Question about LG Heat cool Window Air Conditioner
How do you set on and off mode on air conditioning
  • LG Master
  • 17,129 Answers
Use the remote to enter the timer to switch off - OFF timer setting and the On timing after setting the clock on the remote
Once this is presetted the unit will continue to work shut of in the thermostat settings and fully cuts off power in the set off time.
later the set will come back in the set on time and work till the thermostat setting is reached.
Posted on Aug 29, 2010
Self Evaporating is not working. Have to empty constantly. What is wrong and can it be fixed?
if this is a free standing unit, is it possible that you have it set to de-humidifier mode. This mode specifically draw moisture from the air and does require the machine to be emptied.
There are usually three settings
Air Conditioning
De-humidifier
Blower
Sep 02, 2015 | Heating & Cooling
Why incessant beeping?
Good Afternoon Friend,
I understand that your Frigidaire air conditioner, model# FRA124HT2, begins with a constant beeping, and changes the modes itself, about every 30 minutes. I also see that it ends up on a different setting each time it does this. I suggest resetting your air conditioning, by either unplugging it or shutting the power off at your home's circuit breaker for 3-5 minutes. Bring power back to it and turn it on. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 26, 2014 | Frigidaire FRA124HT2 12000 BTU...
Ac repair portable 12000 btu unit will not blow cold air
Maybe you have it set on dehumidifier mode instead of air conditioning mode. That happened to me with mine too. And turn off your timer (if it has one) or it will shut off after a while and you will forget why.
Jul 23, 2013 | Amana Portable Air Conditioner
Heater plows cold air on drivers side on my 2005 inpala
You probably have automatic air conditioning with dual zone capability, Please review the owners manual for the dual zone operation. I looked in the service manual and certain heat / air settings criteria have to be met before the system will work properly in automatic mode. If those conditions are not met, the system will assume manual operation and mostly play dead waiting for the user defined manual settings. Start with a good review of the dual zone automatic settings.
Nov 04, 2012 | 2003 Chevrolet Impala
What symbol is for air conditioning?
Here is the operating manual
www.fujitsugeneral.com/.../OwnersManuals/OPManCeilingSuspended.pdf
On Page EN 7 it has the operating instructions for the hand held remote unit. When the word "cool" appears in the display, depending on the temperature that the room is and what the remote is set for, the unit will function in the air conditioning mode.
Nov 28, 2010 | Fujitsu 36CS Air Conditioner
Thermo set "heat" and "Auto
Check the fan relay. These relays are used to cut the fan on and off when the thermostat is set in the air conditioning or heating mode or when you move the thermostat to the "Fan On" position. The low voltage usually the green thermostat wire is wired to terminal #1. The low voltage common wire to terminal #3. One line voltage wire is attached to terminal #4. The high speed blower wire usually black is attached to terminal #2. When the thermostat calls for air conditioning or "Fan On" the 24 volt coil is energized, the terminals 4 and 2 close. This causes the fan to come on in high speed. When your home cools down and the thermostat cuts the air conditioner off, the low voltage coil terminals 1 & 3 are denergized, and the fan goes off. Sometimes these little relays stick which causes the fan to run all the time or will not make good contact, which causes the fan to not run in the "Fan On" or air conditioning mode.
Nov 16, 2010 | Weather King 10AJA6001AH Air Conditioner
When the control is set on air conditioning, it has recently started to dehumidify also on that setting. What to do? The unit is 5 years old.
I'm sorry is the unit set on COOL (snowflake) or DRY (raindrop) All air conditioner will dehumidify when in cooling mode. That is just the dynamics of air conditioning. The air should still be cool depending on your settings. if the air is not cool and you have confirmed that it is in cooling mode, check that the filters are clean and if they are have the system serviced.
I take the time to answer your question, so please rate me.
Thankyou Mat
Aug 24, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Rear air conditioning setting
It sounds like your rear temp. blend door is malfunctioning. You might could get a known good controller from (ebay,junkyard,craigslist) then plug it in. If this does not fix, it is probably a blend door actuator issue.
Dec 24, 2008 | 2005 Mercedes-Benz Mercedes Benz E320 Cdi
Air conditioning
You need the AC mode/function switch to be replaced, it controls the different modes the AC/Heater are set to and where the air goes within the air ducts..
Jul 27, 2008 | 1997 Chevrolet Lumina
LG Heat cool Window Air Conditioner Logo
751 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
