this ok to use these older style 3-prong plugs? Also, is there any reason that i can't use the used transfer switch in my home? will my electrician refuse to install a used unit? everyting is in good working order, and he only used it a few times, although it is probably 8-10 years old. Thanks for any advice or help...
  • Coleman Master
  • 43,501 Answers
There is no reason not to use the plug... it may vibrate out though...that's what duct tape is for...:-)
The electrician should hook it up,, I would no problem...those tranfers are apiece o cake....
I say go fer it...
heatman101
Posted on Aug 29, 2010
Hi! I have a Coleman Powermate 5000 maxa er plus. It wouldn't start so I check out the air filter, it was kind of dirty and I found gas in it. I cleaned my carburetor with carb cleaner even if it was clean...
The engine is pulling secondary air from the torn gasket area by the sound of it. It can't govern itself like that.
That must be fixed before any further tests !
Aug 19, 2013 | Coleman Powermate Powermate 5000W...
Hello, I'm trying to get an old Coleman Maxa 5000 ER Plus to work again. The interesting problem is that i can get it to start and run, IF i squirt gasoline into the carb throat with a squirt sprayer, but...
First make sure you have fresh gas in the tank, as old gas can cause a 'no run' condition. Once you have fresh gas in the tank, make sure the gas flows freely all the way to the carb by removing the fuel hose from the carb inlet & checking for good flow (bad shut-off valve or obstructed hose by debris could cause same problem). Once you are sure that good, fresh gas is going into the carb w/o obstruction, remove the lower bowl from the carb - carefully - do not lose ANY parts, starting with the washer on the bolt. With fuel flow 'ON', fuel should flow freely when this bowl is removed, so shut off fuel valve in the hose. Now, if you carefully remove the bolt / brass tube from the center of this bowl area (center of plastic float) - remove bolt downward, like you would a lightbulb from the ceiling - this bolt should have several holes in the side, they are probably clogged, so unclog them with a needle or wire, wipe clean, and reinstall. That probably just solved all your problem.... if not, you likely will want to replace the carb completely, as it is not very expensive, and will surely solve your problem. *** Be careful with gas fumes !!! ***
Dec 21, 2010 | Coleman Powermate Powermate 5000W...
I have a 5000 w maxa ER generator that has a battery assist added ( PM 0525312.17 ) Question...Is the battery a regular 12v car battery, or maybe a lawn tractor battery?? Once the generator is started...
Replace battery with your choice of 12v products considering physical size, amp range and warranty. Lawn tractor batteries seem to have the least life/duty cycle. There are two methods of charging the battery used by Coleman. One is to charge the battery with charger/alternator coils installed under flywheel of the engine and second is to charge with built-in circuit in generator itself. Examine your wiring diagram to discover which you have. Simple test with volt meter will show if system is charging. Test voltage at battery with engine off, then start engine and retest looking for slightly higher voltage indicating charge. The charging system is like a trickle charger and not like your auto with initially high amp charge then taper to minimum. If your run your generator for long periods of time and you feel that the battery is being overcharged, then rig a switch to stop charging after one hour or longer. Good holiday
Nov 27, 2010 | Coleman Powermate Powermate 5000W...
It is not a problem like to know if i can use my coleman 5000 maxa er plus 10 hp. With A welder with out damage it. Tanks
Yes, you can use a welder with it. Pay attention to the ratings of the welder, don't exceed running watts of the generator. It would also be a good idea to try and use a welder that is less than the running watts rating of the generator. Then you would have some extra capacity to deal with fuel quality, maintenance history, momentary undervoltage, altitude, etc.
Jun 20, 2010 | Coleman Powermate Powermate 5000W...
How do you convert the (2) 240 volt outlets to one twist lock connector on a coleman powermate maxa 5000 er genset
Make an Umbilical recepticle adapter. Buy the recepticle install the recepticle in a 4" electrical BOX on a plate with two manufactured 3 prong power cords plugging into the 2 outlets and terminating at the new Box twist lock recepticle you made.
Feb 09, 2010 | Coleman Powermate Powermate 5000W...
Powermate Maxa 5000 er will not run stably
Check the fuel filter. My company designed hybrid generators that are far more efficient. They use batteries to power your equipment, and the generator runs intermittantly to recharge the batteries when needed.
If you would like to convert to hybrid, contact me at buffalonymann@yahoo.com
Sep 24, 2009 | Coleman Electrical Supplies
Coleman Powermate Powermate 5000W Generator Logo
202 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
