I have a philips tv mod # 55pp9401 the orginal remote got broken, bought a harmony advanced remote. need to know how to adjust color, and everything is showing double. there is a yellow and blue line across the screen.
  • jhanshew May 08, 2008
    It's a harmony advanced universal remote 550
  • 13,433 Answers
Hello
I beleave its a problem with your tv and not with the color settings.
I would call in a repair tech to check the status of the tv.
Posted on May 08, 2008
    Genius:
  • 3,422 Answers
Can you please give the make and the model no. of the remote
  • 1 more comment
  • Priya darshan May 08, 2008
    ok,just hold on..will let you know if there is any manual..
    Ok,
    here is a solution.Did you get a user manual with it?
    The user manual for your remote can be accessed when you login to your account.
    To access your user manual:
    1. Log into your account in the Harmony software,
    2. On the right side of the screen click on More Help in the Tip Center.
    3. In the new window which opens, click the 'User Manual' tab.
    4. Click on the User Manual link.
    5. The PDF of the user manual for your remote will then open in the software.
    In addition, you can find a user manual by doing the following:
    1. Go to the main Logitech Support page.
    2. Select your product (ie. Harmony Remotes > H-880) from the Product drop-down list.
    3. Type the word 'Manuals' into the search field and click the Search button.
    4. Your user manual article will be returned.
    You can also get one by emailing them...
    My solution no. is 2 so if you want to accept my solution as fixya then please only rate the sol. no. 2
    I think you've accepted the other experts solution instead of mine.
    if you want to rate me then change your rating..
Can't get colors right projection tv
Go into menu with remote and select convergence--see if skewed will it adjust or not?
Apr 27, 2012 | Philips 55PP9401 55" Rear Projection...
We no longer have the remote for model 55pp9401 and we have a convergence problem what can we do
Here's the Philips support URL for your TV:
www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=55PP9401&slg=en&scy=US
PDF download of your Owners' manual:
http://download.p4c.philips.com/files/5/55pp9401/55pp9401_dfu_aen.pdf
Here's what Philips FAQ says about your convergence procedure:
Question How do I adjust convergence (align colors)? Answer Note: For best results, the Projection TV needs to be turned on for 15 minutes or longer before adjusting the picture tubes (convergence).
Press the INTELLISENSE button on the remote (under the flap). During the convergence process DO NOT press the INTELLISENSE button again and DO NOT move the Projection TV.
So, I think you're going to need to order a replacement remote.
search "replacement remote" at http://www.philips.com
May 13, 2011 | Philips 55PP9401 55" Rear Projection...
We just bought a new TV...what do I need to do to make my Logitech Harmony Remote work with it?
Hi. You will need to add your new TV in to the software. If you do not have the Harmony Remote Software, you can download it at http://logitech.com/myharmony.
Once you have the software up and are logged in, click 'Devices' at the top and then 'Add Device.' Once your TV is added, click 'Update Remote' for the settings to be transferred onto the remote.
Apr 24, 2010 | Logitech Harmony One Advanced Universal...
Broken harmony one remote
Logitech does not repair Harmony remotes, however if it is still in warranty you can have it replaced. I would just send them an email.
In the software's 'Tip Center' click 'Support'. Click on the 'Contect Us' tab and click 'Email'. Describe that the button has fallen off, and be sure to include your Harmony login ID, and the PID of the remote. The PID can be found under the battery cover.
If the 'Email' button does not appear in the software, then your warranty is expired.
Hope that helps.
Apr 09, 2010 | Logitech Harmony One Advanced Universal...
Philips 27ps55 s321 tv remote problem
bought a new universal remote control of phillips
Jul 05, 2009 | Philips 27PS55S 27" TV
Magnavox energy saver projection tv-cannot remove closed caption
If you can bring up the FEATURES menu and can navigate with the Harmony remote scroll down the the CAPTIONS options. If you can turn display OFF then you should be all set.
If you do not have the manual for this set you can see it at:
http://www.p4c.philips.com/files/5/55pp9401/55pp9401_dfu_aen.pdf
Feb 27, 2009 | Philips 55PP9401 55" Rear Projection...
Philips tv
the problem you are describing is your convergence ic's are bad you need to replace them both...you need 2-STK392-120's you can get replacements at this link i posted as well as picture installation instructions and free online tech support
http://servicemanuals.vstore.ca/
May 08, 2008 | Televison & Video
Where can i buy remote control for phillips 55pp9401?
get a full universal at your local walmart for less then 20 with full menu and program functions, get a phillips brand and no programming required.
Mar 16, 2008 | Philips 55PP9401 55" Rear Projection...
Philips 55PP9401 ProjectionTelevision
it seems as you need your tubes re-alinged dont get riped off by tv experts saying it will cost you loads if you have a screw driver and a gentl touch just re focus your red green and blue-simple cost you nothing
Aug 08, 2007 | Philips 55PP9401 55" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
