Question about Kenmore 22422 Top Load Washer
Kenmore top loader washer
The machine filled will water & went thru all the cycles, but when it comes time to rinse it does nothing, just out of the blue it did this. Is there something I can check or do I have to get something replaced?
  • judy666 May 10, 2008
    That fix the problem!!! Cking the lid switch!! Many Thanks for having
    "FIXYA" it's the best!! Will be refering other folks to this site for sure!!
    Scholar:
  • 150 Answers
Check lid switch
Posted on May 07, 2008
  • andrew kinslow May 10, 2008
    cool make sure you rate me I have given advice that went over the heads of the askers and got poor ratings because they didn't have the capacity to understand my advice. was at guru status but it fell to wiz. glad I could help
Rinse cycle not working on Kenmore 600?????
sounds like a program prob not familiar with this mech but it seems suspect
Mar 01, 2015 | Kenmore 600 3.5 cu. ft. Top Load 110-2962...
I filled my washing machine with clothes tonight and it got to the end of the short cold wash cycle and had stopped running so I pushed in the knob then pulled it back out and then pushed it back in and...
It sounds as if the machine doesn't spin during the spin cycle. Normally the agitator stops spinning, fairly quickly, if the lid is opened during the spin cycle.That safety circuit includes a switch mounted under the opening and is set by a tab on the lid that protrudes thru a small hole in the top of the washer. The most likely failure on most Kenmore models is that switch, broken or loose, the tab on the lid broken, or the two misaligned. I would need the model number of your washer, located on a tag on the bottom of the lid to be more specific
Jan 07, 2010 | Kenmore Washing Machines
Kenmore 80's series top loader only works on wash and rinse cycle
This is a problem with the pump being stuck so the motor cant turn the whole thing. Turn the washer on its side, underneath you can acces the pump, which is connected to the motor by two long clips. remove the pump and take out the colg that caused it to get stuck.
Jul 01, 2009 | Washing Machines
Kenmore will not agitate
The timer is the most common problem. Call any appliance parts store and tell them the model number and ask for price for new timer. Also call sears appliance parts and get price. But a new timer and install it.
Apr 15, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer quit working
it may be waiting for a faulty heater to kick in. try it on a cold water wash, no heat and see if it continues the full wash. if it does not then it may have a faulty timer.
Mar 16, 2009 | Washing Machines
Kenmore washer not draining/also getting stuck doing nothing
i had my kenmore washer doing the same,looked at water pump but nothing was stuck inside ,i tried the lid switch and stuck a screwdriver in it to see if this would do the trick,nothing..but when i took it out, i could see where it had come apart...took it out and decided to use gorilla glue and clamp it back till the glue dries,before the glueing process ,i test the draining outside with a buckett..and bingo,it started draining the water,i only had the switch crimped with my fingers and at the same time pushed the switch down ,it worked..draing started..hopes this helps
Mar 15, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer won't drain or spin
top loader ??? or front loader??? if top loader you have broken your lid switch, will fill, agitate, but when it comes to drain/spin for safety reasons if the unit doent recognize the lid closed it will not advance...if yo have a front loader then i would suspect that something has gotten into the pump assy and preventing drainiing of water therefore will not spin
Mar 02, 2009 | Kenmore Washing Machines
Kenmore 22956 top loader quit running after agite cycle
If the timer cycles your lid switch is ok.
most likely: motor Switch (on Motor), condenser next to motor, motor itself, or wiring going from the time to the switch,
It is probably cost efficient to replace the unit rather than trowing parts at it .
AB
Apr 06, 2008 | Kenmore 24032\24036 Top Load Washer
Washer filled with water & then stopped & will not work in any cycle.
could be a bad pressure switch did it fill all the way is it a top loader or front loader any noise or nothing
Dec 31, 2007 | Kenmore 24622 Top Load Washer
Kenmore 22422 Top Load Washer Logo
Sal De
fordexpert
 Brian Main
Brian Main
