Question about Microwave Ovens
Gas oven - Microwave Ovens
  • Microwave Ovens Master
  • 43,501 Answers
Just because it glows that does not mean it is not bad...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Aug 29, 2010
Maytag oven will not heat, no gas flow. Broiler works, clock and timer works.
You may even see the orange "glow plug" (called a hot surface igniter) glowing orange and so assume that it's OK. Not necessarily!! You have to measure the current/amp drawn by the igniter and compare it to this repair sheet before you can say it's OK or not. The gas valve has a bi-metal that open when a certain amount of current flows through it to heat it up. The igniter is wired in series with the gas valve. As the igniter gets older or weaker, it's resistance increases to the point where not enough current is flowing to the gas valve bimetal to open it up. As a result, the gas valve never opens up. BTW, a common symptom of the early stages of this problem is erratic temperature control in the oven due to delayed firing of the bake burner while cooking.
The hot surface igniter will not come on - check igniter with a ohm meter, you should have continuity through the glow bar, the glow bar can also crack = new igniter time. The glow bar comes on but the main burner will not light - you should have an amp probe to check properly, but often this is a hot surface igniter problem. The hot surface igniter often looses it's ability to get hot enough to open the gas safety valve. The safety valve can fail, but most times it is just a bad hot surface igniter. The hot surface igniter can also quit part way through cooking , in other words the oven may cycle a couple of times and then it just sits there with the red glow from the igniter. See this service sheet for the proper way and amp readings for the hot surface igniter system. Hot surface igniters do weaken and will eventually generate less heat than they normally could. When this happens they can still allow marginally correct current to flow to the oven gas valve for it to open but not get quite hot enough to ignite the gas burner immediately. When this happens, gas released into the oven can sometimes build up to the point where when finally ignited, the amount of gas lit can cause a small explosion inside the oven or cause an odor of gas with out the oven working. Yes, your glow bar igniter can glow orange-red and still be bad!! How a common gas valve works - click here.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 13, 2011 | Maytag Microwave Ovens
My gaffers sattler gas oven stopped turning on. can not smell any gas when i turn it on.
heatman101
Jul 25, 2011 | Microwave Ovens
The oven is gas - the top burners light, but the oven doesn't heat and appears to not be getting gas.
heatman101
Jun 25, 2011 | Microwave Ovens
I have a range master 110 clasic 2007 when the small oven was switched on a fan would come on. my engineer says that this model has no fan because it is gas.
I have a Rangemaster and like yours is dual fuel. Gas hob and electric oven. The large oven is fan assisted but the small oven, on the right hand side of the range) is self cleaning and not fan assisted.
Hope that helps.
http://www.pricerunner.co.uk/sp/rangemaster_classic_110.html
Mar 31, 2011 | Microwave Ovens
We want replace to exsisting oven do we need an electrician?.
"We want replace to exsisting Problem with the Microwave Ovens we want replace to exsisting oven do we need an electrician?."
Not if the microwave oven plugs in.
In England and Wales, household appliances that are "Wired" in require an electrician connects it to the wall point and for Gas, an authorised Gas Safe engineer should install it.
Feb 02, 2011 | Microwave Ovens
Hi, got old Eurolec Gas oven/hob. Hob lights up fine. Was cooking in oven all morning, no probs. Tried to light oven for evening meal & gas will not stay lit, goes out once ignitor & temp' dial...
Hi, your thermocouple is faulty, it is the little probe like thingy that sticks up into the pilot flame. It is there for safety purposes, detects flame and holds a valve open magnetically to allow the gas to pass through. Try giving it a clean with a scourer, sometimes works, or your pilot flame is not big enough, could be low on gas or unit needs a service Kristian KJ Tech
Sep 15, 2010 | Microwave Ovens
Oven will not light
Go to partselect.com and look for a ignitor.
When on this site... you will be asked to put in you model # which you will find in the drawer below oven.
This is a very simple project which should be about half hour to replace.
No electrical to turn off, no gas to turn off. Just a screwdriver, and the job is finished
Jul 29, 2010 | Kenmore 80412 Microwave Oven
20" gas stove: has pilot light in oven, oven lights but then after several minutes will turn off. do not smell gas after it turns itself off. Using 3/8" gas line. Please advise as to potential problems...
The oven igniter should stay on constantly as long as oven control is calling for heat and not fade off. If the igniter is too weak and not pulling enough current it may not open the gas valve correctly and gas will be let out of the gas valve and not igniter.
The likely failure is a weak oven glow bar igniter. I recommend calling a service technician to diagnose and repair your range.
Hope this helps .
Apr 21, 2010 | Microwave Ovens
We have a 6 burner, nat gas cooktop....all unit light but the igniter clicking will not stop...unplugged it . question: all mechanics are closed is this safe gaswise?
What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame. Once the set temperature is achieved the control stops all power to the ignition circuit which causes the ignitor to dim and the oven gas valve to close, stopping any burner flame. Cycling on and off continues to maintain the specific temperature the control is set for.
Jan 09, 2010 | Microwave Ovens
Microwave Ovens Logo
20 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
