Question about Denon AVR-1601 Receiver
I cannot get my surround sound to work, is there a fuse ar reset?
  • Denon Master
  • 17,129 Answers
Choose the surround on the remote control to switch on . If the display comes on without the speakers not responding, check the speakers, if not the surround section output IC is faulty. There is fusible resistors in the power supply to the IC, So if there is no voltage on the surround IC, then check and trace back.
If the fuse blows then the IC is faulty.
Posted on Aug 29, 2010
Reset timer on tv and why surround sound doesnt work when int use to
The Timer and Sound are two different options and neither one should interrupt normal operations. You should open the TV Manual and follow the directions on setting up the Surround Sound. Forget the timer for now. When you get the Surround sound feature back....see if all functions work in concert. If the Surround fails after reestablishing the proper format; you may need to contact technical services at Panasonic. Have them walk you through the process.
Dec 19, 2013 | Panasonic Televison & Video
Sharp ar 5516 maintenance reset
sharp ar 5516 showing ( - - - ) what's the solution
Sep 02, 2012 | Sharp AR-5316 Advanced Digital Imager...
My kenwood is only playing sound from the front 2 speakers the center and surround is not working. is there a fuse inside i can change? what do i need to do?
Not a fuse. Go through all the setups and speaker definitions or maybe just find that pesky "stereo" mode switch and reset it to something that allows all the channels to operate.
Jan 22, 2010 | Kenwood KRF-V5100D
Problem for Sharp AR-5320
The Fault fuzer. Possible faults of the block of the fastening the scene or in contact of the join or in signal of the controller of the direct current.
Address please in service Sharp
H2 00 Fusing unit temperature error 01 Fusing unit temperature error H3 00 Overheated fusing unit 01 Overheated fusing unit H4 00 The fusing unit doesn't heat up 01 The fusing unit doesn't heat up H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error
Oct 08, 2009 | Sharp AR-5320 Black and White Copier
5.1 Surround sound not working
Maybe the surround processor is having a bad day... My kenwood would do similar and a reset was necessary to correct. Have you tried resetting the system? On my Sony STR DE 597 this is accomplished by powering off. Then while holding the 2 channel button down (front face plate) power on. A reset message is displayed. Your model may be similar but check your manual or download the PDF of the manual from Sony's support website. Hope this helps
Sep 05, 2009 | Sony STR-DE685 Receiver
Sharp AR-5127 H2-00 code reset
Sharp Fuser
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
You have to reset fuser errors with simulation 14. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
Feb 01, 2009 | Office Equipment & Supplies
My xbox 5.1 SPHEREX SURROUND SOUND SYSTEM DOES NOT WORK NO POWER
my bfs did this same thing he went to radio shack found the fuses replaced them and boom works great its been workin over a yr in half now no problems
Jan 10, 2009 | Spherex Xbox 5.1 Surround Sound System...
Xbox 5.1 surround sound not working. not coming on at all
so no power at all ?? then u might want to check the fuse in the back and are cheap my bf had this problem bought fuses and works like a charm for over a yr in a half
Dec 28, 2008 | Spherex Xbox 5.1 Surround Sound System...
How to get surround sound workin with ps3 and tv
you have to select the dolby surround button from the remote to get the sound
Dec 25, 2008 | Panasonic Home Theater System System
Denon AVR-1601 Receiver Logo
136 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
