Question about Polaroid FLM-3734B 37 in. LCD HDTV
No picture after overnight off
I cant get picture back on after overnight off. I must use a power bar to off the tv and then turn back on. I have cable box for high channels and a remote programed to turn both tv and channel selector back on
    Sergeant:
    Champion:
  • 362 Answers
Sounds like your standby controller is going out the problem is with polaroid its a board replacement video board.
Posted on Jul 01, 2008
    Problem Solver:
  • 9 Answers
Which model
http://www.fixya.com/support/t293971-37_polaroid_lcd_tv_turn
Posted on Jun 27, 2008
LG 55LE5400 LED TV will power up, but only shows black screen with no picture and no sound. Any ideas?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Jun 11, 2016 | LG 55LE5400 TV
Cant get tv to turn on
Try leaving it out of the power overnight. Also, check all the cable connections.
Apr 05, 2008 | Ultra LCD30-500 Television
My LTV-32w6 westinghouse powers on & has sound but displays black screen with very faint colored vertical lines. It shows like this for about 1min before it goes into standby mode & the blue power...
Depends on what is causing it...
Vertical bands of faint black are generally caused by filtering capacitors and can be found in the power supply or the 5 volt supply or even the Video processing circuit...it is not an easy task to identify the source of Video hum bars.....we also call them Jailbars.
Another problem seen is faint black lines caused by the TV set being in 4:3 mode all the time....right at the edge of where the picture ends and the black pillars begin, we see a faint black line that never goes away and is normally seen with a full screen....
That is actually image retention, but it's caused by the crystals that create the picture becoming polarized or ionized over a very long period of time....and it's not easy to DE-Polarize them !
But there are some theories out on how to do that....
Certain people suggest running the TV overnight with an ALL-WHITE picture and some suggest an ALL BLACK PICTURE...and some suggest alternating between both !!
Now, a black picture is easy to make, you just deactivate the Video Mute (blue screen) and set it to an unused Video INPUT overnight....
About the only way to make a white screen is to use the USB port for pictures and take a very bright outdoor shot of a piece of white paper that hopefully is out of focus too....That would create an all-white picture that you can plug into your TV set overnight....
Now if you decide to try this, deactivate any displays on your TV set...all you do is press the display button until the Video and/or USB input numbers disappear....
Next day , set it back to normal TV and see if it's gone or if it's REDUCED....try it again if needed, or try the exact opposite if you see NO RESULTS....
Sep 20, 2012 | Westinghouse Televison & Video
LG 32LH30 screen won't power up. Red light at bottom glows hi to low, but no picture. Unplugged and waited overnight, plugged in again, still no picture.
There is a way to tell if you have a bad board, or a bad panel.
1. Make the room dark and turn on the TV. Can you see it light up? If so, does it stay lit or turn right back off?
2. If the panel lights, but you have no picture, I would suspect the T-con. Some units now have the T-con incorporated with the main board, so you will need to check.
3. If you never get any light at all, then I would suspect the power supply.
4. If you only get light for a second or two, then you have a bad panel.
Apr 10, 2012 | LG 32LH30 32 in. LCD HDTV
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
After power outage tv won't turn back on.
Its not a matter if it sitting, it got a power surge that did some damage to the power supply...might be as simple as a fuse
Dec 04, 2017 | Hitachi 60UX54B/55K 60" Rear Projection...
Samsung HP-R5052 Plasma TV
It related with Power Board(50%) or Y-Main(50%).
But, if you use the power bar with surge protacton, need to check
the power bar's lamp when the TV is turning on & off.
Jan 31, 2009 | Samsung HP-R5052 50 in. Plasma HDTV
Sabre 42 in plasma tv stuck on component 1
remove the power from the wall and leave the TV off for at least an hour, the static charge may have shorted the circuit board for the pront panel controlls.
after an hour or so plug it back in to see if has reset itself
hope this helps
regards
Nov 27, 2008 | Televison & Video
SONY WEGA TRINITRON
power cord disconnect cable overnight try next morning power bar to not good for life especialy if you got lot off stuff on it cheers
Jan 06, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
TV picture goes out and then comes back, TV eventually turns off
Probable bad DM module = repairable by qualified Mits.tech.....
Nov 13, 2006 | Mitsubishi WS-48613 48" Rear Projection...
Polaroid FLM-3734B 37 in. LCD HDTV Logo
42 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
