Question about Sharp UX-B20 Plain Paper Inkjet Fax
Sharp UXB-30 Fax Machine
Hi, I have a problem with print quality. I have installed a new cartridge, aligned it, and cleaned the nozzles several times along with the roller and glass panel. Still the print quality is patchy. Please help??!!
    Problem Solver:
  • 7 Answers
I'm not familiar with this unit. Make sure you are using the original cartridges and not "compatibles." They claim to be the same but they are not. There are some that are fine but their consistency changes all the time. If you are using the right cartridges then it may be the head that's clogged. The head in your unit may or may not be replaceable. If it's a bad clog, the cleaning process will not help. Manually cleaning these nozzles is not recommended because they can be damaged easily.
Posted on May 07, 2008
New black cartridge horz lines cleaned head &cartridge roller ; bought new cartridge still lines
Try to clean the print cartridge nozzles:
  1. On the printer control panel, press Menu.
  2. Press the down arrow button until you highlight Clean Cartridge. Press Select. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
  3. Print the document again to verify that print quality has improved.
  4. If print quality has not improved, try cleaning the print cartridge nozzles up to two more times.
You can also try to align the cartridges:
  1. On the printer operator panel, press Menu.
  2. Press the down arrow button until you highlight Align Cartridge. Press Select.
Jul 28, 2011 | Lexmark P4350 All-In-One InkJet Printer
I have an HP 2140 fax purchased one year ago. I have never replaced the catridge and have used the fax about once a month. Today I am trying to copy and it won't print. I cleaned the nozzle and still...
New cartridge wouldnt print but sounded like it was printing. You can check ink levels clean or align cartridge by pushing menu then tools. I cleaned contact points w qtip and alcohol. What seemed to work is putting alcohol on cartridge where ink is released and putting back into machine wet did this three times first time little dots of ink then a faint print and now it is printing must have been dried ink further then I could access.
Apr 12, 2011 | HEWLETT-PACKARD HP 2140 Fax
My fax machine states 'fax RX in memory' and does not receive any faxes?
There is a Fax in memory. Either, the machine has a paper jam, is out of paper, or needs the ink cartridge replaced. Fix the above and the fax will print and the machine should work in Fax mode again.
For a unit with paper and no paper jam, try adjusting the paper stack and check if the unit picks up the paper properly. If you have ink in the cartridge, try cleaning the print nozzles and contacts. If a nozzle cleaning from the unit doesn't work, do it manually. Use a damp cloth (lint-free) and wipe in one direction only. Dampen the cloth with bottled or distilled water for best results. See your manual for pictures.
If you need the manual, try the Sharp site or http://www.retrevo.com/support/Sharp-UX-B700-Fax-Machines-manual/id/310bh149/t/2/ .
I hope this helps.
Jan 14, 2011 | Sharp UX B700 Plain Paper Inkjet Fax
MY LEXMARK 4505 LEAVES 3-4 BLACK BLOTCHES ON THE EDGE OF EACH PAPER IT PRINTS, TRIED CLEANING THE ROLLERS TO NO AVAIL, ANY SUGESTIONS
ADJUST THE COLOR AND PRINT SPEED You may need to adjust the color and print speed. CHECK THE LEVEL OF INK IN THE PRINT CARTRIDGES 1 From the Finder desktop, double-click the Lexmark X5400 Series folder. 2 Double-click the Lexmark X5400 Series Utility icon. 3 From the Maintenance tab, check the ink levels of the cartridges. If an exclamation point (!) appears on a cartridge, the ink level is low. Install a new cartridge. Improving print quality These are possible solutions. Try one or more of the following: CHECK PAPER • Use the appropriate paper for the document. If you are printing photos or other high-quality images, for best results use Lexmark Photo Paper or Lexmark PerfectFinish Photo Paper. Do not use Lexmark Premium Photo Paper. Your print cartridges are not compatible with this type of paper. • Use a paper that is a heavier weight or bright white. CHECK PRINT CARTRIDGES If the document still does not have the print quality you want, follow these steps: 1 Align the print cartridges. For more information, see "Aligning print cartridges" on page. If print quality has not improved, continue to step 2. 2 Clean the print cartridge nozzles. For more information, see "Cleaning the print cartridge nozzles" . If print quality has not improved, continue to step 3. 3 Remove and reinsert the print cartridges. For more information, see "Removing a used print cartridge" on and "Installing print cartridges" . If print quality has not improved, continue to step 4. 4 Wipe the print nozzles and contacts. For more information, see "Wiping the print cartridge nozzles and contacts". If print quality is still not satisfactory, replace the print cartridges. For more information, see "Ordering print cartridges". CHECK PRINT CARTRIDGES If the document still does not have the print quality you want, follow these steps: 1 Align the print cartridges. For more information, see "Aligning print cartridges" on page 124. If print quality has not improved, continue to step 2. 2 Clean the print cartridge nozzles. For more information, see "Cleaning the print cartridge nozzles" . If print quality has not improved, continue to step 3. 3 Remove and reinsert the print cartridges. For more information, see "Removing a used print cartridge" and "Installing print cartridges" If print quality has not improved, continue to step 4. 4 Wipe the print nozzles and contacts. For more information, see "Wiping the print cartridge nozzles and contacts"
Nov 10, 2010 | Lexmark X5495 All-in-One &USB...
Photos print with a faint 'pinstripe' effect
that could be head alignment (most noticible on low quality settings .. there is a procedure for aligning the heads ... or it could be clogged nozzles
to check these things start to print something
then select preferences .. then maintainence then
you have a choice .. nozzle check should be done first .. if all nozzles are working then go to "head alignment" and follow instructions there .. if some nozzles are not working then run the "cleaning" utility . sometimes it needs to do that several times .. if you cant get all nozzles working then you can try "deep cleaning" that uses lots of ink so you dont want to do that often ... if that doesnt work then you need new heads .. the heads in many pixma printers are easily replacable but costly ..
if all the nozzles are working and head alignment was done but you still have faint lines then try "high quality mode" .. in that mode you should not see any lines ..
Dec 23, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
My Lexmark Z 515 printer does not print clearly especially the second part of a piece of paper. How can I clean the printer?
To improve print quality
1 On the operator panel, press Options repeatedly until
Cartridges appears.
2 Press the right arrow button until Align appears, and then press
Select.
An alignment page prints. Once the alignment sheet prints, your
automatic alignment is complete.
You may need to clean the print cartridge nozzles.
Using the operator panel
Load paper in the All-In-One.
2 Press Options until Cartridges appears on the display.
3 Press the right arrow until Clean appears on the display.
4 Press Select.
A nozzle page prints forcing ink through the nozzles to clean the
clogged nozzles.
5 Print your document again to verify your print quality has improved.
6 Try wiping the print cartridge nozzles and contacts, and then print your document again.
7 If print quality has not improved, try cleaning the print cartridge
Using the Lexmark X5100 Series Solution Center
Load plain paper in the All-In-One. 2 Click Start Programs Lexmark X5100 Series Lexmark X5100 Series Solution Center.
3 Click the Maintenance tab.
4 From the Maintenance tab, click Clean to fix horizontal streaks.
5 Click Print.
6 Print your document again to verify your print quality has improved.
7 Try wiping the print cartridge nozzles and contacts, and then print your document again.
8 If print quality has not improved, try cleaning the print cartridge
If the print quality does not improve after cleaning the print cartridge
nozzles, dried ink may be on the nozzles or contacts. To wipe the print
cartridge nozzles and contacts:
1 Remove the print cartridges.
2 Dampen a clean, lint-free cloth with water.
3 Hold the cloth against the gold nozzle area for about three seconds.
Gently blot and wipe dry in one direction (this prevents the colors in
the color cartridge from mixing).
4 Remove the old cartridges
5 Let the nozzles and contacts dry completely.
6 Reinstall the print cartridges, and then print your document again.
7 If the print quality has not improved, try cleaning the print
8 If print quality is still unsatisfactory, replace your print cartridges.
Hope this helps.
Thanks
Have a good day.
Dec 01, 2009 | Lexmark X5150 All-In-One InkJet Printer
It says
I'm sorry you are having problems with your Lexmark printer.
Please ensure you are using the correct cartridge.
X3350:
Black 32
Color 33
X5470
Black:28
Color: 29
If you are using the correct cartridge for your machine you can try to do the following:
Cleaning the print nozzles: (X5470)
1 Load plain paper.
2 Press Copy Mode.
3 Press .
4 Press or repeatedly until Tools appears.
5 Press .
6 Press or repeatedly until Maintenance appears.
7 Press .
8 Press or repeatedly until Clean Cartridges appears.
9 Press .
A page prints, forcing ink through the print cartridge nozzles to clean them.
10 Print the document again to verify that the print quality has improved.
11 If print quality has not improved, try cleaning the nozzles up to two more times.
Wiping the print cartridge nozzles and contacts:
3 Gently hold the cloth against the nozzles for about three seconds, and then wipe in the direction shown.
4 Using another clean section of the cloth, gently hold the cloth against the contacts for about three seconds, and
5 With another clean section of the cloth, repeat step 3 and step 4.
6 Let the nozzles and contacts dry completely.
7 Reinsert the print cartridges.
8 Print the document again.
9 If the print quality does not improve, clean the print nozzles. For more information, see “Cleaning the print
cartridge nozzles” on page 92.
10 Repeat step 9 up to two more times.
11 If print quality is still not satisfactory, replace the print cartridges.
If you are still getting the incorrect cartridge message it would be best to return the cartridge and exchange it for a new one.
Thanks
Catherine
Mar 03, 2009 | Lexmark X5470 All-In-One InkJet Printer
Fax will not print after installation of new cartridge
Look at your NEW print cartridge again, very carefully. I'll bet there's another piece of tape on the bottom of it. That's what happened to me.
Dec 03, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Nothing there
Did you try cleaning the print cartridge nozzles.
Press Function once and up arrow 2 times
Press the right arrow once and the up arrow once
Press Start/Memory button
It will print a test parttern page
Once you insert the new cartridge did the machine recognize the new cartridge? You had to press 1 for new
When 1 is selected you will get a prompt New Cart: OK?
OK press start.
If you selected NEW the display will show the alternating messages at right. Align Cartridge----1 Print 2 Set
Press 1 to print an alignment page
Hopefully, it will printed. Let me know one way or the other.
Mar 27, 2008 | Sharp INKJET FAX UX-A1000
Black ink
Print nozzles will be at bottom of cartridge...Make sure that u do not wet copper contacts ... first try using dry paper towel and check where ink comes and follow the procedure given below....
Cleaning procedure
  1. Remove the print cartridges.
  2. Moisten a clean, lint-free cloth with water.
  3. Gently hold the cloth against the nozzles for about three seconds, and then wipe in the direction shown below.
  4. Using another clean section of the cloth, gently hold the cloth against the contacts for about three seconds, and then wipe in the direction shown.
  5. With another clean section of the cloth, repeat steps 2 through 4 above.
  6. Allow the nozzles and contacts to dry completely.
  7. Reinsert the print cartridges.
  8. Print the document again.
  9. If the print quality does not improve, repeat the steps for cleaning the nozzles and contacts up to two more times.
  10. Check the warranty and try to get replaced
Jan 18, 2008 | Lexmark F4270 Plain Paper Inkjet Fax
Sharp UX-B20 Plain Paper Inkjet Fax Logo
103 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
