Question about Singer Sewing Machines
Singer HD 110 C needle bottoms out and will not allow wheel to turn complety
  • 4,924 Answers
OK ..from what you say I understood that the back end of the needle is out too far and when you turn the wheel it is blocking cause in this case the needle is too long ..and it is stopping in something inside..
the thing to do is to unscrew the side needle screw...take out the needle ..(even change it if you have another one ..cause this one might be bent ..)
after that take a look at it ..and see that on one side..the bottom it is flat ...and the other is rounded...The flat side it has to be facing the machine...the arm ...and the rounded side in exterior..and this way it has to be pushed up ..thill the end...and after that tide up the side screw to hold it there ...if you positioned it well and pushed it all the way up ..now the machine will not block anymore..
Posted on Aug 29, 2010
Singer 5532 needle hitting plate how do I fix this
Welcome to sewing. First guess is the needle is loose or got bent. Remove the needle and roll it on a flat surface to look for bends. Although, it would need quite a bend to hit. Jeans require a 110 or larger needle. If the motor strains when crossing the heavy folded areas turn the wheel by hand - you will then know why the motor was straining. Also, sometimes multiple layers require using a seam ripper tool to unsew and then cut out excess layers. It all takes time and patients. Keep at it it's worth it. Consider downloading the manual and carefully review to make sure the machine is threaded right - common beginner mistake.
Feb 10, 2015 | Singer 5532 32-Stitch Heavy Duty Sewing...
The bobbin thread will not raise with the needle
1. REPLACE NEEDLE W/FLAT PART AWAY FROM YOU.
2. MAKE SURE THE TOP THREAD IS PROPERLY THREADED.
3. INSURE BOTTOM BOBBIN IS ROTATING RIGHT DIRECTION. (USUALLY COUNTERCLOCKWISE) ALLOW THREE INCHES OF THREAD PULLED AWAY.
4. HOLD TOP THREAD W/LEFT HAND AND ROTATE HAND WHEEL TOWARDS YOURSELF. DOES IT BRING THE BOBBIN THREAD UP?
5. IF THE BOBBIN CARRIER IS INSTALLED PROPERLY THE HOOK (POINTED OBJECT) UNDER THE BOBBIN SHOULD "HOOK" THE TOP THREAD AND BRING THE THREAD AROUND THE BOBBIN THREAD. THE NEEDLE AND TOP THREAD SHOULD BE PULLING THE BOBBIN THREAD UPWARDS. IF THE HOOK DIDN'T "HOOK" THE NEEDLE THREAD THE PROBLEM IS THE DISTANCE OF THE NEEDLE AND HOOK APART OR THE TIMING. YOU MAY TRY TO MOVE THE NEEDLE TO THE LEFT SIDE AND AGAIN TRY ROTATING THE HAND WHEEL. IF IT DOESN'T WORK THEN TRY TO MOVE THE NEEDLE ALL THE WAY TO THE RIGHT AND ROTATE THE HAND WHEEL. IF IT BRINGS THE BOBBIN THREAD UPWARDS IN EITHER CASE IT WILL SHOW A PROBLEM WITH TIMING. THIS WILL NEED TO BE ADJUSTED BY A PROFESSIONAL.
6. REMEMBER TO PUT ONE DROP OF OIL ON THE RACE TRACK BEFORE YOU PUT THE BOBBIN CARRIER IN.
Jan 13, 2015 | Singer HD-110 Mechanical Sewing Machine
How to insert the bobbin case on
Download the instruction manual for your machine free at the Singer sewing machine site. It is pictured on page 14, and explained on page 15.
The flat part is designed to go under the needle; there is a projection that sticks out on the right towards the bottom that is designed to go against a silver tab to prevent the case from spinning while in operation. It is helpful to insert it so that the flat part is slightly clockwise of where it is supposed to be, then turning it counterclockwise into place. Make sure the case is level in the basket.
Jun 20, 2014 | Singer HD-110 Mechanical Sewing Machine
Hd-110 can't pull up the bobbin thread
If the needle will not catch the bobbin thread, try replacing the needle and make sure the flat side of the needle shaft is facing the back of the machine.
Always thread a sewing machine with the presser foot up.
Lower and raise the threaded needle, while holding onto the end of the thread. This will pull up the bobbin thread.
Take both thread ends under the presser foot and to the back of the sewing machine.
Hand Walk the needle a couple of stitches before using the power pedal.
Mar 19, 2010 | Singer HD-110 Mechanical Sewing Machine
Can't get the bobbin case back in on my singer hd 110. It came out on it's own. The manual is not very helpful.
If this is a vertical/metal bobbin case; raise the needle to it's highest position. This will position the shuttle to accept the bobbin case.
If the bobbin case has a lever on the back, lift it and hold it open as you place the bobbin case back into the shuttle. It should click into place.
Mar 14, 2010 | Singer HD-110 Mechanical Sewing Machine
Singer 7442, how do I adjust the timing?
Have you changed your needle? What needles are you
using?Other than that it may be that your needle may be
too high and not in the right position. So I would
play with maybe bringing it down a little bit at a time -
and hand turn your wheel.
Feb 12, 2010 | Singer Quantum 9920 Computerized Sewing...
Singer Sewing Machine I have thread the machine and everything works when I turn the small wheel in the center of the big wheel. But, when I press the peddle, the big wheel just spins and doesn't move...
Singer has just installed new Q&A features on their website. You can go here: http://new.singerco.com/products and look for your particular model. At the bottom of the product page, you can post Questions for singer experts and other community members to answer!
Jul 11, 2008 | Singer 7442 Mechanical Sewing Machine
Singer 7442 - Needle hitting bottom
FIRST DETERMIN NEEDLE BAR POSITION TURN STITCH REGULATOR TO LARGEST STITCH, THEN TURN HAND WHEEL TIL' NEEDLE IS ABOUT TO ENTER NEEDLE PLATE.
AT THIS POINT THE FEED DOGS SHOULD BE JUST AT OR JUST UNDER PLATE. IF SO NEEDLE BAR IS, IN CORRECT POSITION,AND TIMING WILL BE SET AT THE HOOK.
TO SET TIME REMOVE NEEDLE PLATE TURN HAND WHEEL SO NEEDLE IS IN LOWEST POSITION. USING A SMALL RULE RAISE NEEDLE BAR 3/32 OF AN INCH ( OR 3 MM FOR A METRIC RULE) .HOOK POINT SHOULD BE IN CENTER OF NEEDLES WIDTH. LOOSEN THE 2 SHAFT SCREWS
SLIGHTLY,TURN HOOK TIL CENTER OF NEEDLE. TIGHTEN SCREWS. IF NEEDLE BAR IS OUT OF TIME. BRING HOOK TO CENTER OF NEEDLE AND LOOSEN SCREW IN LEFT COVER. RAISE OR LOWER NEEDLE BAR TO SET 3/32OF AN INCH. THE 3/32 MUST BE VERY VERY CLOSE.
Nov 26, 2007 | Singer 7442 Mechanical Sewing Machine
Sewing Machines Logo
27 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
